bushwacked Posted May 12, 2017 Report Posted May 12, 2017 Yes, I am doing another bathroom cabinet ... gotta make the wife happy with some honey dos before I get on to building something I want haha. So my plan here is to build a European style cabinet 24x24x7 for my kids bathroom to allow some extra storage there. However, I want to keep learning and practicing, so I will be building this out of 3/4 maple ply and then veneering it. Now, I have tossed around a few ideas on veneers and stuff. I am debating on whether I should do the cabinet in a dark or light wood and then the doors in the opposite ... or do the whole thing in the same wood. I was thinking I have it narrowed down to these 3 woods ... 1) Bubinga 2) Etimoe 3) Anigre I was thinking of the combo anigre with either bubinga or etimoe ... the above range from $16-18 for the veneer piece and would cover what I need. If I went only 1 wood, it would be the etimoe, 1) because it is cheap and 2) it is cheap. Afterall this is a bathroom cabinet in my kids bathroom. I want to practice veneering and not go broke from a few minor screw ups haha Edge banding will be a little more, almost the same as the sheet if not more. Construction, because of the veneer with be pocket screws in the cabinet and then dados for the shelves... Also, I was curious as far as the back of the doors, the site recommends a backer veneer that is lower quality I guess and not the exact wood I am actually using on the front. What should I do there? Go same wood all around or good wood on the front and then backer veneer on the back panel or just leave as maple ply? As far as tools go ... I am looking at: http://www.veneersupplies.com/products/Veneer-Glue-Roller.html http://www.veneersupplies.com/products/Edge-Banding-Trimmer.html http://www.veneersupplies.com/products/Better-Bond-Heat-Lock-Veneer-Glue.html Do I need a J Roller or Scraper to smooth it out? As far as finishing this ... I am not sure ... what goes well with veneer? Anything I am missing so far with tools or things I need to think about with this build? Thoughts on the wood? I am not sold on them, but they just look nice ... and pricing works for me! Quote
wtnhighlander Posted May 12, 2017 Report Posted May 12, 2017 Etimoe??? New species to me. Pic looks nice, though. I'd go for it. Cheap does have its advantages. Quote
wdwerker Posted May 12, 2017 Report Posted May 12, 2017 If the etimoe is cheap use it on both sides of the door. You can rip strips of veneer for edgebanding and use the Heat lock glue with it. I would just use the maple on the interior, if it's going to be wall hung and open below use a 3/4" back. Lacquer, poly or a water bourne finish should be used to seal everywhere from the water the kids will surely get all over the place. If shellac is used it will need to be protected with a better topcoat. 1 Quote
bushwacked Posted May 13, 2017 Author Report Posted May 13, 2017 If the etimoe is cheap use it on both sides of the door. You can rip strips of veneer for edgebanding and use the Heat lock glue with it. I would just use the maple on the interior, if it's going to be wall hung and open below use a 3/4" back. Lacquer, poly or a water bourne finish should be used to seal everywhere from the water the kids will surely get all over the place. If shellac is used it will need to be protected with a better topcoat. When you say rip stripes for edge banding ... literally I could rip on the tablesaw? Etimoe is like $30 and I would have enough to do full cabinet and have lots left over. Would some ARS satin work on this? Sent from my iPhone using Tapatalk Quote
wdwerker Posted May 13, 2017 Report Posted May 13, 2017 How big is the sheet ? Yes, you can cut it on the tablesaw . I put a sheet of 1/4" MDF on the tablesaw with a strip of 3/4 on the fence. Countersink a row of screws through the 1/4" up into the 3/4 , clamp , screw or attach the 3/4 to the fence. This prevents the thin veneer from sliding under the fence. Use a very fine blade with lots of teeth . Set the fence allowing for the 3/4" stock and then crank the blade up through the 1/4 sheet, this gives you a zero clearance at the blade. If the veneer curls up you can clamp a strip of 1/4 to the fence with a 1/8" gap under it to stop the curling edge from sliding up the fence. Using a push block like a Grrrippper is ideal . You could also try a straightedge and several passes with a razor knife or a veneer saw like this: http://www.veneersupplies.com/products/Two-Cherries-Veneer-Saw.html 2 Quote
bushwacked Posted May 13, 2017 Author Report Posted May 13, 2017 This was the veneer ... http://www.veneersupplies.com/products/Flat-Cut-Etimoe-Veneer-Lot--12-x-885-2-Sheets-Per-Lot.html What I am thinking of buying ... I have a razor blade I can use to cut the veneer. Unless there is a huge difference in getting the veneer saw? If I I do go veneer saw should I get it sharpened like he offers to do? Quote
wdwerker Posted May 13, 2017 Report Posted May 13, 2017 You picked raw veneer. This means you will need to seam every panel over 11 1/2" wide. You will need to be able to soften and flatten the veneers ( press needed ) and then cut perfect edges ( joint or plane after cutting ) to make the seams. Next is taping the seams together. I would buy twice as much veneer as you need. Practice and working around cracks and flaws etc. Buy a book on veneering ! The paper backed veneers are flattened, seamed and then glued to a paper back you can just cut from the sheet and glue on. 1 Quote
