Mark J Posted August 1, 2017 Report Posted August 1, 2017 I am wondering if anyone sells a switch that could be added to an electric motor to allow the user to reverse the motors direction of rotation as needed? I have a new 120V AC electric motor and would like to be able to run it both clock wise and counter clock wise (it's on my lathe). According to the motor's directions I can remove the cover and swap the red and black wires to reverse the rotation, but that is cumbersome to do more than once and I would like to be able to alternate rotation from time to time. I'm thinking that this could be switched. Quote
mat60 Posted August 1, 2017 Report Posted August 1, 2017 May not much help but my Shapers have reverse motor switches. Quote
thatCharlieDude Posted August 1, 2017 Report Posted August 1, 2017 If you reverse the direction of a motor you reverse the polarity which is why the directions have you switching wires. There are several switches on Amazon like this one: https://www.amazon.com/Rocker-Switch-Polarity-Reverse-Control/dp/B001PNIJM2 that will switch the polarity for you. I worry about burning up the motor by reversing it too often. If you can find the right switch you can wire ito into the power cord. Quote
thatCharlieDude Posted August 1, 2017 Report Posted August 1, 2017 1 minute ago, thatCharlieDude said: I worry about burning up the motor by reversing it too often. If you can find the right switch you can wire ito into the power cord. Well I guess you probably wouldn't burn up the motor, it should be ok unless there's power fluctuations possibly caused from the switch or the wiring of it. . But be careful splicing in a switch. 110v (or 220) is nothing to mess with. Splicing in a switch may void the warranty. Quote
thatCharlieDude Posted August 1, 2017 Report Posted August 1, 2017 This site may be helpful for a DIY solution: http://www.robotroom.com/DPDT-Bidirectional-Motor-Switch.html Quote
wdwerker Posted August 1, 2017 Report Posted August 1, 2017 I got a drum switch from Grainger to be able to reverse my drill press motor. It required about a dozen wires (just guessing, it's all taped up in a bundled cable) Careful wiring and a very tight fit inside the wiring compartment on the motor. You must label or color code each wire and triple check or you can ruin the motor if it's done wrong. Years later the drill press shaft got bent. Salvaged the motor and repurposed it on a 48" fan. Still works just fine. https://www.grainger.com/category/drum-switches/motor-switches/motor-controls/electrical/ecatalog/N-19t5 1 Quote
drzaius Posted August 1, 2017 Report Posted August 1, 2017 With a single phase AC motor, it's not as simple as reversing the polarity. You need a switch like @wdwerker linked to that will reverse the polarity of the start winding only & at the same time switching the power to all windings. 2 Quote
Mark J Posted August 1, 2017 Author Report Posted August 1, 2017 So it's a Drum Switch. They're not cheap. I found this one, too: http://www.electricmotorwarehouse.com/1-5-hp-2-hp-electric-motor-reversing-drum-switch-position-maintained-rs-1/#sthash.TouR2xeA.dpbs Looks to be the same as the Grainger unit. That web page also shows a wiring diagram. I have to think about this a moment; it may be beyond my comfort zone. I guess the next step would be to pull the cover plate off the electric motor and see if I can make sense of the wiring -- e.g. is the wire to the start winding obvious. This web page was also helpful: http://www.industrial-electronics.com/motor_control/3h_Reversing-Motors-Drum-Switch.html 1 Quote
Mark J Posted August 1, 2017 Author Report Posted August 1, 2017 Yup, nope not going to work on that motor. Took the cover off, but instead of wires there's a circuit board and no real access to that. Quote
drzaius Posted August 1, 2017 Report Posted August 1, 2017 2 hours ago, Mark J said: Took the cover off, but instead of wires there's a circuit board and no real access to that. Some motors are not reversible without dissecting the motor. Care must be taken when reversing a machine that is not meant to be reversed. Threaded parts might come undone when torque is applied the wrong way. True story: We were connecting equipment for a large cabinet shop relocation & with 3 phase, there's a good chance it's going to go backwards on the 1st try. We never bumped the machinery ourselves, but had the maintenance people do it. There was a gang saw with 5 blades on it that I was especially leery of, but the maintenance guy uttered those fateful words "nothing will happen". Just a quick bump & all 5 blades came loose & were ruined. 1 Quote
Mark J Posted August 1, 2017 Author Report Posted August 1, 2017 It's a bummer though. I wish I could reverse this lathe. I might look around for a reversible motor. Maybe one attached to a new lathe ☺. Quote
