Turned Bowl with a miter saw
My Spidersense went into overdrive watching this, but he finished the project with no accidents.  Damn.
I'm inferring what they did from the thumbnail... I'll just say that because something can be done, doesn't mean it should be done.
Ding, ding, ding.  Cool result but I have seen folks over on the router forums try to brush their teeth with a router just to show it can be done (sarcasm). Sphincter = Snare Drum on some of that stuff.
I don't want to even watch this lest I add to the number of views. :o
This sort of work must be treated as 'machining'. In metal work, jigs & fixtures are required work holding because the forces involved are simply too great to manage by meat power. Wood machining demands the same, because the risk of injury is high.
For example, my efforts made use of a custom jig to hold the work rigidly, and spin it over the TS blade, keeping me well out of the danger zone.
Just added this to the list of things i won't be trying, ever.
I would have one of 3 outcomes:
Bad
Really bad
Horrific.
I had a small wood 'machining' task today, so thought I would share.
I cut some clamp knob blanks with a hole saw in the drill press, but needed a shoulder to keep fingers off the clamping surface. I used the hole blank like so:
Raising the saw blade into it to the desired depth. With the knob blank attached to a piece of all-thread and chucked into my hand drill, I spun the blank in reverse and lowered it slowly into the hole. With the blade offset to the right side of the hole, and the drill spinning reverse, the wood was feeding IN to the cut, and also keeping the lock nut tight. Here is the result.
Perfect shoulder. I considered a similar method with the router table, but the saw seemed less likely to catch and tear out the wood, given tooth size and cut direction. A fast spin and slow plunge made this go pretty smoothly. I tried a slow spin at first, but that let the saw start to cut, rather than 'grind'.
Here is an assembled clamp (no finish yet).
Personally, I'm too lazy.  I would have just bought a threaded knob. :)
On 4/30/2026 at 4:46 PM, wtnhighlander said:
I don't blame you, this would be 'wasted' time if I had anything better to make. As it is, I'm just puttering with shop accessories and putting scraps to good use.
At least you're puttering. I sat all winter chomping at the bit and now that warmer weather is here, the only thing I've made in my shop so far is an impressive amount of coffee grounds. Just haven't been able to get into gear.
Good time for a shop project to build a little momentum.
That video seemed off, almost AI looking. Either way it seems like something I won't be doing!
