N00b-in-training Posted September 3, 2015 Report Share Posted September 3, 2015 I've finally stuck a flag in the ground and said I'm going to build my home office furniture in a Campaign style, not sure how i settled on that but I think i have. I'm wanting to make it true campaign style that could be easily knocked down and carried to the next battle site. My desk is going to be relatively simple but I'm struggling on how I can attach the legs in a way that would be easily removal without hardware. I was initially thinking a sliding dovetail but i've convinced myself that won't work how i want.Here is the inspiration for my desk and the basic design i plan to build. How would you attach the legs? Quote Link to comment Share on other sites More sharing options...
shaneymack Posted September 4, 2015 Report Share Posted September 4, 2015 Dominos or slip tenons without glue. Should be solid and would be fairly easy to remove when you need to invade the next country.... Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted September 4, 2015 Report Share Posted September 4, 2015 Sawhorse style legs don't have to be "attached" at all. You could include some ribs ir grooves on the bottom of the desk that the sawhorse "backs" fit between so it doesn't slide around. 1 Quote Link to comment Share on other sites More sharing options...
N00b-in-training Posted September 4, 2015 Author Report Share Posted September 4, 2015 Sawhorse style legs don't have to be "attached" at all. You coyld include some ribs ir grooves on the bottom of the desk that the sawhorse "backs" fit between so it doesn't slide around.I was thinking about a groove with the frame of the top extending down to prevent it from sliding forward or backward but I was concerned about it lifting off the legs. I guess if I'm not happy with it i could add a table lock (like used on a dining table extension) underneath. Dominos or slip tenons without glue. Should be solid and would be fairly easy to remove when you need to invade the next country....Well... China is coming! If not them, then Iran. Quote Link to comment Share on other sites More sharing options...
Indy Cindy Posted September 4, 2015 Report Share Posted September 4, 2015 Interesting concept, but those legs look like real knee bangers. 1 Quote Link to comment Share on other sites More sharing options...
TerryMcK Posted September 4, 2015 Report Share Posted September 4, 2015 Yes I agree with Cindy. Some of the campaign furniture I have seen has small chests of drawers making two pedestals positioned either side of a resulting knee hole. Then the desktop simply lays on top of each pedestal - no fixings.Alternatively try this type of sawhorse arrangement - again no fixings required. (Supply your own uniform ) 2 Quote Link to comment Share on other sites More sharing options...
N00b-in-training Posted September 4, 2015 Author Report Share Posted September 4, 2015 Thanks for the pic! I was actually planning to make the inside legs at 90deg like this to help with the "knee knocker" issue but hadn't considered putting shelves on them. It removes from the traditionalness of it being able to break down into the smallest possible parts but I really like this. I'm at least 6 weeks from starting so I'm sure things will change a dozen times before then. Quote Link to comment Share on other sites More sharing options...
TerryMcK Posted September 4, 2015 Report Share Posted September 4, 2015 The shelves are removable too making two frames for each "saw horse" so it does actually break down. They are held in with dowels if memory serves me well. 1 Quote Link to comment Share on other sites More sharing options...
RPCV_Woodworker Posted September 4, 2015 Report Share Posted September 4, 2015 Well... China is coming! If not them, then Iran. China knows better, they already have a lease on the whole country! Quote Link to comment Share on other sites More sharing options...
banderson Posted September 4, 2015 Report Share Posted September 4, 2015 Thanks for the introduction into the campaign style. I really like the designs. I am going t have to investigate more. 1 Quote Link to comment Share on other sites More sharing options...
N00b-in-training Posted September 4, 2015 Author Report Share Posted September 4, 2015 Thanks for the introduction into the campaign style. I really like the designs. I am going t have to investigate more.I'm buying a lathe later this year just so I can make some campaign chair (a la Christopher Swarz style). Quote Link to comment Share on other sites More sharing options...
Andy Wright Posted September 4, 2015 Report Share Posted September 4, 2015 What about using table leaf pins? I used brass pins from Rockler on a sewing cabinet for my wife and they lock in really well. In my application, I added a countersunk brash washer around the female hole so that the male end wouldn't scratch the wood while you are lining them up. I would put the male end on your base and the female side on your table top Quote Link to comment Share on other sites More sharing options...
Barron Posted September 4, 2015 Report Share Posted September 4, 2015 I think the top will be heavy enough that lifting up in normal use won't be a problem. Shop bents could be used for legs, if the desk is set against a wall racking won't be a big deal. Shop bents (also known as Krenov saw horses) look fragile, but are actually quite strong. Using your groove and frame idea you would have a desk that breaks down for travel qucikly and into a small package. Quote Link to comment Share on other sites More sharing options...
