JosephThomas Posted October 27, 2017 Report Posted October 27, 2017 Can a 2hp motor be run on a 110v 20 amp circuit? I have done the basic math in the 'ideal' case and it seems to be well withing comfort in the 13-14 amp range...but I don't really know how much of a factor to use for energy loss due to inefficiencies like friction, which any motor obviously has. Is this a motor-specific thing where I should talk to the manufacturer? The motor is for a jointer, not a DC, so I don't expect the quite as huge of a current draw at startup. Quote
Tpt life Posted October 27, 2017 Report Posted October 27, 2017 Most motors run on oversized breakers due to spike loads on startup. This will vary by motor based on capacitor sizing and some other factors like torque needed at startup. I do NOT do this kind of work, but know enough to say that citing the actual motor manufacturer and model, as well as the work it is being used for (size or weight of impeller), can help get a truly informed answer. The amount of time at peak load makes a big difference. Quote
drzaius Posted October 27, 2017 Report Posted October 27, 2017 A circuit breaker will only reliably long term carry 80% of it's rated current. A 20A breaker in a circuit that draws 20A for hours on end will have nuisance tripping. A jointer is not likely to be under full load all the time, so there's that. As @C Shaffer mentioned motor circuits can have a larger breaker than the wire size would normally indicate because of the high starting current. Up here in the great white north, a breaker can be up to 250% of the motor FLA. I would say that a 2HP, 120V motor that is run close to full load for very many minutes will trip the breaker. It will draw somewhere in the neighborhood of 20 - 26A Quote
Chestnut Posted October 27, 2017 Report Posted October 27, 2017 Acording to the NEC that would be too much for a circuit. I run my "2hp" HF dc on a 20 amp circuit all the time. If it's an option 220 would be roughly half the amperage. I say you can do it with the warning the the safety police are going to harass me. Quote
JosephThomas Posted October 28, 2017 Author Report Posted October 28, 2017 Thx guys. I specified already it was for a jointer, but I should add that I don't have the motor...it's an older jointer (currently running on a 1.5hp motor) and I'm just starting to do a little research into a replacement motor, wondering if an upgrade to 2hp is something I could/should consider. fww, since someone will suggest I "just run the cable", 220 will not be available to me anytime soon (we rent, it's been discussed, it's not happening). Quote
Tpt life Posted October 28, 2017 Report Posted October 28, 2017 45 minutes ago, JosephThomas said: Thx guys. I specified already it was for a jointer, Do not take this wrong if you already know this. I just do not want you to think I did not read the OP. HP is a ratio of mass moved to time. Some motors move massive weight but more slowly. Some move very little weight but more quickly. One of the best ways to pair motors is by the shaft diameter and RPM. The bigger motor can likely handle the same load without requiring more draw in that tool, but... I realize that is more question than answer. Like I said, this is not my specialty, but rather another area of hobby for me. Quote
Chet Posted October 28, 2017 Report Posted October 28, 2017 Hey JT is this a 6 inch jointer or 8? I am just curious because if it is 6 inch I would have to think that 1 1/2 hp would be plenty, even Powermatic has just 1 hp on their 6 inch jointers. Quote
drzaius Posted October 28, 2017 Report Posted October 28, 2017 1 hour ago, Chet said: Hey JT is this a 6 inch jointer or 8? I am just curious because if it is 6 inch I would have to think that 1 1/2 hp would be plenty, even Powermatic has just 1 hp on their 6 inch jointers. My 6" has a 1.5HP & I've never overloaded the motor. Quote
