Can I add boiled linseed oil over top a cherry stain? Or is boiled linseed oil like a stain and it would bleed out the cherry?
5 replies to this topic
#1
Posted 05 January 2012 - 09:56 AM
#2
Posted 05 January 2012 - 10:18 AM
What are you trying to accomplish? I think the typical uses of BLO and stain are mutually exclusive. I would definitely worry about the BLO would "ruin" the stain, especially if wiped on.
#3
Posted 05 January 2012 - 11:01 AM
It depends on the stain...
Some stains use varnish binders that seal the wood. Oil applied after these stains may not penetrate. Other stains are all dye, and don't seal the wood. The oil should penetrate these, but may do weird things.
So I'll also ask... Why?
#4
Posted 05 January 2012 - 12:38 PM
simple answer for me, you can, but don't.
#5
Posted 06 January 2012 - 01:06 PM
Thanks for the replys. Well the wood I am using is I think pine. It's a harder pine. Not the soft pine from 2x4's. Anyway the customer wants it stained cherry. I'm in my 3rd coat and it's not getting as dark as I think she'd like it. So I don't know lol. I'm new to the staining and all that jazz. Usually I just put on stain let dry and apply poly. I got some BLO but wasn't sure it's use I guess. Didn't kkownid maybe it would work together or what. I don't have shellac or anything like that. VERY limited on finish supplies. I got cherry stain and 2 gal of poly oh ad a chestnut gel stain. Any help is appreciated.
#6
Posted 10 January 2012 - 08:48 PM
The linseed oil will not help your cause and it may just make matters worse. I would either keep trying to get the stain right or tint some poly down to the colour you want and apply as many coats as you require to get the colour right. The pale colour of the pine will keep fighting you on this one.
You mention the pine being "harder" and I wonder if it isn't something in the fir family which can be very difficult to take stain well. I'll bet you keep getting winter growth rings coming up pale, right?
Try this solution. Mix some of that cherry stain in with some poly. Test a dab on some scrap to make sure it was compatible and will still dry. If so, try it on a discreet area of the furniture piece and see if it achieves your goal.
Mark Reuten
www.nomadboatbuilding.com
Also tagged with one or more of these keywords: cherry, finishing
Woodworking Talk →
Finishing →
age or stain cherry sapwood?Started by morganew , 01 Apr 2012 |
Woodworking Talk →
Finishing →
Window trim finnishStarted by Miles , 01 Apr 2012 |
Woodworking Talk →
Finishing →
is there a way to get rid of the sawdust inside the pores?Started by Pete TGIF , 28 Mar 2012 |
Woodworking Talk →
Finishing →
Finishing lime woodStarted by Modestas Gilys , 27 Mar 2012 |
Woodworking Talk →
Finishing →
Finishing ChinquapinStarted by Arookar , 19 Mar 2012 |
