Kevorobtz Posted August 22, 2023 Report Share Posted August 22, 2023 Hi, We have some leftover lumber that has been stained with Cabot's solid stain - oil based. Can I paint over that w/ latex paint or do I need a primer first, or is it even possible? The stain has been on for a little over a year now. Thanks! Quote Link to comment Share on other sites More sharing options...
BillyJack Posted August 22, 2023 Report Share Posted August 22, 2023 Contact the manufacturer.. Gotta watch the guesses.. https://www.google.com/url?sa=i&url=https%3A%2F%2Fwww.ispot.tv%2Fad%2F1wfA%2F4imprint-parachute&psig=AOvVaw0-ptWwvPxt8fgYltfe-8e9&ust=1692804411176000&source=images&cd=vfe&opi=89978449&ved=0CA8QjhxqFwoTCMDRnoHK8IADFQAAAAAdAAAAABAD Quote Link to comment Share on other sites More sharing options...
Ronn W Posted August 23, 2023 Report Share Posted August 23, 2023 I agree - contact manufacturer. Also ask them if a coat of shellac over the stain would work. I would be tempted to try that on a scrap piece. Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted August 23, 2023 Report Share Posted August 23, 2023 Agreewith both of the above, and suspect a primer will be recommended. Quote Link to comment Share on other sites More sharing options...
pkinneb Posted August 23, 2023 Report Share Posted August 23, 2023 On 8/22/2023 at 7:23 PM, Ronn W said: ... I would be tempted to try that on a scrap piece. Great advice! Always a good idea to do a test run Quote Link to comment Share on other sites More sharing options...
jbmektx Posted August 24, 2023 Report Share Posted August 24, 2023 A year is not long enough. Exposed to the elements / outdoors 3+ years or beyond stated warranty -- usually 3 years horiz -- 5 years vert. a top quality latex primer will most likely work. Gotta prime anyway -- use Zinnser Cover Stain oil based primer. Lower cost that shellac and better surface build up. https://paintsgeek.com/can-you-put-latex-stain-over-oil-stain/ 1 Quote Link to comment Share on other sites More sharing options...
