hi guys, I've had a problem with my table saw, specifically with the motor. It's and older JET 5 HP cabinet. I'll try not to go into too many details but was wondering if any of you guys have had a similar experience and/or more expertise than me on things electrical/mechanical that could help me get it up and running again. Here's some details:
I was using the saw the other day and it was working fine. I went to start it for a cut and got a big flash from the motor. Could even see it from above the table. I started smelling burning wood! Immediately got under the table, and removed the motor which was a huge pain in the a$$. Pulled it all apart and found it was pretty much caked with dust everywhere and the spark had caught the saw dust on fire (there were a few smoldering embers in there). also bearings on the shaft weren't smooth. so cleaned it all up, and got the bearings replaced and spins very smoothly now. Put it all back together and wired it up outside the saw. Tried to turn it on and got the same results. big spark or arc which threw the breaker. Tried again and it actually working (spun the shaft). However, only worked once and now it won't do anything. I'm not familiar with how the wiring on the motor works but it's definitely arcing where the conductors are connected near the shaft. I've attached some pictures if it helps. if any one has any ideas, it would be much appreciated. One other thing: now when I switch it on there's only a slight electric hum from the switch but no effect at the motor. There's not a fuse somewhere is there? I suppose I should check whether there's power at the motor now. regardless, the arcing is probably the main problem.
post-14703-0-13744200-1422774325_thumb.j
post-14703-0-52630600-1422774326_thumb.j
post-14703-0-28284000-1422774327_thumb.j
post-14703-0-28909500-1422774328_thumb.j
post-14703-0-09432400-1422774329_thumb.j
post-14703-0-67294100-1422774329_thumb.j
post-14703-0-65222900-1422774330_thumb.j
post-14703-0-28232100-1422774331_thumb.j
Motors that size usually have a starting and a run capacitor. After a huge spark any number of things could be fried. I would look for a motor rebuild shop to check it out for you.
I agree with Steve. This could be anything from a bad cap to a need to be rewrapped. A motor shop should act like an auto shop by diagnosing first. If the cost of repair is too great for you personally, they may also give you a credit on a trade knowing that they can rebuild and sell it.
Picture 5 shows why it won't run now: the contacts are fried on the centrifugal switch. That switch is normally closed at startup, which puts a capacitor in cuircut to provide a phase shift to get the motor started. The switch opens when the motor comes up to speed. Without that capacitor in circuit, the motor is effectively a dead short when it isn't turning, so your breaker trips. If you have a motor repair shop nearby, they should be able to repair it for a fraction of the cost of a new motor.
If you try checking the capacitors it is extremely important that you don't touch the two leads together. That would cause a rapid discharge and possible explosion. I have seen these large capacitors blow and you don't want to be anyway close by. Make sure you have safety goggles on, if the cap would pop. some are filled with oil and you don't want that crap in your eyes. I would take the whole motor to a qualified tech.
You have to discharge the cap before connecting your meter or you will let the smoke out of the meter. Touch the leads together to discharge with a insulated object like a screw driver. They are little caps in a 5hp motor won't hurt a thing.
If you don't test motors routinely, I will again suggest a service shop. Discharging and testing caps is not a rookie endeavor in my opinion. Determining what caused the char is paramount. Windings need to be recertified. This is like a failed O2 sensor on a car. Don't replace the sensor without determining why it failed.
thanks all for the responses. I'll have to see if I can find a motor repair shop. My thought was also that it was/is the thing from picture five. didn't know it was called a centrifugal switch but now I do, thanks. Not sure where I can find that part. Maybe Grainger? If that's it, I may try that first before having to take it to someone. It appears the main switch (picture 1) is working. what would I hook the  multimeter to? the two leads or conductors at the centrifugal switch? Thanks!
There may be a wiring diagram inside the motor terminal box cover that shows the capacitor connections.
You can use the volts setting of your meter to slowly discahrge the capacitor. Once you determine which wires go to the cap, set the meter to AC volts, at some range above 220. Connect the test leads to the capacitor wires and wait for the meter to settle down to zero. Then switch the meter to the ohms (resistance) range. A fully discharged capacitor will briefly show a very low resistance, then build higher and higher as the battery in tbe meter charges it. A normal cap will settle out at several megohms of resistance. A low resistance indicates a bad capacitor.
  • Who's Online   0 Members, 0 Anonymous, 45 Guests (See full list)
    26,008
    Bob44
    Bob44
