16G vs 14G - Rewire of track saw
So took the plunge got the track saw and really really like it. Building my bathroom cabinet with it and worked very well.
The one thing I found to be a nightmare was the cord length. Plugged into my CT it was not as a long as the hose and I ran into a few instances I had to stop the cut and move the CT closer so I could finish the cut. This was not a once or twice thing, but almost every cross cut of the ply I had to make sure the CT was right up on my where the cut was happening to make sure I could get across cleanly. This was annoying because to move around after the cut I normally had to move the CT out of my way.
So with all that said ... I will be going to HD to get some cord by the foot. Probably 15-17', but just not sure what gauge. Does it even matter? Right now, it comes standard with 16/2 from everything I have read. Since there is not a grounding wire, I would assume 16G is fine for this application?
28 minutes ago, freedhardwoods said:
Longer runs require larger gauge. Here is a chart for a general guide.
http://assets.bluesea.com/files/resources/newsletter/images/DC_wire_selection_chartlg.jpg
Thanks for that! I would assume my setup is in the not critical column which would still seem to say I need 14G. Why do manufacturers not follow this?
Even at 8' it would need to be 14G for 15+ Amps. It has a 12Amp motor so the 16G would blow the 10A connection.
This is what they are selling for a replacement...
25 minutes ago, wdwerker said:
My TS 75 has a 12 or 14 gauge cord I think. I know the CT 26 has a 12 gauge cord.
I have the CT36 so I would assume its the same as well with the 12G cord. I am assuming 14G or better would be a vast improvement then and now  the question I guess becomes should I go 14/2 or 12/2? I am not sure if the 12/2 wires would be small enough to fit the connections though for the saw.
Although I think for this the 14/2 would serve me well if I get only 15-20' of it...right?
Also this saw pulls 12A at max load going through hard material. Will this break the CT if I ever do try to cut some thick solid wood maxing the makita power output?
ok so I found this over on FOG: http://festoolownersgroup.com/festool-tools-accessories/power-ratings/
Quote
Using the Festool CT dust extractors with large Festool saws and routers.
The receptacle on the vacuum is rated at max 10 amps continuous duty. Our 12 and 13 amp tools are compatible because the MMC electronics front end prevents the machines from drawing any more than they need to make a cut. This is usually around 5 to 8 amps. Only when cutting very thick or hard material do they draw their full rating, and this is usually intermittent for short periods of time. Even the 15 amp OF2000 router idles at less than 10 amps, and only draws more when cutting heavy stock.
The vacuum is drawing 10 amps also,  and with the addition of a large tool running at full load, the combination may trip the mains circuit breaker of a common 15 amp household circuit. In this case the operator can adjust the speed control of the vacuum lower to reduce the draw of the vacuum motor. This is a feature not found on most other tool triggered vacuums. Also rarely found on other vacuums is the 12 gauge wire power cord (good for a total of 20 amps, or 2400 watts)  If a project requires lots of heavy cutting with any of these larger tools, it is best to plug in the tool and the dust extractor separately. The dust extractor can then be turned on with the MAN switch setting.
Yes, the Festool dust extractor is rated at a TOTAL of 2400 watts (20 amps)? 10 amps for the blower motor and 10 amps at the receptacle. All in all this is the strongest rating of any other tool triggered dust extractor available today. These ratings are as high as possible for a portable appliance in the USA today. In the USA, any 120 volt device rated at more than 2400 watts (or 20 amps @ 120 volts) is usually permanently wired into the mains by a certified electrician.
I have used my TS 75 which pulls 13 amps all day making long rips in 5/4 white oak with it plugged into my CT 26 without any problems.
ok so from all this ... it sounds like I need to just go 14G and be done with it and happily go back to cutting material again with no worries.
The chart won't load. here's the web site.
Did a little checking. That chart, I'm afraid, is completely useless.
For example; a 10A load with a circuit length of 30' (remember to include the wire that is in the wall). That chart says that you will need a #10 wire to limit the voltage drop to 3%. However, a voltage drop calculations shows that using #14  wire will result in a voltage drop of only 1.34%. For a 3% (which is entirely acceptable) you could actually have a total length of over 60'. These calculations are for total circuit length, that is 60' means actual wire length is 120' (to the panel & back)
Just thinking, that chart must be for 12V or 24V, whatever boats use.
Just one other thing to put in the mix.  Heavier gauge is thicker, obviously, you might want to check to see if the heavier gauge cord will fit properly into the housing on your saw otherwise you conversion to a longer cord might be dead in the water.
oh interesting ... OK I will do some more digging as well. It sounds like 16G will be fine for what I am doing then most likely.
Yep, I have thought about that. I am not sure if 14g would be too big. However I was going to only get a foot or so of 14g to take home and test with. I would have not much use for a 14/2 20' around the shop haha.
Here is the chart on sizing ...
So I think it should work, but may be a little snug ...
Also the reason I am asking is because I saw this when looking for the terminal rings that it uses ... it says 16-14G so that got me thinking ...
2 minutes ago, AJ_Engineer said:
Just make a 10' extension cord out of some nice SOOW cable?
I am planning on using SJOOW, but I am going to need 15-20' .... I use SOOW 12/3 for shop cords and quad duplex boxes I have around. I dont see a need to have 600V for this purpose when 300 is plenty
I don't know if I'd want to drag a bunch of SOOW behind a tool. It's pretty thick. How about SJ? It's got a real rubber jacket, but is lighter & thinner.
yep its really heavy and especially for a track saw I think that would be a real pain in the ass.
I would use #14/3 SJO. That would make the cable useful for any portable tool in your shop for cables up to 25' or so in length. SJO cable is smaller in physical size. I suggest 3 prong connectors on each end.
By the way, when calculating line loss, don't forget to include both directions in your length calculations.
So how would you handle the fact that the track saw does now have a ground .. at least from every video I have seen. What does a ground do if it's not really connected to the saw?
My concern would be, how will it affect your warranty?
I'm not sure it will. I'll tell them the other colors got damaged and needed to be replaced for safety. Plus it's only a year warranty so worse comes to worse I'll keep the original cord for a year.
I was thinking ft at first then remembered the plug it cord and issue I had with mine at first. The plug it for the track saw is different than the plug it for the Domino and sanders. Different size wire so you can't run the bigger draw to on a smaller wire.  The first time I traveled with the tools, I brought the wrong (smaller) cord.
Now I run everything on the bigger wire which fits all.
I strapped the heavier tracksaw cord to my larger 35mm hose. Never noticed there was a difference. Thanks for the info ! I'm constanly learning stuff around here .
  • 26,012 Total Members
  • JAR Newest Member ·
