Mark J Posted September 1, 2025 Report Posted September 1, 2025 If you can't bend the parts back into position to move the radiator forward, maybe you could grind off a millimeter or two off the leading edges of the fan blades? Not optimum, but... 1 Quote
Popular Post Tom King Posted September 1, 2025 Author Popular Post Report Posted September 1, 2025 I knew it wouldn't get me anywhere worrying about it yesterday or trying a fix in my head. As soon as I drove up to it this morning and looked at it the easy fix popped in my head. I used a couple of chains and two screw type load binders. The front plate is at least 1/8" thick sheet metal, but it had to move with this setup. I just hooked one end of the chains to the front plate and the other end hook onto the loader bucket. I wasn't sure if the hooks would bend the front plate where they were hooked onto it but they did their job no noticeable damage. I hit the bulges at the bottom with a smooth faced 20 oz. hammer as I tightened the binders. It went right back in place. It took three tries to get the right amount of springback, but it was really pretty easy. The fan has plenty of clearance now. I have everything assembled. Some of it was a little bit aggravating, like having to rethread some of the Chinese threaded holes in the aftermarket radiator, but overall not too bad. I just need to put fluids in, start it up, and check for leaks. Hopefully it will be ready to go to work as soon as the current renters check out tomorrow morning. Timing all seems pretty good. 5 Quote
Popular Post Tom King Posted September 2, 2025 Author Popular Post Report Posted September 2, 2025 Everything works great!! I can't imagine a new one running any smoother or quieter. The hydraulic system is smooth, responsive, and strong. The power reverser shifts are a little bit too crisp, but I learned how to adjust that when I rebuilt the reverser five years ago or so. The adjustment is easy and easy to get to. No leaks. The bucket still leaks down, but the possible things to cause that are narrowed down to the loader control and one bucket cylinder that has a small leak. I'm used to using it with the bucket easing down, so will put it to work before I get into more work on it. With no leaks on the ground, I can do all the work I need to with it before the weather changes when I can put it in the shop. It smells a lot better too, and no more pressure washing needed on it so I can put it in the shop whenever I get around to working on it again. 6 Quote
Ron Swanson Jr. Posted September 2, 2025 Report Posted September 2, 2025 That's great @Tom King! Nice to win one once in a while! 1 Quote
Mark J Posted September 3, 2025 Report Posted September 3, 2025 On 8/31/2025 at 8:38 PM, Coop said: I’ve read several novels written by a retired Navy Seal that quotes their mantra of “Slow is smooth, smooth is fast”. That quote has been rolling around in my head since you posted it. Very useful. Thanks! 2 Quote
Popular Post Tom King Posted September 4, 2025 Author Popular Post Report Posted September 4, 2025 The loader is unbelievably strong to me now. It had gotten to the point that I had to wait for it to lift a bucket of dirt and even dump it. This morning I screened a bucket full of dirt just playing with it and it never slowed down or even acted like there was anything in the bucket. I don't think it's been this strong in the 34 years that I've owned it. It's quiet too. The only noises it's making are engine and fan noises. When I reassembled it I made sure there were no left out bolts and that no parts were rubbing together-much different than what I started with. Total cost of this repair was $1754. That includes the water pump rebuild kit that came wrong and I was ghosted by the ebay seller so ate that $77. Also, I made a mistake ordering the fan by looking at the wrong part of the parts diagrams so I now have an extra $50 five bladed fan. I originally thought the wrong fan was on it looking at the page showing a five bladed fan, but stumbled on the correct page looking for other part numbers and saw the fan for the one with a larger hydraulic pump like this one on tractors with a reverser is a seven bladed fan. Now I think the one that was on it was the original and that no one had ever replaced any of these parts before. It's fun to operate now and a lot better than spending a hundred grand on a new tractor, so I have no complaints by doing this. No fingers damaged or even skinned knuckles either. I cleaned and put away all the tools this morning, so am now ready for the next job. 8 Quote
Popular Post Tom King Posted July 30 Author Popular Post Report Posted July 30 Rather than start another thread.......Another another tractor repair. About a year or so ago I put in a newly rebuilt hydraulic pump. At the time I put in all new parts, but mostly aftermarket. The new parts included all new parts for the connection between the engine and the new pump. The parts all looked fine, but like a lot of Chinese parts, the special bolts looked like the ones from John Deere that are normally more expensive than you might think they should be, but were not suitable for their purpose. Three out of the four sheared off. The radiator had to come back out and several white dishpans of other parts to get down to the broken off bolts that had to come out. Two of the three came right out in the first few revolutions of the Milwaukee close quarters M12 right angle drill with 3/16 left hand Cobalt bits. I was worried that those two coming out so easy was not a good omen. It wasn't. The third bolt was broken at a sharp angle so that no matter what I did, I could not get a bite with the bit and it wouldn't come out. Okay, I'll pull that 5-1/2" diameter pulley off the front of