Hey folks, i threw together this bench for the mrs last weekend. I think it came out OK considering all the wood was from the scrap pile in my sideyard. Lots of dings and damaged edges and such but its a garden bench thatll have potted plants on it. For me it was an opportunity to try my hand at some better joinery and give the woman something she wanted. Here is before final shaping and sanding.
Forgive the crappy pics i wasnt planning to upload them until....
I threw some finish on it and it blotched like crazy. It looks worse in person. Very dark wavy spots all over that appeared instantly. It almost looks like figure but its just sooo dark in those areas.
Heres the pertinents... its a blend ive used before, spar varnish, blo and mineral spirits. It was a very warm day when applied. This quart of finish was mixed probably 6 months ago to revive another redwood piece. The wood was sitting outside, covered and dry for a few years. The piece was sanded through 220 and finish was wiped on liberally with a rag, then wiped away soon after as it was drying fast in the heat.
Same finish on same species has worked well enough for me in the past on this project.
I know redwood is prone to blotching but ive never seen it even close to this dramatic before. Any help is appreciated, thanks.
Sent from my SAMSUNG-SM-G890A using Tapatalk
I've finished redwood a few times with regular poly and it gets REALLY dark. It's a very thirsty wood and my recommendation would be in the future to sand to a higher grit. The boxes i made below i sanded to 320 and they didn't come out as dark as some previous work i did where i stopped at 120. Also to note that the wood shows sanding marks worse than any other I've worked with. My common practice there is to hit it at the end with some hand sanding to blend things together. You can see some sanding marks on the piece below.
13336095_10101010871123299_5216461804595
Edit: I think your bench looks great. Maybe it just needs some sun to even out like mike said.
Mike the only reason i wiped it off is because its varnish, blo, and spirits mixed in equal parts. I thought wiping off was common practice for oil varnish blends. Otherwise it would dry slowly and stay gummy wouldnt it?
Chestnut, yeah redwood is a real pain to sand. Especially the flat face grain top. The soft wood sands away leaving ridges where the hard grain lines are. I hand planed and scraped with some success but also got alot of tearout in places. In the future ill try going to a higher grit by hand as you mentioned.
Thanks!
Here are better pics of what im talkin about.
If that is redwood it must be second growth.  Oil or a oil varnish mix should work fine. If it's going outside don't worry about blotching the color will even out and darken.
Its definitely redwood wdwerker. The pics are a little misleading i suppose. Thanks for the input i think ill throw another coat on in a few days and call it good.
Mike i used that finish because its what i had on hand and it had some spar varnish in it which should help outdoor. I like the blends on projects like this because its easy to apply and repair. On my planter box it has done quite well outside for 2+ years now. I didnt want leave it bare but i didnt want to spend time trying to get a nice film finish for something thats gonna take some pretty severe abuse.
Thanks, thats my first time doing mortise and tenon, wedged through tenons or the split-mortise lap-through-tenon or whatever youd call that stretcher joint lol.
Im still a little bothered by the weird finish though. I dont mind it enough to strip it back, but for knowledge sake id sure like to know why the same species reacted so differently to than previous projects.
I hear ya Mike and appreciate the input. But this bench and the planter box above were both made from a mix of pieces from different sources. The top slab for example has been in my yard for years, the legs were resawn from 4x4s that ive had for about 1 year. Cant recall where the stretcher came from. The planter box was a mix of home depot 2x4s and old "con-heart" from other jobs.
It would be quite a coincidence if this randomly mixed batch of wood happened to be so consistently different than another random batch. The planter shows a little wavy figure but none of the dark nasty blotching. But the bench has those dark blobs throughout, on every component. The top is the worst. The legs have some nice wavy figure that i like, but the top and parts of the legs look like i spilled coffee on them and half sanded it out.
I hate to dwell on the issue but as i mentioned before im just trying to learn from this. Whether its my finish going bad, 9or the heat (its been 100+ here for almost 2 weeks) causing the redwood tannins to misbehave or some such.
I know sanding to higher grit wouldve helped but the planter box got the same treatment as this bench and its clean and clear.
Yeah, i dont wanna mess with the bottom half at all. Maybe ill try sanding and refinishing the top just for kicks. Perhaps ill even try a coat of fresh BLO first instead of going straight to the blend. If i get similar results then its probably just the wood as u mentioned and i just happened to put similar enough pieces together both times that the results were consistent. Stranger things have happened! :-)
Great looking bench sheperd ! Nice joinery ! I agree with the other guys about the finish, don't worry about it especially it being an outdoor project.
Keep in mind for future designs that best practice is to wedge perpendicular to the grain and not parallel. There is a risk of splitting the grain if you wedge too hard when its parallel.
Thanks Shane, and yeah i learned that one the hard way. One of the legs did split a little when i over drove. I drilled relief holes at the bottom of the wedge cuts but it didnt work on that one.
I dont know why green koolaid man didnt bust through the wall with a systainer shouting "oooohhhh yeeaahhhh" to stop me ;-)
Haha! Well if you would have been doing a journal and posting pics along the way, I would have had your back !
Moral of the story, next project, journal it ! =)
  • Who's Online   0 Members, 0 Anonymous, 65 Guests (See full list)
