Dknapp34 Posted November 28, 2017 Report Posted November 28, 2017 I was milling up some wood for panels and I noticed that my jointer (Grizzly G0490 with Byrd Shelix cutterhead) was milling a slight convex shape into my stock. This was especially annoying as I usually like to make a sprung joint when doing panels, so it took more hand work than usual to get a good glue joint on the boards. This is the first time I've ever noticed this with the jointer, which previously had been producing dead flat results. The boards I was milling were around 50" or so and the convex curve was about 1/64" or 1/32" or so from the high point in the middle to the ends. The only thing I can think of is that my tables somehow are no longer co-planer, but I haven't messed with them, so I'm not sure how that could have happened. Anyone else experienced this with this jointer? Quote
Just Bob Posted November 28, 2017 Report Posted November 28, 2017 I have the same jointer, I would suspect the wood before the machine. Can you duplicate the problem with scrap? Quote
Dknapp34 Posted November 28, 2017 Author Report Posted November 28, 2017 I can check tonight when I get home, but the convex curve was pretty consistent on a number of boards that I was milling for the panels. Quote
minorhero Posted November 28, 2017 Report Posted November 28, 2017 I would also assume the wood is the issue. If from the same tree you could be looking at movement as the stress is being released. Try thicker stock as well and see what happens. Quote
Unknown craftsman Posted November 29, 2017 Report Posted November 29, 2017 @Dknapp34 try lowering the outfeed table a tiny bit .001. Your inserts have lost a tiny bit of edge and now the wood is riding on the lip of the outfeed table. Aj Quote
gee-dub Posted November 29, 2017 Report Posted November 29, 2017 Cutting a convex curve on a jointer would be quite a trick. This implies your outfeed end is rising. Just to check our terminology and point of reference; a convex curve will rock like a rocking chair when set on a flat surface and a concave curve would arch like a bridge. To cut a convex curve you starting point would have to arch up and away from the outfeed table continuing on this path till the trailing edge cleared the cutter head. At this point much of board could be in the air(?). Exaggerated for clarity: Pressure should be applied at the outfeed pressing your freshly jointed surface to the table as your reference plane. Quote
Brendon_t Posted November 29, 2017 Report Posted November 29, 2017 This problem can also arise from applying pressure on the Infeed table. Easy to confirm you are applying pressure on the leading edge of the board over the cutter head and transition the downward pressure to the outfeed side and maintain the pressure a foot or so past the cutter. Quote
Dknapp34 Posted November 29, 2017 Author Report Posted November 29, 2017 I checked this morning and it looks like @Unknown craftsman is correct. My outfeed table is higher than the highest point of the inserts on my cutter head. I didn't have time to raise the table and do a test cut, but it appears that this may have caused the problem. If I understand correctly, this would cause the trailing end to be tapered slightly. It's possible that this was what I was seeing, rather than a true convex curve (I have since hand planed the boards and glued them up into a panel so I can't check now). Not really sure how this happened, since I have not adjusted the outfeed table. I know that regular straight knives can wear, causing them to be lower than the outfeed table, but I wouldn't think that carbide inserts would wear like that. In any event, I will fix the outfeed table and do some test cuts to see if it resolves the problem tonight. Quote
Chestnut Posted November 29, 2017 Report Posted November 29, 2017 How long has it been since you've rotated inserts? If they have worn so they are smaller they might just need a fresh edge. Just a thought. Quote
Dknapp34 Posted November 30, 2017 Author Report Posted November 30, 2017 16 hours ago, Chestnut said: How long has it been since you've rotated inserts? If they have worn so they are smaller they might just need a fresh edge. Just a thought. Only 6 months maybe. And I'm just hobbyist, so it's not like I'm milling hundreds of bd ft a day on this thing. I've run maybe 50-100 bd ft over it in the last 6 months. I only had a few minutes to spend down in the basement last night, but I took a few passes with some scrap and confirmed that it was not actually a convex curve I was seeing, but a taper towards the trailing end. I lowered the outfeed table and the taper went away. I didn't have time to get it fully dialed-in and I actually ended up lowering it too much, which caused some snipe at the trailing end, but at least it seems like I've figured out what the problem was. Now I just need to find some time to get everything dialed-in. 2 Quote
