Cliff Posted April 19, 2016 Report Posted April 19, 2016 I have my blade aligned to my right miter slot, which is the side with the arbor nut. Then I have my fence aligned with that miter slot as well. In my continuing crosscut sled issues.. after I finally got the stupid thing .002, the plywood has warped in some fashion so that when I hold my Vertias straight edge against it, I can see the bow across the entire thing. So I have been using my Kreg miter bar, and discovered that it isn't square either. After some thought I realized it's probably because it rides in the left miter slot, and not the right where I know the blade is aligned. I'm reasonably sure my slots aren't parallel because when I create sleds, I can't move the sled forward or back with the miter bars tight to the sled base, I have to loosen the screws to allow play to get them to move. I'm thinking real hard of picking up the Incra 5000 system. But I will definitely want to run it in the left slot for at least 2 reasons- 1. it's the same side as the on/off switch, so I prefer to stand on that side of the blade. 2. The steel wing on the right side of the saw slopes downward significantly. I'm not sure if it can be fixed, since the cast iron is straight and the rails are straight, that leads me to believe that the steel wing is warped or the hole the bolt goes through is mangled and stretched. So replacing that with a cast iron wing would be optimal, but not sure I want to deal with that yet. This page: http://www.woodmagazine.com/woodworking-tips/techniques/outfitting-woodworking-shop/tune-up-your-tablesaw/?page=4 says Next, adjust the miter gauge to 90°, and set it into the slot on the arbor nut side of the blade. If your miter gauge fits sloppy in the slot, use feeler gauges to shim it snugly against the side of the slot nearest the blade. So, is there a reason for that? If I know I really want to use my left slot, which is NOT the side of the arbor nut, is there a potential downside? Does it really matter so long as you always use the same reference slots for things? I know I can't make the blade parallel to the left slot and the fence parallel to the right slot, of course, so I will need to readjust everything. Quote
drzaius Posted April 19, 2016 Report Posted April 19, 2016 Having miter slots that are not parallel is a fundamental defect in the saw that is practically impossible to fix. So, you have to ask yourself if you can function with only 1 miter slot. If not, then it's time for a better saw. If you want to calibrate to just the left slot, I can't see any reason why that won't work. Just get the blade parallel to the left slot & then the fence as well. The left slot is the one I use most of the time. Quote
minorhero Posted April 19, 2016 Report Posted April 19, 2016 If your miter slots are not parallel that is a huge problem. How far out of parallel are they? You can measure the distance between the slots and as long as measurement runs perpendicular to the slots it should always be there same. If they vary then they are not parallel. Knowing the answer to this will tell you why your sleds are not working and sleds are important. It will also answer your other questions as well. What type of saw is this? Quote
Chestnut Posted April 19, 2016 Report Posted April 19, 2016 I tihnk it's time to buy a new table saw. You've been wanting one for a while. Either that or run all your sleds using the 1 slot that is parallel to your blade. Personally and feel free to correct me but i don't' see the need to using 2 miter slots other than making damn sure your miter bars are perfect. If your using some metal adjustable miter stock I'm sure that it's up to snuff to ride in the slot with minimal tolerance errors. Quote
collinb Posted April 19, 2016 Report Posted April 19, 2016 56 minutes ago, Cliff said: I have my blade aligned to my right miter slot, which is the side with the arbor nut. Then I have my fence aligned with that miter slot as well. In my continuing crosscut sled issues.. after I finally got the stupid thing .002, the plywood has warped in some fashion so that when I hold my Vertias straight edge against it, I can see the bow across the entire thing. So I have been using my Kreg miter bar, and discovered that it isn't square either. After some thought I realized it's probably because it rides in the left miter slot, and not the right where I know the blade is aligned. I'm reasonably sure my slots aren't parallel because when I create sleds, I can't move the sled forward or back with the miter bars tight to the sled base, I have to loosen the screws to allow play to get them to move. :::::::: This page: http://www.woodmagazine.com/woodworking-tips/techniques/outfitting-woodworking-shop/tune-up-your-tablesaw/?page=4 says Next, adjust the miter gauge to 90°, and set it into the slot on the arbor nut side of the blade. If your miter gauge fits sloppy in the slot, use feeler gauges to shim it snugly against the side of the slot nearest the blade. So, is there a reason for that? If I know I really want to use my left slot, which is NOT the side of the arbor nut, is there a potential downside? Does it really matter so long as you always use the same reference slots for things? I know I can't make the blade parallel to the left slot and the fence parallel to the right slot, of course, so I will need to readjust everything. On my first sled attempt I didn't quite have the miter rails in perfect position. I would slide the sled in a ways and as the back end entered it would grab. Might be easy to blame on the slots. Best way to check is to put the dial indicator on a long arm and check against something in the opposite slot. I've one miter fence that has set screws in it that can be adjusted. What seems to be 3/4" may be off by a couple of mills, enough to feel and affect precision cuts. So one adjusts the set screws to widen the bar effectively giving it a suitable fit in the slot. Quote
