TomInNC Posted August 29, 2023 Report Share Posted August 29, 2023 I am planning on making shaker-style drawer fronts for some drawers. My initial plan was to use 1/4 ply for the panel. I assume that the 1/4 ply isn't enough material to actually hold screw for attaching to the drawer. How do people usually handle this issue? I guess I could size the stiles and rails on the drawer so that there would be enough overlap between the front and the box to attach to the stile. I am concerned this might make the drawer front proportions look odd. Any thoughts or suggestions are appreciated. Quote Link to comment Share on other sites More sharing options...
BillyJack Posted August 29, 2023 Report Share Posted August 29, 2023 Depends on how you design the face and the box. You want enough beef from the drawer frame to be fastened to tye drawer box. Some will insert the 1/4 panel and then put a filler between the 1/4 panel and the drawer box and use the drawer handle to fasten to the drawer .. Quote Link to comment Share on other sites More sharing options...
BillyJack Posted August 29, 2023 Report Share Posted August 29, 2023 Here is the card drawer from my bar 1 Quote Link to comment Share on other sites More sharing options...
Chestnut Posted August 29, 2023 Report Share Posted August 29, 2023 The face of the drawer is either false, or you could make the panel a raised panel with the raised portion going to the inside of the drawer. In the false front you make the drawer face and then attach it to a completed drawer box. You'd want to provide a spacer of some sort to go between the drawer box and the panel on the false front. Honestly I solve this the easy way. Shaker drawers are a slab front and I don't typically design larger drawers. If i do taller drawers for a hull height bank i put a door on and have pull out trays. 1 Quote Link to comment Share on other sites More sharing options...
BillyJack Posted August 29, 2023 Report Share Posted August 29, 2023 On 8/29/2023 at 12:38 PM, Chestnut said: The face of the drawer is either false, or you could make the panel a raised panel with the raised portion going to the inside of the drawer. In the false front you make the drawer face and then attach it to a completed drawer box. You'd want to provide a spacer of some sort to go between the drawer box and the panel on the false front. Honestly I solve this the easy way. Shaker drawers are a slab front and I don't typically design larger drawers. If i do taller drawers for a hull height bank i put a door on and have pull out trays. If i do taller drawers for a hull height bank i put a door on and have pull out trays. That would be considered a roll out Quote Link to comment Share on other sites More sharing options...
pkinneb Posted August 29, 2023 Report Share Posted August 29, 2023 Tom I did mine as you described for my basement bar here are a couple pics. 1 Quote Link to comment Share on other sites More sharing options...
Tom King Posted August 29, 2023 Report Share Posted August 29, 2023 Rabbet in groove to make back flush with enough thickness of the plywood for screws. Two screws in over sized holes in drawer box until alignment is perfect, then more screws in to lock permanently in place. 1 Quote Link to comment Share on other sites More sharing options...
TomInNC Posted August 30, 2023 Author Report Share Posted August 30, 2023 Thanks guys. Helpful as always. Pkinneb and BillyJack, are the screws on your drawers going into the panels or the rails? I was having trouble figuring that out from the pictures. Quote Link to comment Share on other sites More sharing options...
pkinneb Posted August 30, 2023 Report Share Posted August 30, 2023 On 8/29/2023 at 8:37 PM, TomInNC said: Thanks guys. Helpful as always. Pkinneb and BillyJack, are the screws on your drawers going into the panels or the rails? I was having trouble figuring that out from the pictures. In my case both. Here is a better pic the outer two are into the face frame the center two are the drawer handle. 1 Quote Link to comment Share on other sites More sharing options...
BillyJack Posted August 30, 2023 Report Share Posted August 30, 2023 The drawer screw goes in the 1/4 panel. Why you need a filler to draw it tight. 1 Quote Link to comment Share on other sites More sharing options...
