Hammer5573 Posted June 24, 2018 Report Share Posted June 24, 2018 I'm building a federal style sideboard with inset drawers and doors . The drawers and doors are constructed with 1/8" and 1/4" cherry bead moulding on all edges. How much clearance should I allow for wood movement (the humidity can get pretty high where I live)..? Quote Link to comment Share on other sites More sharing options...
mat60 Posted June 24, 2018 Report Share Posted June 24, 2018 If I did that when its dry here like in the winter I would leave a 1/8 and when its humid in the summer it would be 1/16. Im not one of the experts here so others may do it different. Quote Link to comment Share on other sites More sharing options...
Mick S Posted June 24, 2018 Report Share Posted June 24, 2018 Are the door and drawer fronts solid wood? Quote Link to comment Share on other sites More sharing options...
wdwerker Posted June 25, 2018 Report Share Posted June 25, 2018 What's the widest board ( crossgrain) in each door & drawer . Long grain dimensions won't change, but crossgrain will move with the seasons. 1/16 gaps look great but are a lot of effort to achieve. 1/8 gaps look pretty good and are reasonably attainable. Bigger than that starts looking worse. If you shoot for the gap on the crossgrain width to be 1/8 when it's the driest humidity in your area or 1/16 when the humidity is high you should be fine. A 6" wide piece of plain sawn cherry could move .107 ( or a little less than 1/8 over a year ) from driest to wettest. That should approximate a slab drawerfront or 2-3" wide stiles on a frame & panel door. Investing in a moisture meter will help. The " Woodshop Widget " app will help you figure movement for different species. Rift sawn & quartersawn wood moves less. Kiln dried moves less than air dried. Well finished on all edges reacts to humidity changes slower. Furniture that lives in a home that has year round temperature & humidity controls moves less. Forced air heat and air conditioning can both dry out the air so spring and fall may be when you have a little more movement. Usually a wide tabletop is more of a concern with wood movement. But inset doors with tight gaps leaves small margins. Wood movement is one of the main reasons for frame & panel doors. Always leave extra depth on the grooves on both sides of a panel side to side. The height/length of a board doesn't change enough to worry about 1 Quote Link to comment Share on other sites More sharing options...
Hammer5573 Posted June 25, 2018 Author Report Share Posted June 25, 2018 The drawer and door fronts are composed of a laminated composite surrounded by 1" thick hardwood and covered with wood veneer. I've used this approach in the past and it's worked very well Quote Link to comment Share on other sites More sharing options...
Mick S Posted June 25, 2018 Report Share Posted June 25, 2018 Just now, Hammer5573 said: The drawer and door fronts are composed of a laminated composite surrounded by 1" thick hardwood and covered with wood veneer. I've used this approach in the past and it's worked very well That's how I do my inset doors and drawers. You could probably get by with a smaller gap, then. You have much more humidity than we do, but unless your stiles and rails are really wide and crossgrain - not really Federal style - you should be fine with 1/16". On a side note, you don't happen to know EJ (Eric) Nodurft there in Wheeling, do you? Quote Link to comment Share on other sites More sharing options...
Hammer5573 Posted June 25, 2018 Author Report Share Posted June 25, 2018 ...response to Mick S What kind of composite material do you use? I laminate Masonite using Gorilla glue wrapped in waxed paper and placed in a mold. Very satisfied with the results "On a side note, you don't happen to know EJ (Eric) Nodurft there in Wheeling, do". Wheeling is a small town but I haven't had the pleasure of meeting him Quote Link to comment Share on other sites More sharing options...
wdwerker Posted June 25, 2018 Report Share Posted June 25, 2018 With a laminated composite core I agree with Mick, 1/16 is fine. Quote Link to comment Share on other sites More sharing options...
Ronn W Posted June 25, 2018 Report Share Posted June 25, 2018 Fro comparison......I am in the process of building a mate for a cherry federal end table that I have. I plane the draw to fit - about 1/32" clearance. First table was built last september and has still slides freely. I may be pushing my luck but so far so good. Quote Link to comment Share on other sites More sharing options...
