I have a Carbide Processors rip that is designed the same way.  I can definitely feel the difference between FTG and FTG/TCG on thicker stock.  It does remove the multipurpose of your rip as a FTG but, gives better rip performance for me on my 3HP saw.
An FTG rip will give good flat bottom grooves but, crosscuts can be a challenge.  I have a 50T ATB with a flat top raker for cutting flat bottoms with or across the grain.
That is my go to rip blade and I guess in a down and dirty would it gives a pretty good glue line rip.  But for nice stuff I still run my hand plane over it or take it to the jointer.
Yeah, I have no problem with the quality of the cut. I wasn't looking for a "glue line" cut off the saw despite the name of the blade. I have a couple of ATBs for general purpose use.
I was trying to get a dedicated FTG rip blade for using on my tenon jig and for splines in box corners, etc but I messed up and got the thirty tooth blade. Apparently the 24 tooth Freud rip blade has a true FTG. I should have looked closer and not assumed that any rip blade would give flat bottomed cuts.
On 12/27/2016 at 9:42 AM, gee-dub said:
...I have a 50T ATB with a flat top raker for cutting flat bottoms with or across the grain.
Only a true Flat Top Grind (FTG) will leave a truly flat bottom.  An ATB/R combination grind won't leave flat bottoms either, because the ATB teeth stand proud of the flat raker much the same way a chamfered tooth stands proud in a Triple Chip Grind (TCG).  The teeth that are proud wouldn't really do anything if they weren't proud of the raker.  Most true FTGs are found in bulk rip blades.
Some good FTG options are the Freud LU87(TK)/LM72, Infinity 010-024/010-124, CMT 201.024.10/202.024.10, and Amana RB1020 or 610240.  Note that the Freud Diablo, Oshlun, and Irwin Marples rippers (among others) are ATB grind.
ATB/R:
78074d1377682787-ordered-baileigh-10-hyb
TCG:
FTG:
On 12/27/2016 at 0:41 PM, shaneymack said:
It is
Just bought the thin kerf cut version of this one on Amazon, haven't even tried it yet, but will let you know if I see anything other than FTG. Great price btw, only $38.99 USD right now.
6 hours ago, Tom Cancelleri said:
I have the Ridge Carbide TS2000. Every fifth tooth is a flat raker and leaves a flat cut, after the 4 previous ATB teeth. Cut quality is great, there's a lot of carbide on each tooth.
http://ridgecarbidetool.com/10-ts2000-super-blade.html
Great blade, but the kerf isn't flat.  It'll have minor bat ears on each edge from the ATB teeth.  I'll say again....only an FTG blade will leave a truly flat bottom.  The TS2000 has an ATB/R grind.78074d1377682787-ordered-baileigh-10-hybATBR_teethdiagram13989663805362886c3a043
  • Who's Online   3 Members, 0 Anonymous, 68 Guests (See full list)
    26,008
    Bob44
    Bob44