bushwacked Posted May 13, 2017 Author Report Posted May 13, 2017 You picked raw veneer. This means you will need to seam every panel over 11 1/2" wide. You will need to be able to soften and flatten the veneers ( press needed ) and then cut perfect edges ( joint or plane after cutting ) to make the seams. Next is taping the seams together. I would buy twice as much veneer as you need. Practice and working around cracks and flaws etc. Buy a book on veneering ! The paper backed veneers are flattened, seamed and then glued to a paper back you can just cut from the sheet and glue on. Well hell. I don't want to do all that the first time haha. I want paperbacked from the sounds of it. I'll look more on that site then for paperbacked. Although. The main reason for choosing that one is nothing is wider than the sheet so I would not have to seam. Now the flattening part with a press only is a no go since I don't have one. What about some of their softener sprays they have? http://www.veneersupplies.com/products/Super-Soft-2-Veneer-Softener-Conditioner.html Sent from my iPhone using Tapatalk Quote
Alan G Posted May 13, 2017 Report Posted May 13, 2017 @bushwackeddo you have a veneer press already? If not, what is your clamping plan? Im curious cause I want to start trying veneering soon also. Quote
bushwacked Posted May 13, 2017 Author Report Posted May 13, 2017 @bushwackeddo you have a veneer press already? If not, what is your clamping plan? Im curious cause I want to start trying veneering soon also. No veneer press. Clamping plan ... not that far along yet haha. I will be sure to cover what I end up going with though so you can see what I ended up doing. Sent from my iPhone using Tapatalk Quote
wdwerker Posted May 13, 2017 Report Posted May 13, 2017 I recommended he try Heat lock glue. You roll the glue on the panel and the back of the veneer, let it dry ( 2 thin coats recommended) then iron it in place. The heat reactivates the glue. It's better than contact cement & allows you to rub bubbles out. I've used it on case sides that couldn't be pressed. The softener works fine but then you have to press it flat and dry it flat or it curves and ripples right back to how it was. Even after you flatten raw veneers you have to cut and work around the cracks & splits. A sheet with a big bubble may split when its flattened. You said the cabinet was 24" x 24" x 7" ? So even a pair of doors would be 12" wide each. You've got to have some overhang to trim flush. If you planned 1/2 overlay hinges you just might get away with no seams. Still need to flatten & I wonder what the veneer will do when you apply glue to the back? I've only used it with paperbacked sheets. 1 Quote
Brendon_t Posted May 13, 2017 Report Posted May 13, 2017 Ross, many commercial veneers can be cut with a very sharp blade at a low angle on a box knife. When I've seamed before, I flipped them face to face, made one cut, unfolded them to reveal complimentary edges that went together flawlessly. 1 Quote
bushwacked Posted May 13, 2017 Author Report Posted May 13, 2017 Ya I couldn't find anymore that were cheaper. So I was thinking maybe shrink the dimensions to about 20x20 so I could use that veneer. Also I am not sure what will happen once the glue is applied. However I was going to cut all my pieces and then squirt just a little water on them and then sand which between to flat pieces and put weights on them to flatten them before glue. Think that would be good enough? Sent from my iPhone using Tapatalk Quote
wdwerker Posted May 14, 2017 Report Posted May 14, 2017 If the doors were 11" or so wide it might work. If you use the veneer flattener or mix up a homemade version (I've seen recipes out there ) and some very thick flat boards w weights it would probably work. 12-24 hrs or maybe more if the veneer has lots of ripples. I'm just guessing on the time. Joe Woodworker 's site has lots of info . Read well before you jump in. Sharpening does improve a veneer saw. I've got a couple of the 2 cherries saws . I just remembered hammer veneering with hot hide glue. A veneer hammer is used like a squeegee. I haven't tried it but you can trim after it cools and hardens. 1 Quote
bushwacked Posted May 14, 2017 Author Report Posted May 14, 2017 Also ... since this is raw wood veneer. Can I cut with that tool still or do I use router bit? Sent from my iPhone using Tapatalk Quote
wdwerker Posted May 14, 2017 Report Posted May 14, 2017 I would use the veneer saw & straightedge to cut parts and a razor knife to trim edges. If you sandwich sheets of veneer between 3/4 ply the tablesaw might work .The Edgeband trimmer might work but I would have a backup plan if it tears, it will not work well on the endgrain trim. Some folks use a block plane to trim. Have you done some reading? I don't veneer so often and I do a little refresher reading especially if I'm using an unfamiliar type of veneer. 1 Quote
bushwacked Posted May 14, 2017 Author Report Posted May 14, 2017 I would use the veneer saw & straightedge to cut parts and a razor knife to trim edges. If you sandwich sheets of veneer between 3/4 ply the tablesaw might work .The Edgeband trimmer might work but I would have a backup plan if it tears, it will not work well on the endgrain trim. Some folks use a block plane to trim. Have you done some reading? I don't veneer so often and I do a little refresher reading especially if I'm using an unfamiliar type of veneer. Yep was going to use ply in the tablesaw and put weights on it to help flatten. At least that's the plan for now. Been reading up on it and watching videos to become more familiar with it Sent from my iPhone using Tapatalk Quote