Brendon_t Posted April 19, 2016 Report Posted April 19, 2016 The mitre slots not being parallel to each other would be a pita. With that being said, I run one runner in the left slot on both of my table saw sleds. I push the sled through from the same place every time for consistency. I do not have any play in the runner at all. I feel like getting an increase sled is a band aid. A manufactured sled will have the same problems as a shop made sled if your slots are not right. I would be trying to diagnose if there is a bigger problem before throwing more money at it. Quote
Cliff Posted April 19, 2016 Author Report Posted April 19, 2016 58 minutes ago, minorhero said: If your miter slots are not parallel that is a huge problem. How far out of parallel are they? You can measure the distance between the slots and as long as measurement runs perpendicular to the slots it should always be there same. If they vary then they are not parallel. Knowing the answer to this will tell you why your sleds are not working and sleds are important. It will also answer your other questions as well. What type of saw is this? Delta 36-725. If I had to guess, a few thou off. I don't know this for sure yet, I need to check them. Just based on the evidence I've seen with problems I've had. It was suggested as being out of parallel when I mentioned in another thread that i would put my bars in, adjust them (incra bars) for zero play then put the plywood on top with double stick tape then screw them in - put them back in the the slots with base and with the screws tightened I could not move the sled at all. 54 minutes ago, Chestnut said: I tihnk it's time to buy a new table saw. You've been wanting one for a while. Either that or run all your sleds using the 1 slot that is parallel to your blade. Personally and feel free to correct me but i don't' see the need to using 2 miter slots other than making damn sure your miter bars are perfect. If your using some metal adjustable miter stock I'm sure that it's up to snuff to ride in the slot with minimal tolerance errors. Well, I agree that it's time to get a new one because I'm not satisfied with the accuracy and features on this one. However it literally just turned 1 year old. And I've bought an entire shop in that time almost. So unless another side job comes along and dumps a ton of cash in my lap I'm going to be stuck with this one for maybe 2 years. Maybe 1 if i prioritize a Sawstop over a drum sander. 39 minutes ago, Brendon_t said: The mitre slots not being parallel to each other would be a pita. With that being said, I run one runner in the left slot on both of my table saw sleds. I push the sled through from the same place every time for consistency. I do not have any play in the runner at all. I feel like getting an increase sled is a band aid. A manufactured sled will have the same problems as a shop made sled if your slots are not right. I would be trying to diagnose if there is a bigger problem before throwing more money at it. The Incra sled rides in one slot. Then there is a second piece that is a zero clearance thing that rides in the other slot. Think of it as two separate bases that ride in the slots, each trimmed to be perfect with the blade. IF I understand how it works that is. This video shows ya https://youtu.be/cgM2-3lQmw8?t=81 Quote
Brendon_t Posted April 19, 2016 Report Posted April 19, 2016 Did you buy the saw new? Being that they are still made and sold, IF the slots are not parallel, you may be able to get a new top under manufacturer defect. Quote
Cliff Posted April 19, 2016 Author Report Posted April 19, 2016 I did @Brendon_t. I will look into that after I verify. I wish I had my receipt. I might. But I doubt it. Though I'm guessing the manufacturer probably doesn't care about the receipt like Lowes would if I took it to them. They should be able to track the serial number back to the purchase date. Quote
Brendon_t Posted April 19, 2016 Report Posted April 19, 2016 That sounds like a better first step. Verify what you believe the problem is. Going back to them being able to say the slots are out of parallel by .025" is better than I think it's of because my sleds don't work right * ) Quote
minorhero Posted April 19, 2016 Report Posted April 19, 2016 I am not sure I understand how you are installing your sleds legs but it sounds different then how I did mine. I followed the directions on the wood whisper main site and that was pretty easy. If your legs are about 2/3rd the length of your miter slots that will help to resolve calibration errors as well. Quote
Tom Cancelleri Posted April 19, 2016 Report Posted April 19, 2016 I have the Incra miter 5000. It's a great unit once you at it up. Keep in mind, it's a different animal than a crosscut sled. For 90 degree cuts and batching out same sized pieces, I prefer the shop built crosscut sled. My next question is, why is your crosscut sled only using 1 miter rail. I find using 2 works better for a crosscut sled. Sent from my 831C using Tapatalk Quote
