duckkisser Posted March 10, 2013 Report Posted March 10, 2013 http://chicago.craigslist.org/sox/tls/3664200272.html found a 10" ryobi drill press for 88$ i need a small machine 10-12inch drill press. is this a good deal or just junk? dont know anything about ryobi drill press. what is a good price considering ill have to drive a hour to pick it up. how do i figure out if this machine is in good condion like drill strait ect.... Quote
Indy Cindy Posted March 10, 2013 Report Posted March 10, 2013 That costs $130 new at Home Depot so I don't know if it is worth an hour drive. I have it and it's not super powerful, but it does fine for my needs. Quote
wdwerker Posted March 10, 2013 Report Posted March 10, 2013 That is what I like about this Forum, somebody has used it and will give you an opinion. Way to go Cindy. I have a Delta drill press that has awful handles, always loose and wiggly. Every machine has good and bad qualities depending on your budget and needs. Quote
Indy Cindy Posted March 10, 2013 Report Posted March 10, 2013 One of its positives is that it is very quiet. Hardly know that it is running. It has a work light as well as laser cross beams. You can set a depth stop. It drills straight and it has a small foot print. Not a bad little beast. Quote
knotscott Posted March 10, 2013 Report Posted March 10, 2013 Lower end DP's are pretty similar....HF, Cman, Ryobi, Hitachi, Griz, Northern Tools, PC, etc. It's generally the size and power restrictions that turn people off, not poor quality. If that's what fits the space and budget, any of those should be fine. Quote
duckkisser Posted March 10, 2013 Author Report Posted March 10, 2013 thanks cindy i need something for drilling small parts and since i have such a small shop i need a small footprint. i would like a more powerful unit but more powerful means larger and i dont think i can fit it my space. mostly going to use it for drilling small holes for hinges and making boxes ect.... small project type work. thinking of building knives so i would need the drill press to drill the holes for the pins in the handles. figure as long as i go slow and give the bit time to do its work it should work. Quote
wdwerker Posted March 10, 2013 Report Posted March 10, 2013 When you have a drill press with low power a trick to use is drill a small pilot hole then progressively larger bits till you reach the size you need. That way you are just enlarging a hole which doesn't require the power that drilling a big hole needs. A bit time consuming but effective way to get results from a small machine. Quote
Indy Cindy Posted March 10, 2013 Report Posted March 10, 2013 Duck, Yep, that's the kind of stuff I use it for, too. I first got it to drill holes for dowels. I've been surprised at how often I use it, just so much easier and more accurate than using a hand drill. Cindy Quote
tim0625 Posted March 10, 2013 Report Posted March 10, 2013 My father in law retired early in life and had a woodworking shop. It was still mostly a hobbiest level. He had Ryobi's jig saw, drill press (just like this one you're considering), and cordless drill and they all served him well. It's one of the basic brands that is good - not a lot of bells and whistles and you wouldn't want to have it in a machine/production shop with daily heavy use. Basically Duck, if it wasn't in a machine shop, it's probably fine - only real wear area is the spindle bearings and they are hard to wear out. Grab the chuck and see if you get a lot of play. Cindy said $130 for new....you know the normal rule - 1/2 the price of new if you can get him down. Keep us posted! Tim Quote
Byrdie Posted March 11, 2013 Report Posted March 11, 2013 I have the exact same drill except bought from Mennards under the Tool Shop brand (another of their house brands). It works fairly well but I have to agree with Cindy about it being somewhat under powered. I also don't like that amount of work area under the bit. Wish I'd saved a little extra for a floor standing model. I paid about $100 new for mine. Quote
Chris H Posted March 11, 2013 Report Posted March 11, 2013 Duck, I have the same unit. I bought mine from Home Depot. I primarily use it for drilling pen blanks. For the price, it is a good buy. I don't know if I would get it used, only because on sale it's about $100-$115. I like having the option of taking it back if something goes wrong. Pros: Super quiet, average power for it's price point, laser guide. Cons: Travel seems to be standard for all 10" presses, but it is about 3/8" short of my best selling pen's long tube... The motor occasionally stalls out on me too, but again, that is typically on an exotic wood at max plunge, so it's to be expected. Quote
