osgw380 Posted October 14, 2010 Report Share Posted October 14, 2010 I've got what may be a stupid question but i'm new so i figure i'm allowed a few. I'm working on making a picture frame that has spots for 3-4 pictures. The frame will be two contrasting colored hardwoods. The middle part of the frame is going to be checker board pattern of the contrasting woods (similar to a cutting board) with cut outs in the middle for the pictures. The pictures will be framed around with cornes forty fived and the edge of the frame will also be trimmed similarly. I figured i would spline the forty-fives. My question is do i need to worry about movement where the checkered patterns meet the framed outside edges or is just glue or possible biscuits plenty and i do not need to worry about movement on a picture frame? Thanks allen Quote Link to comment Share on other sites More sharing options...
iSawitFirst Posted October 14, 2010 Report Share Posted October 14, 2010 Wood expands the most across the grain. Usually frames are so narrow that there's virtually no movement. If you're dealing with pieces narrower than a few inches you'll be OK. Unless the wood is green. Quote Link to comment Share on other sites More sharing options...
Bombarde16 Posted October 25, 2010 Report Share Posted October 25, 2010 Perhaps I'm reading the description wrong but it sounds as if you may have a problem with the inner, checkerboard part versus the outer frame. Could you give us a simple drawing? Quote Link to comment Share on other sites More sharing options...
iSawitFirst Posted October 25, 2010 Report Share Posted October 25, 2010 Well, now i've re-read it and this time it sounds like you're worried about the rate of expansion for the checker box being different that the rate for the frame. Without sizes of both its hard to say. When making a game board you definitely need to allow for wood movement within the frame. What size is the checkerboard? Quote Link to comment Share on other sites More sharing options...
osgw380 Posted November 2, 2010 Author Report Share Posted November 2, 2010 Well, now i've re-read it and this time it sounds like you're worried about the rate of expansion for the checker box being different that the rate for the frame. Without sizes of both its hard to say. When making a game board you definitely need to allow for wood movement within the frame. What size is the checkerboard? I haven't worked out exact size yet approxiamently 36"x36" or so. There will be 3 maybe 4 cutouts in different locations for pictures. And yes thats what i was worried about the checkered part expanding and making the frame around the checkered pattern mess up the corners. Best way to describe it would be a cutting board framed around with cuttouts for pictures. Thanks for all the help. Quote Link to comment Share on other sites More sharing options...
Beechwood Chip Posted November 3, 2010 Report Share Posted November 3, 2010 One of the tricks used in making chess/checker boards is to glue a thin veneer of the squares to a stable base like plywood. You wouldn't do this for a cutting board because you would cut through the veneer, but for a picture frame it should be fine. As I understand it, the thin veneer doesn't generate enough force to move against the glue and the base. Quote Link to comment Share on other sites More sharing options...
