16G vs 14G - Rewire of track saw
You need to be a bit careful with taking some of these charts on wire sizing that you find on the internet a bit too literally. They are intended to provide guidelines for sizing extension cords or other wiring, without going through the full analysis. They don't apply directly to manufacturing a product like this. In picking the 16 gauge, Makita would have had an engineer go through all usage scenarios (which probably don't all include the saw pulling peak current continuously) and they would be looking at temperature of the wire, voltage drop, along with making sure the cord is manageable mechanically. It may very well be part of the reason that the cord is 8 feet long, is because that allowed them to use 16 gauge and meet their criteria. Any extension cord would be assumed to be adequately sized (14 gauge or bigger).
Unless you're really determined to open up the saw, I would recommend you just find a nice, flexible single outlet extension cord in 14 gauge, assuming you're not getting one that's excessively long. If you want it to stay plugged in, just use electrical tape to secure it.
If you were going to replace the cord and make it significantly longer, you would be stuck with 14 gauge, if for no other reason than you're not going to analyze its performance. You would have to be very careful about making sure that the cord is not going to have issues on the saw housing with pinching, that it has appropriate strain relief, and that it's not going to fray and wear. All that being said, if it was my saw I wouldn't modify it and void the warranty.
This does make a lot of sense on the 16g 8ft length ... this is one reason I was hoping to be able to fit a 14g on there and double the length and know I am not going to break anything.
I am wanting to make it about 15' or so to make sure I have plenty of room to work with.
So with all the help here and opinions I figured I would ask one more ... I just called Makita Support, and it was actually very pleasant. Called in and about 10 seconds later I was on the line with a tech support guy.
He basically said I was definitely not the first to think of this. He is not sure why Makita decided to go 16g and 8' but that is what they did. He said if I was going to increase the length just drop a gauge as well. So go to 14g and 15' should be good to go without any issue. The only thing he was not sure of was the wire harness thing that makes the cord go straight out for like 4 inches, it may not fit in there, which is fine.
Got it wired tonight and I'll test it out tomorrow
I'll post a how to in a new thread if anyone will think it's helpful
The 14g fit just fine. A little more snug but easy.
Rewired and tested. Nothing blew up [emoji1] happy with the new length and no longer have to worry about the length.
I have done this a dozen times or so and have just been bypassing this thread for some reason. We engaged a large number of cut cords while using a saw table running vinyl. Any insulation nick would get the OSHA guy to cut the cord in two. It can be tricky to get things lined up properly on first go. Well done.
  • 3 weeks later...
On 2/2/2017 at 4:38 PM, bushwacked said:
So how would you handle the fact that the track saw does now have a ground .. at least from every video I have seen. What does a ground do if it's not really connected to the saw?
Sorry for the late reply. I make it a standard in my shop to make all extension cords 3 prong so I can use it anywhere. No other reason. If you don't need the ground for a particular tool and it will always be used for that tool only, then use two wire cable.
  • 26,012 Total Members
  • JAR Newest Member ·
