I've been using scrollsaw blades in a jeweler's saw for years. Lusted after a Knew Concepts saw but haven't had a project that would justify pulling the trigger on one yet. Really wanted a titanium one but I don't think they are available anymore.
I found that high tension, a light touch when cutting and maintaining a quicker stroke gets me the best results right up till it grabs and the blade snaps. That's why I keep around 2 dozen of each different blade on hand. Only practice lets you build speed and accuracy.
Good idea about the scrollsaw blades. The Knew Concepts saw is pretty awesome. I have an old crappy home center saw that I have used for things in the past and it's a night and day difference. Easier to control, keeps tension better, and it just looks cool (I'll admit this was one of the reasons I got it, I am building a tool cabinet to display my tools, after all...)
Sent from my iPhone using Tapatalk Pro
You journaling it? I'd love to follow along.
My previous storage method was to leave my tools wherever the hell I happened to have them last, and then spend 20 mins trying to find it later.
Coming along nicely! I made a tool chest out of Butternut and agree the power tools do leave a bit of fuzz but the hand tools work the wood beautifully. Re fret saw blades for DT's, I usually use a 12 TPI skip tooth scroll saw blade
Nah, just gonna do a finished product.
Update time:
Finished the frames for the 3" deep doors:
Also finished the face frames for the doors. Frames are dominoed together. Had a little bit of a resawing issue with the crotch walnut panels I was planning on using. Thought I was going to be able to get 4 panels out of two boards, but it looks like I am only going to be able to get 2. Since I only have 2 of the heavily figured crotch panels, I either need to try and find some similar crotch boards, or use this other piece I have (the one on the left below), which also has some crotch figure at the bottom. The original plan was to have both doors look like the one on the right (bottom panel is darker because it has mineral spirits on it). I'm still trying to figure out if I like the look of the two different doors together. Love to hear others' thoughts...
Think you're probably right about that. Unfortunately, I don't have capacity on my band saw to resaw them. I'll look around online and see if I can find something with a similar grain pattern. Might just have to save those panels for another project and get something different entirely. Worst case scenario, I can buy some veneer and make veneered panels.
1 hour ago, wdwerker said:
That looks wicked ! Fresh paper helps w drying.  What kind of glue did you decide on? You might want to do a little test run if you have some spare veneer.
Was thinking about using Titebond Cold Press Veneer Glue. Have never used it before, but they carry it at my local woodcraft. My plan was to glue up the back side of one panel first as a test run.
9 hours ago, wdwerker said:
Smart move. Going to use the same clamps & cauls ?
Nope. Planning on using 4 cauls across the top and bottom, and the panel will be sandwiched between two layers of 3/4" mdf on each side. Hopefully that will give me enough evenly-distributed clamping pressure.
Should work I think. Don't overtighten the clamps. Even pressure is what you want. If overtightened you can get lumps where the glue is forced out from under the cauls and glue starved stripes under the cauls. Apply the glue as evenly as possible.
  • Who's Online   0 Members, 0 Anonymous, 60 Guests (See full list)
