Chicirda Posted May 3, 2015 Report Posted May 3, 2015 Are battery powered brad nailers just as good as air compressed nailers? If not, why? Thanks. Looking to get a nailer, but do not have a ton of room, so I'd like to avoid an air compressor. Quote
Tpt life Posted May 3, 2015 Report Posted May 3, 2015 Battery supplies the spark for butane powered nailers. Can you specify if you mean true battery power or butane impulse (Paslode)? Quote
Chicirda Posted May 3, 2015 Author Report Posted May 3, 2015 Well I'm trying weigh my options for nailers without an air compressor. So I supposed I'd be open to either. I just don't know how well they perform/what is the big advantage of have an air compressor. Quote
Tpt life Posted May 3, 2015 Report Posted May 3, 2015 Compressor powered nailers will run circles around impulse. Impulse is most used where hoses and compressor setup is impractical. The butane fuel cells are an out of pocket expense. If you are contracting, the homeowner pays the electric bill. Impulse can freeze up in super cold environments and should be stored warm. They are also a tad bulkier. The deciding factor is going to be your expected usage. I have not ever used a battery nailer. I cannot imagine them efficient for more than a few nails except at pin or short trim nail sizes. Quote
treeslayer Posted May 3, 2015 Report Posted May 3, 2015 I have a space problem also, mounted a small compressor on the wall and hooked it to a hose reel with 100 foot of hose, works well with my brad and pin nailers and I can pump up the kids car tires when they go flat sitting on the street 2 Quote
Janello Posted May 3, 2015 Report Posted May 3, 2015 Compressor powered nailers will run circles around impulse. Impulse is most used where hoses and compressor setup is impractical. The butane fuel cells are an out of pocket expense. If you are contracting, the homeowner pays the electric bill. Impulse can freeze u in super cold environments and should be stored warm. They are also a tad bulkier. The deciding factor is going to be your expected usage. I have not ever used a battery nailer. I cannot imagine them efficient for more than a few nails except at pin or short trim nail sizes.I used a DeWalt 20V cordless framing nailer to nail all my purlins in my pole barn. It drove 3.5 inch framing nails all day no problem. It uses no gas or air. The only draw back is the nail capacity. I imagine more cordless nailers like this are in the works. DeWalt also makes a 16 ga 18V finish nailer but I have no experience with it. Its basically older technology than the brushless framer i used. I have used a few different passload nailers in the past and hated every one of them. Expensive cartidges that smell bad, bulky and heavy. Quote
..Kev Posted May 3, 2015 Report Posted May 3, 2015 I used compressed air for a lot of things other than nailers so, find the compressor valuable to have. Sounds like treeslayer has a nice solution for that space issue. Quote
Tom King Posted May 3, 2015 Report Posted May 3, 2015 I wouldn't want to be without an air compressor anyway. Quote
Tpt life Posted May 3, 2015 Report Posted May 3, 2015 I went digging. I got my compressor, roofing gun, framing gun, and two trim guns (all guns were pawn shop rehabs that just needed new o-rings) for less than the prices I am seeing for the 20v gun. On Janello's recommendation I might try the gun in place of a Paslode purchase, but only when hoses and compressor did not work. Quote
Janello Posted May 4, 2015 Report Posted May 4, 2015 I went digging. I got my compressor, roofing gun, framing gun, and two trim guns (all guns were pawn shop rehabs that just needed new o-rings) for less than the prices I am seeing for the 20v gun. On Janello's recommendation I might try the gun in place of a Paslode purchase, but only when hoses and compressor did not work. Point well taken. I get most of my tools free of charge. One of the benefits of purchasing tools in large quantities for a living, so I sometimes don't think to look at it this way. The OP wasn't looking for a framing nailer, I was just making a point that battery operated nailers can and do work well. 1 Quote
ColinF Posted May 4, 2015 Report Posted May 4, 2015 I've used a paslode on jobsites before, they would probably be good if they had 1 user that took care of them and not 5 or 6 guys passing them around, 3 or 4 of which could care less about how it's taken care of. 1 Quote
