Guestion about guide bushings - are they really that useful? Or should I just invest in a good top-bearing and bottom-bearing pattern bits?
Both guide bushing are cheap and dont replace a pattern bit.
Is this 690 variable speed?  My first router was a hand me down fixed speed Porter Cable.  I was fine with it for a couple years but then I needed to use some larger bits that are supposed to run at lower speeds.  I needed a plunge router anyhow so I bought a variable speed plunge router.  But if I had to start from scratch with one router I would have bit the bullet early on and gone for a variable speed model.
No the 690 is not variable speed. Small HP routers do not need to be variable speed, it would be a waste of money. They should not be used with cutters that need to be slowed. HP is rated at max rpm so slow down even a 3.25 hp to use on a panel raiser and you dont have any where close to 3.25HP.
Is this the porter cable you guys are recommending?
PB - You mention getting both pattern bits and bearing guides - I think I see the difference is that the guide bushing is fixed to the base, so you can use it with templates/guides/whatever there you'd need, say, a shallow or partial-depth cut, where a bit's bearing wouldn't engage. You just have to remember to account for the width of the bearing.
Is that correct?
Another woodworker with the famous router addiction! I wonder who has the most routers...
Is there a prize for this contest?
As many 690s as I have (a number of dedicated ones in toolboxes with regular dovetail jig, and door lock templates, etc.) , if I'm going to change a bit in one for a one off use, I reach for the 11amp Milwaukee.   It has a better fine adjust on the depth, and a better usable clamp to affix once you get the depth right.  I have some Milwaukee tools that were made in the US before they started making them in China, but this router is pretty good for one made in China.
Is that correct?
That's right.  I still use some with the bushing because the templates they work with a seriously old, but still work great.  If I'm making a new template, it's for a bearing guide.  The bearing guide is the same diameter as the bit, so you make the template exact size.
Time for a poll!
I had a floor standing pillar and other than hanging my clothing on it or using it as a cup holder it never was used. I pretty much used a router for anything the pillar could do. Admittedly there are some things its not gonna be able to do but with patience you can get by with the Hand drill/ router combo
PM makes a great point.
Think of it this way. 110 volts +/- times 15 amps +/- equals about 1650 watts, which is 1.65 Kilowatts, which is only 2.2 HP.
2.2hp @ 100% efficiency, which is mythical.  Likely less than 70% efficiency.....could be even lower.
Re: the poll - I'm down to 4 routers.
I think I decided on the router. Now it's just deciding between the PC690 and the Bosch kit. It comes down to the fact that I can drill reasonably straight on my own, and could make or buy some drilling guides for sensitive stuff. But the flexibility of a router for morticing, pattern work, and all that stuff is hard to beat. Glad to get ALL of the advice from you guys.
knotscott -
Absolutely. I'm semi-regularly searching the holy trinity of ebay/amazon/craigslist. Both felt reasonably good in-hand, though I think I'll probably spring for a d-handle upgrade in the future.
  • Who's Online   2 Members, 0 Anonymous, 56 Guests (See full list)
