So.. like the subject says. Just bought one. First.. a lot smaller than I thought it would be. First impression was that I am an idiot for spending $115 on it.
My question is, do I need to change anything to use it as a general block plane? I would like to be able to use it on endgrain, but also just for general block plane reasons. Honestly, I never want to own more than two block planes. This one and the rabbeting block plane that I should have just bought but was sick of waiting (I kept spending money on other stuff so I was short.) So I'd like this one to be as versatile as possible. Do I add the 5 degree microbevel to it? Leave it be?
Thanks for the advice :)
You may have been better off spending your money on a larger block plane if your goal is to tackle end grain. Not to say that it can't, but the adjustable mouth on the larger sized tools as well as the increased purchase the body affords would have been more beneficial to your goal.
Having said that, the plane you have is a very nice tool. It was the first LN plane I purchased. I use mine to lightly chamfer edges like the side of a table top or similar. It is a great general purpose plane.
I have a Veritas low angle block plane. It works great on end grain, does everything I need a block plane to do, chamfer edges, clean up end grain and other small things. I put a microbevel on all my blades for easier honing and sharpening while removing less material. Rabbeting block plane is nice and I wouldn't mind having one,
You didn't say which one you bought...there's a 102 low angle and a 103 standard angle.  The 102 is better for end grain and the 103 is better for anything else.
If I were only going to own one block plane I probably would have gotten a 9-1/2 or 60-1/2 adjustable mouth...those are standard size block planes.  I have all four of them and use all four of them, but the bigger ones will be more versatile.
Yup, +1.
I also use a low angle Jack plane for tackling end grain on larger work (with blow out support, of course).
In the subject, I said Low Angle. The 102. My question was mainly what I need to do to make it a good all around block plane, if it needs a micro-bevel or not. Sorry if I wasn't clear!
I'm not a hand tool guy, but I understand the importance of having a few essentials on hand, so thats why I'm looking to only have one block plane. It's an investment I'd rather not make.
You're right, sorry...missed that.
Well, that's the thing with planes.  You can set many of them up to be jacks of all trades (e.g. JACK plane)...problem is, they'll be okay at many tasks but great at none.  Or you can collect an arsenal of planes that are individually not at all versatile but excel at specific tasks.  It's a compromise.
My advice would be to sell the LN, or return it before altering it. Then you should purchase the larger #60 1/2 adjustable mouth block plane.
https://www.lie-nielsen.com/product/block-planes/adjustable-mouth-block-planes-?node=4072
I don't think I understand what an adjustable mouth means. Don't both planes have the thing to extend the blade in and out? What is the advantage? Honestly one reason I went with this one is the amazon.com reviews seemed to indicate that it would do what I needed.
In a previous post, you stated that you only want one block plane. The #60 1/2 is the arguably the most versatile block plane LN makes. The adjustable mouth is on the underside of the plane. It is separate from the blade depth.. The adjustable mouth allows for less tear out on wood when using a closed mouth, and allows the plane to be used with a heavier cut be adjusting open to allow the shaving to pass. Just a more versatile tool.
As nice as the one you have is, it is far from versatile.
Fair enough. I'll go youtube the crap out of the 60 1/2 so I can learn how to use it. I just ordered it and submitted a return request for the other. Thank you, I'm glad I checked in with you guys before putting a micro bevel on. Though, disappointed I have to continue using my crappy Kobalt block plane until the new one gets here, as i will need it on my project!
So I will want a micro bevel on the adjustable one correct? 30 or so degrees?
I set a micro with my Veritas honing guide. I think it's 5 degrees higher than the planing angle.
Yet another thing I badly need :) I bought the $12 honing guide off of amazon because it had good reviews. It tells you how to do 25 degrees and 30 degrees. That's it. And the blades don't stay in the jig.
Thanks again!
You do not need a micro bevel. Some guys prefer one but I find it faster and easier these days just to work with a single bevel. In the end, both are simply edges and the wood won't know the difference. It just depends on your own sharpening preferences...
You don't need a microbevel.  Hone on the hollow grind or hone a flat bevel in a honing jig.
A hollow grind is nothing more than a jig; it's makes the cutter self-jigging.  Click the cutter to the stone and hone.  This is why I love natural oilstones, you get an audible click, along with the feeling that the cutter has been registered to the stone fore and aft of the hollow grind.
Do not use an 8" diameter or larger wheel to hollow grind thin cutters - the hollow is too shallow and you'll regulary be grinding all the way to the edge.  You need a 6" wheel and it gets better when the diameter gets smaller over time.
Proper hollow grinding never reduces the length of the cutter.  One does not grind all the way to the edge to produce a burr unless the cutter is nicked.  Only honing reduces the length of the cutter by the size of the burr produced at each honing session.
  • Who's Online   2 Members, 0 Anonymous, 48 Guests (See full list)
    26,008
    Bob44
    Bob44
