band saw fence
Sure, there are plenty of Videos but I'll give a Readers Digest version. Assume wheels complainer and you have just put a new blade on. Chances are you will have to adjust the wheels from exactly complaner in order to get the blade to track correctly. This is due to wear on the tires. Draw line on a board, cut and check for drift. Drift is normally due to slight differences in set of the blade or tire wear. This is a very very small difference. Adjust the tracking of the the blade minutely, not a quarter turn but small changes and check again. The change in tracking will alter the attack angle of the blade. Once it is neutral, lock the tracking adjustment, do a final set on the upper and lower guides and I am done. Do I recommend this for everyone, no.
Particleboard, I ment no disrespect but there are few things in woodworking, other than splinters, that are absolutes. My technique works for me, and others.
Thanks. I didn't think you meant to disrespect anyone. Your explanation is great we learn something new everyday, thank you ill give it a try. Sorry if my post sounded short or argumentative. It was just a quick phone post and meant no disrespect.
got my band saw down in the basement and only ran over my foot once and droped it once :)  i quick test cut looks like it cuts strait and even down the length im realy happy with how well it cuts eather because its jet or because the guy had it calibrated just right.  im thinking of geting these for the band saw so i can cut acuratly.
http://www.woodcraft.com/product/2001885/3608/bandrollers--fits-jet-and-most-imported-14.aspx i like the bearings better then just the blocks
http://www.mcfeelys.com/product/KTC-1001/Kreg-Band-Saw-Fence im leaning towards kreg fence rather then the mag fence because i dont want to have to line it up everytime with the blade.  the track will keep it lined up with the blade
http://www.mcfeelys.com/product/KTC-1003/Kreg-Micro-Adjuster do you guys think this is necissary keep in mind that im going to use the band saw basicly as a table saw to rip lengths, to make band inlays,  to cut out carving blanks, band saw boxes.  to resaw so i can make small boxes ect......
Duck, do you use one on your TS and router table? If so, then you will probably want one on the BS. I don't have one on any shop tools. The 1/32nd marks on the TS are good enough for my work. I have thought about one for the router table though.
--BRuce
I got the micro adjuster at the same time I bought my Kreg fence.  There are pluses and minuses to it.  It sure does make it easier to make fine adjustment rather than trying to "nudge" the fence back and forth until you hit the right spot.  On the other hand, I find it has quite a bit of "slop" in it.  Easy enough to get used to, I just expected tighter tolerances.
thanks byrdie i ended up not geting the micro ajuster.  i can always get it later if i am too frustraited with my saw.  so far i havent had to ajust my bandsaw fence the guy who sold it to me had it prity strait on.  because the blade has a small warp in it propably from someone trying to twist it back and forth while cutting so my cuts are off by about 1/32 where the the blade wonders back and forth.  so some parts are little bigger then other places.  i figure ill use the saw for cuting out bowl blanks and eventuly when the blade is dull ill put a new blade on that will run more true.
I've used a very similar method to this and have had great results. I took a band saw tuning class and came out of there believing that I would never have drift again. I have to admit, I am now one of the tune it right, toss your drift-master converts. My bandsaw is a craftsman POS and I get great results with almost imperceivable drift. Of course, if I ever want to change the blade or something like that, I have to start over.
I took a look at and tried the method mentioned in this thread and found it just creates a controlled drift, steering the blade. Blades have a neutral not steered adjustment. Neutral setting makes it where the fence can be set at any angle inside the kerf and still cut straight. This is how Olsen and most band manufacturers suggest setting up the blades. I agree there is more than one way to skin a cat. Drift fences come from the world of big flat tire euro saws where there is no way to adjust for neutral.
Below is neutral on my saw it will cut straight at either angle in pics or anyplace in between. Table is used to set miter slot within range.
I agree!   By the time I remember which lock screw to loosen, and remember to take the play out first, I could have tapped it.  :D   Most of the time, I leave the microadjuster disconnected.
The Fine Woodworking Tools & Shops issue (Winter 2012) reviewed bandsaw fences and found the Grizzly Resaw Fence Complete (H7587) slightly better than the Kreg.
I have the grizzly AndyF I like it alot the price was good also as I recall you can adjust for drift easily, and reconfigures from tall resaw mode to low profile quickly.
