Hi everyone..  New to this forum!
I'm a semi-experienced amateur woodworker, mostly limited by time and workspace.  I built a nice desk for my daughter a few years ago, forcing myself to learn some new joinery techniques.  Now it's time to finally build a couple built-in bookshelves that will flank our fireplace.  I've spent a long time getting the design drawn up.
I have a lovely Grizzly 0715P that has been serving me well.  I replaced the stock blade with a Freud Premier Fusion after I purchased the saw.  Rip and crosscuts are beautiful, but I did find that the 2 1/4 HP is a bit light for the full-kerf blade.  The new bookshelves will be made from sapele since the old fireplace mantel was mahogany.  This will be my first experience with gluing up boards from lumber.  Since I don't have the space for a jointer, I'm hoping my table saw (with a jig) will suffice.  So here's my question:
Should I purchase a new Thin Kerf Premier Fusion or try the Freud Thin Kerf Glue Line blade?  The Fusion is a bit more expensive, but that's not a big concern.  Based on my full kerf blade, I can't imagine a better glue line, but I was hoping to get your input.   Obviously changing out blades is annoying, so if I the combo Fusion will be just as good, I'll go with that.
Thanks very much!
I have the full kerf Glue Line Rip blade and it is great (just remember that it doesn't leave a flat cut, so it isn't good for box joints or splines).
I just have a little jobsite saw and the full kerf GLR blade cuts easier than the Freud Diablo 40t thin kerf combo blade I have. Changing blades on my saw is a pain, but I still prefer to do that over using my combo blade on everything.
Welcome the the forums Doc.
I use Feud Rip and Cross Cut full kerf blades and I have less hp then you do and the only thing that slows me down some is something like 8/4 maple.  I think some thing that really helps is cleaning the blades regularly.
I am a little hesitant about thin kerf because of the potential for deflection.
JohnG and Chet, thanks for the comments!  The sapele is harder than any other wood I've cut, although most of my projects have involved 3/4" plywood.  I think I'll give the Fusion a try and see how it goes.  If I have to switch to a thin kerf, I'll also need a new riving knife which adds another $50.
I was already thinking about cleaning that blade, so thanks for the reminder!
Thanks, wtn
Definitely need to learn about using a hand plane.  Zero experience with them and I have a hard time even fathoming how to make a long flat surface with a hand tool!  (But I realize that's just my inexperience)
3 minutes ago, IthacaDoc said:
Thanks, wtn
Trust MY experience - it is much easier to make a long, flat surface with a hand plane, than with an under-sized jointer...
  • Haha 1
  • Sad 1
I used to run thin kerf blades in my PM66 but SS recommends they be a certain thickness and the Freud blades are to thin so I sold them and bought full kerf versions. I use Freud blades almost exclusively (I have a few Forrest and a Forrest dado stack) and the glue line rip is a great blade.
  • Who's Online   1 Member, 0 Anonymous, 58 Guests (See full list)
    26,008
    Bob44
    Bob44