Tom King Posted May 14, 2017 Report Posted May 14, 2017 I just use a veneer hammer, and hot hide glue. I made the hammer out of scrap stuff. You can get a "wax heater" off of ebay for probably less than 15 bucks with free shipping. Derek recommended that a good while back, and it works as good as the high priced heater, which I believe is just the same thing with a much higher price. If you feel inclined, you can also order a cheap thermometer off of ebay to see when the glue hits 140, but when it's good and runny, it's good to go. The wax heater I bought has a little lift out container with a handle like the high priced heater, only it's aluminum instead of copper. If I did a lot of veneering I might invest in more expensive tools, but this works as good as any. I use a natural bristle brush that was too good to throw away, but not good enough to use for painting any more, to spread the glue. It might take a little longer than fancier setups, but considering the low time required for setup, it works out best for me. If the veneer is not flat, or needs a little persuading together here and there, just put glue on both sides, and keep rubbing it you get it like you want it. It's not hard to do. I expect reluctance is the biggest trouble. One thing about hide glue, you can always get it off later if you want to. Many places sell the glue flakes, including ebay. I expect there should be all sorts of videos on youtube. This is one of the low skill jobs in woodworking. edited to add: here's a wax heater like the one I use, only I found one just like it without the "wax warmer" written on the front. http://www.ebay.com/itm/Single-Wax-Hot-Warmer-Heater-Portable-SPA-MACHINE-Treatment-Salon-PRO-Equipment-/122158869704?hash=item1c713c6cc8:g:VPAAAOSwmfhX7gmP do a search on ebay for "wax heater" or warmer, and there should be many available. This was just the first link that came up for this type of warmer. 2 Quote
bushwacked Posted May 14, 2017 Author Report Posted May 14, 2017 http://www.joewoodworker.com/veneering/iron-on-veneering.htm One of the pages I'm trying to memorize haha Sent from my iPhone using Tapatalk Quote
bushwacked Posted May 19, 2017 Author Report Posted May 19, 2017 I was talking to a buddy and he mentioned that iron on wood doesn't work. Most finishes will soak into the glue and loosen it up making it bubble or fall apart. He recommended just buying veneered plywood of the species I was wanting. Then just edgeband what's needed. Is that a better alternative? Sent from my iPhone using Tapatalk Quote
wdwerker Posted May 19, 2017 Report Posted May 19, 2017 No. He's wrong. Solvent finishes should be sprayed or brushed on in thin coats, same thing with shellac or waterbourne finishes. Heat lock is far from anything he has any experience with. Old school hide glue can be heated and steamed many years later to fix a blister and it works quite well. You might have to refinish but the veneer re-attaches . Usually hide glued veneer comes loose due to storage in a wet area or a vase of flowers repeatedly wetting the same spot. 1 Quote
bushwacked Posted May 20, 2017 Author Report Posted May 20, 2017 No. He's wrong. Solvent finishes should be sprayed or brushed on in thin coats, same thing with shellac or waterbourne finishes. Heat lock is far from anything he has any experience with. Old school hide glue can be heated and steamed many years later to fix a blister and it works quite well. You might have to refinish but the veneer re-attaches . Usually hide glued veneer comes loose due to storage in a wet area or a vase of flowers repeatedly wetting the same spot. Ok good to hear haha. I don't have a sprayer to apply anything so it will all be brushed or ragged on. It will be in a bathroom so the finish will need to stand up to a good amount of steam from the shower. Sent from my iPhone using Tapatalk Quote
wdwerker Posted May 20, 2017 Report Posted May 20, 2017 Thin coats ragged on at least to begin with is one way to go . I have been spraying for 35 years. My newest HVLP spray gun is 23 years old. Buying good tools and taking care of them goes a long way. When I do sample boards I use waterbourne finishes and a foam brush. Very thin coats dry faster. Sand 320 between coats, 220-240 if the grain raises a good bit. If you stain a piece put several thin coats on before sanding then be very careful around corners and edges, sanding through the stain is a nightmare to touch up. You might try on a sample board raising the grain before you finish. I use filtered water and a clean tee shirt type rag and dampen the entire surface equally. Don't leave wet streaks, evenly wet then wipe back to a consistent appearance. Should be ready to sand (220-320) again in an hour or so. Maybe longer if it's real humid or your using solvent finishes. Overnight drying won't hurt. 1 Quote
bushwacked Posted May 20, 2017 Author Report Posted May 20, 2017 Great info Steve! Thanks! Ya I don't have the money to invest in a sprayer at the moment. I am working on building the cabinet this weekend hopefully. Then ordering supplies shortly as well. As for a finish that needs to stand up to moisture and can be foam brushed or towel rubbed. What should I be looking at? Any brands? Sent from my iPhone using Tapatalk Quote
wdwerker Posted May 20, 2017 Report Posted May 20, 2017 Ask Pug. He has used Generals waterborne finishes . Quote
