Patrick Posted December 31, 2016 Report Posted December 31, 2016 I've owned the Laguana LT 1800 for a few years now a would recommend you keep it on your short list. I've used it quite a bit for resawing barn beams (cut down to 6-10' lengths). Resaw King blade is worth the price. What side of Indy are you investing in? I'm in Louisville now but Indy is my hometown. If possible, you might acquaint yourself with some reputable property management groups. They usually have a strong list of subs that will churn out the work at rock bottom prices. I've done some consulting for property management groups in the past and before that was in residential lending for 18 years. Once you've successfully turned a few homes talk to a locally owned bank for cheaper money (this may well be your plan). Though hard money lenders do have their place. Quote
The Region Rogue Posted December 31, 2016 Author Report Posted December 31, 2016 5 hours ago, Patrick said: I've owned the Laguana LT 1800 for a few years now a would recommend you keep it on your short list. I've used it quite a bit for resawing barn beams (cut down to 6-10' lengths). Resaw King blade is worth the price. What side of Indy are you investing in? I'm in Louisville now but Indy is my hometown. If possible, you might acquaint yourself with some reputable property management groups. They usually have a strong list of subs that will churn out the work at rock bottom prices. I've done some consulting for property management groups in the past and before that was in residential lending for 18 years. Once you've successfully turned a few homes talk to a locally owned bank for cheaper money (this may well be your plan). Though hard money lenders do have their place. Right now I'm on the near east side: St. Clair Place just east of Woodruff place. It used to be really rough, and it still is somewhat, but it's been turning around since they had the Superbowl in Indy as there has been major investment to revive the area. Two houses down the street, two houses on the next block, and the house right across the street from the one I'm working on are all being rehabbed. I'll be working in the Fountain Square area as well. Honestly, anywhere there's a good deal. Thanks for the recommendation on the property management groups, and yeah, I'll definitely be looking at better leverage options once I have a slightly larger portfolio and track record. Lines of credit, etc. Honestly, a business loan would probably be the best, but they don't really do that for real estate investment like they do for other small businesses. LT18 is already on the short list! Quote
hawkeyestoob Posted January 27, 2017 Report Posted January 27, 2017 Here is what looks like a good deal on a big Crescent bandsaw that should be capable of doing what you need it to do. Crescent bandsaw link! Quote
HuxleyWood Posted January 27, 2017 Report Posted January 27, 2017 5 hours ago, hawkeyestoob said: Here is what looks like a good deal on a big Crescent bandsaw that should be capable of doing what you need it to do. Crescent bandsaw link! I have bought several machines from IRS auctions but you need to understand the whole process well before bidding. The issue with most hobbyists and 2,000 pound bandsaws is the logistics, few even have the vertical height needed to just get it over the threshold into the shop. Large 30-40" bandsaws can be dirt cheap because industry by and large doesn't use them anymore and they are more than most hobbyists want to deal with. While very good compared to new machines Crescent bandsaws were the "affordable" options when these were made, not the quality of Yates, Oliver, Northfield, Greenlee etc. Quote
