Dennis-n Posted April 19, 2020 Report Posted April 19, 2020 (edited) I just changed out the rear roller on the 735. The sprocket broke and the roller end got damage so I ordered replacement roller and bearings. Replaced broken sprocket roller and bearing and then stated it up. The rollers seemed to to pull wood through unit and the cuter head did not engage(have the Byrd spiral head installed). Raised machine to full height to determine if rollers were turning along with cutter head all were working has anyone had this problem thanks for any assistance Edited April 24, 2020 by Dennis-n Update Quote
Dennis-n Posted April 24, 2020 Author Report Posted April 24, 2020 Update I verified that the rollers and head were spinning when machine was on. I removed the covers from the drive chains and they were running and turning the rollers under no load. Checked both speeds and the drive chains changed speed correctly. When I put a board into machine and slowly lowered the head the rollers stopped as verified by the drive chain also stopped. Cutter head was still running at speed. Anyone out there have any info I could try original problem was a sprocket broke and jammed up the rear roller that why it was replaced Quote
wtnhighlander Posted April 24, 2020 Report Posted April 24, 2020 Sprocket not affixed properly the shaft, missing a key or set screw? One motor drives it all, sounds like you definitely have a transmission problem. 1 Quote
Dennis-n Posted April 24, 2020 Author Report Posted April 24, 2020 I reset the sprocket on the roller shaft. Could it be a problem inside the gear box at the end of the cutter shaft? Quote
Tpt life Posted April 24, 2020 Report Posted April 24, 2020 1 hour ago, Dennis-n said: I reset the sprocket on the roller shaft. Could it be a problem inside the gear box at the end of the cutter shaft? Worth a look. Quote
wtnhighlander Posted April 25, 2020 Report Posted April 25, 2020 Be certain the the speed control lever is switched from one position to the other while the machine is running. I flipped mine with it off once, the cutter turned but the rollers did not. Maybe yours is not fully engaged? Quote
Dennis-n Posted April 25, 2020 Author Report Posted April 25, 2020 I checked and speed control lever is engaged. With the protective covers off under no load I can see chain drive move in both speeds. Under load with a board the rollers stop and the main cutter continues to rotate Quote
Larry Moore Posted April 25, 2020 Report Posted April 25, 2020 It sounds like you have a key that is not in place. Under no load there could be enough friction to turn the rollers but they slip with a load on them Quote
Dennis-n Posted April 25, 2020 Author Report Posted April 25, 2020 Thanks I’ll go check. The two rollers front and back have sprockets with imbedded keys. Verified all the sprockets on the end of rollers and all are intact Only thing left is the gear box. I’m going to open up and check the gears in it for signs of wear. Will update later today with findings. Thanks Quote
Coop Posted April 25, 2020 Report Posted April 25, 2020 4 hours ago, Larry Moore said: It sounds like you have a key that is not in place. Under no load there could be enough friction to turn the rollers but they slip with a load on them My brother had the same problem and the key was the resolve. Quote
Popular Post Dennis-n Posted April 25, 2020 Author Popular Post Report Posted April 25, 2020 After taking the chain off on gear box side and removed the sprocketsthe drive sprocket had a broken key. Every time I checked the key was always in place and appeared to be intact. After changing out the sprocket and put everything back together I test ran a piece of popular and it ran like a champ. Lesson learned need to remove sprockets to verify the key in intact. Thanks for the input,I’m backup and running dennis 6 Quote
treeslayer Posted April 25, 2020 Report Posted April 25, 2020 Glad to hear you’re back up and running Dennis Quote
Dennis-n Posted April 25, 2020 Author Report Posted April 25, 2020 Thanks. On a side note after I had to replace the rear roller, the brackets to get to the roller are 5mmx10mm 80 pitch Phillips head screws. They were very prone to stripping out. I replaced all of them with hex head cap screws. They are easier to install and easier to take out. dennis 2 Quote