Cliff Posted April 19, 2016 Author Report Posted April 19, 2016 21 minutes ago, minorhero said: I am not sure I understand how you are installing your sleds legs but it sounds different then how I did mine. I followed the directions on the wood whisper main site and that was pretty easy. If your legs are about 2/3rd the length of your miter slots that will help to resolve calibration errors as well. I may not have described it well. This exactly: 1. put the bars in the slots on top of pennies after adjusting for snugness 2. double sticky tape on the bars 3. lay plywood on top 4. flip the plywood over and drill holes through 5. remove bars, remove tape 6. screw bars into sled with the new holes 7. place back on tape with bars in slots 8. attempt to move, it doesn't. loosen screws in the sled base until it does 10 minutes ago, Tom Cancelleri said: I have the Incra miter 5000. It's a great unit once you at it up. Keep in mind, it's a different animal than a crosscut sled. For 90 degree cuts and batching out same sized pieces, I prefer the shop built crosscut sled. My next question is, why is your crosscut sled only using 1 miter rail. I find using 2 works better for a crosscut sled. Sent from my 831C using Tapatalk Cross cut sled uses both miter slots for mine. But I've only confirmed the right one is parallel to the blade. Quote
Tom Cancelleri Posted April 19, 2016 Report Posted April 19, 2016 16 minutes ago, Cliff said: Cross cut sled uses both miter slots for mine. But I've only confirmed the right one is parallel to the blade. If you are using both slots, then the miter slots are parallel to each other. If they weren't, you'd get a lot of binding when trying to move the sled on the table. Quote
Cliff Posted April 19, 2016 Author Report Posted April 19, 2016 5 minutes ago, Tom Cancelleri said: If you are using both slots, then the miter slots are parallel to each other. If they weren't, you'd get a lot of binding when trying to move the sled on the table. That's exactly the problem I have. i have to loose about 5 out of 6 of the screws that hold the sled base to the miter bars to get it to move without resistance. But if I'm using the Incra 5000, then it just rides in one slot so that would work fine, I'd just have to make sure the left slot (my slot of choice) is parallel to everything else and ignore the right. Quote
Tom Cancelleri Posted April 19, 2016 Report Posted April 19, 2016 1 minute ago, Cliff said: That's exactly the problem I have. i have to loose about 5 out of 6 of the screws that hold the sled base to the miter bars to get it to move without resistance. But if I'm using the Incra 5000, then it just rides in one slot so that would work fine, I'd just have to make sure the left slot (my slot of choice) is parallel to everything else and ignore the right. Here's a stupid question... Did you put both slides in your miters slots and make sure they could slide freely before attaching the sled to it? Quote
gee-dub Posted April 19, 2016 Report Posted April 19, 2016 From some of the comments made here it sounds like you have been battling this issue fir awhile. It may be that you have been taking it in bite-size chunks over a period of time and it just seems like a longer time(?) At any rate, you align the blade to the miter slot you will use your miter gauge in. Sure they "should" be parallel and sure your use both for jigs but, there is no need to align to the slot you do not primarily use. Align your fence to this same slot. If the second guide bar on the sled is loose it may not be doing much for you at the accuracy levels you have been talking about. It may be helping with gross movement top some degree. Two rails are much better than one IMHO but, that assumes a level playing field. With your wonky right slot I would probably just use the left slot (you have to align it for the miter gauge anyway, right?) and move on. Sure this isn't the best situation but, what are you going to do? It is easy enough to mill a couple of slots in a saw top to spec but, if QA is lax, humans seem to slack off. If your slots are too far off there is not a good solution that I can see for that saw; the cure would be overkill for the patient. This is just my opinion but, if I had no alternative I would align the saw to the left slot and consign myself to that slot as my reference point. I made a lot of nice furniture on a 1980's Sears/Emerson contractor saw but, I threw 3 times what I paid for the saw at it to make it usable. In hindsight, this was a false economy. . 1 Quote
Cliff Posted April 19, 2016 Author Report Posted April 19, 2016 12 minutes ago, Tom Cancelleri said: Here's a stupid question... Did you put both slides in your miters slots and make sure they could slide freely before attaching the sled to it? Yeah. Cause the Incra bars have those custom things to adjust the play, so I always make sure they move without play. 5 minutes ago, gee-dub said: From some of the comments made here it sounds like you have been battling this issue fir awhile. It may be that you have been taking it in bite-size chunks over a period of time and it just seems like a longer time(?) At any rate, you align the blade to the miter slot you will use your miter gauge in. Sure they "should" be parallel and sure your use both for jigs but, there is no need to align to the slot you do not primarily use. Align your fence to this same slot. If the second guide bar on the sled is loose it may not be doing much for you at the accuracy levels you have been talking about. It may be helping with gross movement top some degree. Two rails are much better than one IMHO but, that assumes