Cliff.... Your approach is the problem here. Get some double stick turners tape, put a couple of small pieces on the top of the runner, put pennies under the tracks to raise them up put your sled on top. and press down to adhere the runners to the sled base. Then use a vix bit to drill centered holes, attach the runners and give it a go. Never put your fence on until you have a smooth moving sled.
Yes, the Vix bits will be a tremendous help with getting the holes in the plywood centered on the holes in the runners.
Aside from vix bit, this is my process.
Since the battle continues I will toss out a couple other things I do that may help.  I use strips of material in the miter slots to fully support the rails and assure a good "stick" from the double stick tape.
I put a non-rubbery, double stick tape the whole length of the runner and trim to fit.  Use a thin, fabric or paper base tape, not carpet tape or that other gooey stuff some of our specialty stores sometimes carry,  You want no shifting around.
The holes and counterbores in the runners are pre-drilled before the tape is applied.  I then use the fence to help align the base when dropping it onto the runners.  Once stuck on the base is easily removed and flipped over to allow screws to be added.  I do NOT remove the runners or the tape.
I then glue and screw the front fence on.  This can simply be aligned to the edge of the base as it is not super important alignment-wise to me.
The rear fence has to be adjustable.  Expecting a sled to stay magically aligned forever is setting yourself up for disappointment.  I use t-bolts in over-sized holes.  The through holes in the fence are drill to fit the bolt shaft tightly.  All the play is in the base.
The following pics are from a different sled made the same way . . . .
I run a felt pen down each side of each rail and then push the sled back and forth in the slots.  I note where the ink gets rubbed and use a card scraper to "tune" that area.  You can see that these are UHMW runners.  I have used Incra aluminum, straight grained oak and ash and UHMW materials all with similar methods and results.  I have no preference.
I then run through the 5-cut method to align things and find I can trust the sled implicitly.  Somewhere down the road I will notice something not quite right and have to do the 5-cut method again.  I do not find this happening with my fences made of laminated strips of BB ply so you may want to thin about that over solid wood fences.
If you were closer I would be glad to drop by and help you give it a try.  Sometimes having a fresh set of eyes on something is all it takes to get me over a rough spot.
I disagree because I had wooden runners on the last sled, and had the same exact issue where it wouldn't slide after screwing them to the sled base. Hence the assumption that my slots aren't perfectly parallel. Plus, the humidity swings here are legendary and I like to remove that variance from it.
Also, my fence is made of plywood, laminated. It was dead straight when I first made it, now it's off by quite a bit. Possibly because it's terrible plywood because that's about all I can get in this area. This particular sled made it about a month and now it won't cut square because of this issue.
In other words, the compounding fuss annoys me and I'm buying the Incra system so I can stop dealing with 1000 different variances between the material I am using or the tool. Hopefully it will work out.
I saw a video of someone (Drunken Woodworker?) who installed aluminum miter rails by setting them into place and pulling the sled backward so that the first several inches are hanging over the front of the TS.  That way he could drill from underneath and get the first couple or few screws into place on each rail with most of the rails still in the miter slots.
I'll look for the video when I get to a computer.
I think your double sided tape may not be as secure while the screws are going in as you'd hope or need.
Baltic Birch is the only plywood I use (from Lowes.)
And again, I had the exact same issue happen when I did use wooden runners and screwed down from above into them without ever moving the base off of the runners. I have made 5 sleds (4 crosscut, 1 dado,) and all bound up after fastening down the base to the runners.
Anyway, this thread wasn't about sled issues, I made the decision to buy the Incra, I just wanted to make sure there wasn't some sort of insane reason that everyone recommends making the blade and fence parallel to the right miter and not the left. I did not think there was.
Is it real Baltic birch? That's not really a big box sort of product & it isn't listed on their website. There's a huge difference between real BB & birch ply that's sold at Lowes or HD (around here, anyway).
I know I'm going a little off topic here, but I've read about your sled troubles in other threads. Wonky ply can cause a lot of grief.
  • Who's Online   2 Members, 0 Anonymous, 64 Guests (See full list)
    26,008
    Bob44
    Bob44
