Wood Species
The design is shamelessly stolen from the Benchcrafted prototype design. Same cheap Lee Valley screw plus a couple skateboard wheels.
Very nice homebuilt leg vise! Can you tell us how smoothly it moves, possibly compared to the Benchcrafted stuff if you have any experience? I've wondered how much of the 'effortless' action can be attributed to the roller supports, versus the high quality of the screw hardware itself.
  • Replies 91
  • Views 31.7k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • There is a company on the east coast called www.mcilvain.com and they have reasonable rates on hard and soft maple, but do not carry ash. The only drawback is that you must buy 500 b.f. to get best p
  • A couple of thoughts on wood selection. I see a number folks are considering Ash. If you think about it Ash, Oak or other open pore wood will tend to trap things like metal filings (if you sharp
  • Great shots of an alternative to the Benchcrafted tail vise! However, I am distracted by the wreckage of your RC fleet in the background of that wide shot. My stepdad's garage looks like a hangar f
Posted Images
I would say take it easy on yourself and just use SYP throughout. Lots of folks use the stuff on their benches with great success. Laminating another species on top of a SYP base just sounds like a problem waiting to happen, and a lot of extra work. I have yet to hear from someone who regrets using SYP for their bench so I say dive in head first and enjoy the process.
I'd have to concur on this. I built my bench several years ago out of SYP and it's held up quite well. It doesn't really do what I want now, but that was a limitation of the design and my skills when I built it than the lumber. It's nice and cheap it's hard enough and is stiffer and heavier than hard maple iirc correctly.
It also ages to a decently neutral colour, and if it's flattened properly it'll stay pretty flat for a long time. I haven't had many dent issues or anything like that in the few years since I'd built it. Initial flatness on the other hand, well you can read how big a pain it is if you didn't do it right the first time here*
*yea it ain't pretty but it works and it's flat now :)
It moves quite smoothly, I've not experienced the Benchcrafted hardware myself. I think with the real one you can flick the handle and it glides in a few turns on momentum alone. Mine doesn't do that but it is very smooth so I would imagine the screw and round handle have something to do with it as well.
Here are the first three, steel plates on the bottom close up a rabbit in which the T shaped block slides.
Another shot of the underside, there is a groove reinforced with angle iron to accept the sliding leg vise.
Great shots of an alternative to the Benchcrafted tail vise! However, I am distracted by the wreckage of your RC fleet in the background of that wide shot. :) My stepdad's garage looks like a hangar for RC planes, so I've been trained well. I enjoy describing the time that my wife flew (while on a trainer setup) a small electric foamie directly into the flight path of a large gas powered B-52 replica. Less than a second later, it looked like it was snowing.
Thought this thread might be the place for this question ... quarter-sawn or not?
I have access to some Victorian Ash which is quarter sawn and wondering if it's worth acquiring it for certain parts of my bench. It's a little more expensive so couldn't do the entire bench with it, but are there any particular parts people feel it might be more useful for? Or it is really an expense not worth bothering about?
Thanks,
Af.
I wouldn't bother. The only reason would be increased stability and the only place we might benefit from that is the top. But in the construction of the top, standard flat sawn lumber is turned 90 degrees, effectively creating something that looks and acts like quartersawn wood. So id say save the money and get flatsawn.
(null)
I thought as much. Thanks for the confirmation Marc. Can't wait to get started on this build, but I might be a little behind the others - gotta save a bit more for the timber first. :)
Guildies,
I felt I should post this since I started the thread.
For better or worse i ended up with all Soft Maple FWL, 8/4 (~150bf) and 4/4 (~30bf) it is now sitting in my shop and waiting for milling.
I used the cutlist to make sure that for the widest parts (Leg vise chop, dead man) i had boards wide enough.
This is a LOT of wood!
Time to make some dust...
Thanks for all of your comments, ideas, suggestions and guidance!
Well I too finally dropped some coin on lumber for the build. Douglas Fir (DF) kiln dried to about 7% moisture the same as everything sitting in my shopfor over a year. not a single knot and it is nice and true. now I do have to mill it but I expect it will remain straight,
QUESTION: any experence with dogs in Walnut? I may highlight the DF benchtop with Walnut and was thinking about having my dog holes in the strip that would be walnut. Any wood properties that raise a concern that I should be aware of?
not at all...I had a concern about this being that walnut is harder than DF or soft maple which I am using. I ws worried about the walnut beating on my doghole strip, but when I thought about it the walnut's long grain is contacting the soft maple or DF end grain...end grain is harder than long grain so I equated that the dogs will take the beating before the end grain of the dog hole strip does and how do I equate this. Sinple: Take the walnut's long grain and put a block of df end grain against it (same width and height) and smash the end grain of the df, with a hammer, into the walnut long grain and see what dents greater. 99 percent sure the walnut's long grain is going to give more.
The KAISER OUT!!!
  • 1 month later...
Thought I'd just chime in...
Here are some prices per bf in Seattle for 8/4: (as of January 2012)
Cherry - $10.50
Walnut - $9.50
White Oak - $6.95
Soft Maple - $6.65
Birch - $6.50 (small selection)
Red Oak - $4.65
Alder - $3.95 (small selection)
Eastern Ash - $3.95
I've used a lot of the Maple in the past, but only 4/4 stock. I've also had the (un)pleasure of using real Hard Maple.
But it was my understanding that the Maple comes from Canada, and from the name... Ash comes from back east!?
So I went with Ash.
This was at:
http://crosscuthardwoods.com/
The guys there are really helpful, and if you purchase $500+ shipping is free in Seattle.
Bill
  • 3 weeks later...
I'm planning to construct my top from soft maple,and the base from some old red oak I reclaimed. But I just realized while watching the Leg Vise that I might run into a potential problem with wood modulus. I'm concerned about the top potentially compressing more than the leg over time, resulting in the leg protruding past the top and denting workpieces.
Does anyone think that's a real concern, or am I just crazy? Would it make a difference if I attached using a double through tennon (a la Schwarz)?
I would think that you would never be clamping something down with so much force that you would compress the wood. I mean if you were doing that you would likely also be damaging the wood that you are working on. As far as I can tell from the benchcrafted videos it looks like you just need to tighten the vise till its snug. Never have used a leg vise myself so take it for what its worth.
Awesome, thanks guys! I thought so but am very glad you agree. That just saved me several hundred bucks.
I bought my soft maple one week ago today for $3.30/bf. My supplier only had 8/4 in 14' lengths and 6 to 7 inch widths so I have some scrap but maybe I will use the small cut offs for something sometime. Out of that I got a couple of pieces with really nice tiger stripe so that is going on the front of the top and the front stretcher.