a level playing field. With your wonky right slot I would probably just use the left slot (you have to align it for the miter gauge anyway, right?) and move on. Sure this isn't the best situation but, what are you going to do? It is easy enough to mill a couple of slots in a saw top to spec but, if QA is lax, humans seem to slack off. If your slots are too far off there is not a good solution that I can see for that saw; the cure would be overkill for the patient. This is just my opinion but, if I had no alternative I would align the saw to the left slot and consign myself to that slot as my reference point. I made a lot of nice furniture on a 1980's Sears/Emerson contractor saw but, I threw 3 times what I paid for the saw at it to make it usable. In hindsight, this was a false economy. . That's kind of the way I'm looking at it too. I can't get a square cut with my Kreg precision miter bar in the slot that I have it in, so it seems to me it's time to work with what I got, and maybe buy the Incra sled just because I'm tired to death of making crosscut sleds at this point. Then focus on a new saw, which I want anyway because I have probably 5 different issues about this one that bother me. It's just a huge pile of cash and I had other priorities - well now those priorities are down to drum sander and new table saw. Quote
minorhero Posted April 19, 2016 Report Posted April 19, 2016 Ok I have a much better picture of how you are making your sleds and I definitely don't like it ;p It's too easy to move those legs a few thousandth when removing the sled and adding screws. Instead skip the feeler gauges and just create counter sink holes and screw in from the top of the sled leaving it in place. Again the wood whisperer video on this is extremely helpful. Quote
Cliff Posted April 19, 2016 Author Report Posted April 19, 2016 4 minutes ago, minorhero said: Ok I have a much better picture of how you are making your sleds and I definitely don't like it ;p It's too easy to move those legs a few thousandth when removing the sled and adding screws. Instead skip the feeler gauges and just create counter sink holes and screw in from the top of the sled leaving it in place. Again the wood whisperer video on this is extremely helpful. He glued his. With shop made runners. I'm using Incra. In order to precisely drill the holes, I'd have to ... I don't even know how it can be done. There is far more room for error when laying out those holes then there is with tape. Quote
minorhero Posted April 19, 2016 Report Posted April 19, 2016 7 minutes ago, Cliff said: He glued his. With shop made runners. I'm using Incra. In order to precisely drill the holes, I'd have to ... I don't even know how it can be done. There is far more room for error when laying out those holes then there is with tape. We must be watching different videos. This is what I am referring to. http://www.thewoodwhisperer.com/videos/the-cross-cut-sled/ Quote
Cliff Posted April 19, 2016 Author Report Posted April 19, 2016 4 minutes ago, minorhero said: We must be watching different videos. This is what I am referring to. http://www.thewoodwhisperer.com/videos/the-cross-cut-sled/ That's exactly the video I'm referring to. At the 6 minute mark you can see him drill into the purpleheart runners from above. I have metal Incra runners that I cannot do that with. The way to get the holes lined up to drill is (per the manufacturer instructions and every video online for Incra runners) to use double sided tape. Quote
Ronn W Posted April 19, 2016 Report Posted April 19, 2016 Here is an alternative that has worked well for me. I make my runners 1/8" shallower than the miter slot then place shims that are about 5/32" thick under under the runners so that the runners will be about 1/32" proud of the table. Then remove the runners and put a thin coat of glue on the top of each and set them back in place. Locate the rip fence where the edge of the sled plywood will be to act as a guide. Put the edge of the plywood on the table against the fence and lower the plywood onto the runners, then walk away. After he glue dries you can install screws if you want without having anything move. If a little glue squeezes out it is easy to clean it up. If the sled is not free slding to your satisfaction, slide it back an forth a few times, look for the scrape marks on the sides of the rails and use a card scraper on the marks. Quote
drzaius Posted April 19, 2016 Report Posted April 19, 2016 22 minutes ago, Ronn W said: Here is an alternative that has worked well for me. I make my runners 1/8" shallower than the miter slot then place shims that are about 5/32" thick under under the runners so that the runners will be about 1/32" proud of the table. Then remove the runners and put a thin coat of glue on the top of each and set them back in place. Locate the rip fence where the edge of the sled plywood will be to act as a guide. Put the edge of the plywood on the table against the fence and lower the plywood onto the runners, then walk away. After he glue dries you can install screws if you want without having anything move. If a little glue squeezes out it is easy to clean it up. If the sled is not free slding to your satisfaction, slide it back an forth a few times, look for the scrape marks on the sides of the rails and use a card scraper on the marks. He's got metal runners, so he probably won't want to epoxy them in place. Quote
Ronn W Posted April 19, 2016 Report Posted April 19, 2016 Aha! Sorry, I missed that. Nevermind. Quote