the crankshaft to be able to work on it with more room. I needed a puller that I didn't have, so ordered three different brands and types of harmonic balancer pullers. They came over the last few days and this morning was relatively cool and comfortable, so I tackled the pull. It was a good thing that I ordered the three different pullers because I ended up using parts out of each of the three to come up with what I needed (without making the story longer). After about 20 minutes of trying different things, the pulley came right off. Turns out it was a good thing this ended up happening. If it hadn't, I'd probably continue leaving a trail of oil droplets for years to come. The old pulley had a big groove worn in it where the seal material had been working for several decades composed only of dirt and oil. It had leaked for a long time even after I had the John Deere dealer rebuild the engine in 2009. I believe this seal is original from 1979. The new seal that I'm still waiting on to get here will make a much better seal on the new pulley. The things that work for three bolt or two bolt patterns were not big and wide enough for this pulley. The main bolt that came with the bigger bar was too long to get in behind the shaft coming out of the hydraulic pump, but the one out of this red kit was the same thread and short enough. Turns out it all was a good way for things to work out. This is one of the last leaks there was to fix on this tractor. Pam said, "I told you to get a new tractor". She did. 4 Quote
Popular Post gee-dub Posted July 30 Popular Post Report Posted July 30 If LOML told me to get a new tractor, I'd be out shopping. I did my lifetime supply of heavy equipment service and repair in my 20s. Now I cash in on that by paying some other 20-something to do it. . I still use lessons learned from that part of my life. When you are using a combination wrench that is 24" long and weighs 20 pounds, you don't set it on a cross member or a fender; you set it on the ground because (I can still here the bosses voice) "It can't fall any farther than that". 6 3 Quote
Popular Post Tom King Posted August 1 Author Popular Post Report Posted August 1 There's not much room to work on the front end of the crankshaft. I didn't want to have to take other stuff off the get the timing cover off to be able to tap out the seal. My regular seal puller could not get in there to get any leverage behind the seal. I found a seal puller on Amazon with an adjustable angle head. It came yesterday so I tried it today. The seal started to come right out. I didn't pull it all the way out because I'm still waiting on the new seal to get here Monday and the tractor is sitting outside with rain expected tomorrow. I don't want to have to clean rust out of the seal seat. Edited to add: the seal came in today, but it's in the Sun and hot now, so I'll see about getting the new seal in and maybe even back together tomorrow morning before the rain gets here. 5 Quote
Popular Post Tom King Posted August 1 Author Popular Post Report Posted August 1 I checked the seal, and it's the right one. I can't get in there to tap it in without risk of deforming the seal, but found the perfect combination of things hanging on nails in the old building that I call my Mechanic Shop. I can use the threads in the middle of the crankcase with the pulley bolt to press the new seal in place. The last picture shows the old weld pipe reducer (at least I think that's what it is) sitting on the seal. It's about as perfect of a fit as would some special tool be. 6 Quote
Popular Post Tom King Posted August 2 Author Popular Post Report Posted August 2 The seal is in and the new pulley on. My cobbled up installation tool worked, but didn't push the seal in alignment with the face of the timing cover. I decided to check to see how close my front seal installtion tool for my truck was. It was not close, but a perfect fit for probably the same seal. It eased the seal right in but it was designed to leave the seal a little proud of the surface and this one needed to be flush. My cobbled up rig finished the push in flush after the LB7 tool got it most of the way in. The pulley went right on, but I spent a lot of time finding different length bolts to get the right one to push it on far enough for the stock bolt to finish it. By the time I got this far, the Sun was up far enough to catch me, so I quit for the day. In any case the crankcase is all closed up now so no worry for rain getting water in the block and putting it back together should be fairly easy now. The good thing about working on a tractor is that everything is relatively easy to get to. I couldn't get it back in the shop the day the hydraulic pump drive bolts sheared off because there was stuff in the way in the shop and the loader was going down with no hydraulic pressure and I also had no power steering. At least I got it back right outside the front of the shop, but the Sun is a factor in working on it. Sorry pictures are out of order. Pulley pic should be at the end. Gray stuff around the outside of the seal is non setting Permatex. White specs seen inside the seal is just grease. 6 Quote
Tom King Posted August 3 Author Report Posted August 3 All back together, but I lost enough water to quit for the day. Just needs fluid and final once over. 2 Quote
Popular Post Beechwood Chip Posted August 3 Popular Post Report Posted August 3 On 8/3/2026 at 12:33 PM, Tom King said: but I lost enough water to quit for the day. Just needs fluid and final once over. You, or the tractor? 5 Quote
Popular Post Tom King Posted August 4 Author Popular Post Report Posted August 4 All back together and working great. Also not leaving a trail of oil droplet spots. Smells better too. 6 Quote
