Popular Post gee-dub Posted November 15, 2024 Popular Post Report Posted November 15, 2024 This may be a tip or just dumb. I have a fair amount of things to make things sharp. I hand sharpen, guide sharpen, and power sharpen. I have holders for small or short irons but find these Kell guides handle some of those odd sized irons well. I am not the most highly skilled hand tool worker so I use this trick when setting the iron in this little Millers Falls 33. I stick a couple pieces of tape that are about the depth I am looking for ahead of and behind the blade. I set the plane on a reference surface and extend the blade till I make firm but gentle contact and tighten the lever cap. In this case I am easing edges pretty significantly so masking tape is about right. This gives me shaving like so when easing an edge. Like I said . . . may be a tip or may just be dumb . 7 1 Quote
Ron Swanson Jr. Posted November 27, 2024 Report Posted November 27, 2024 @gee-dub I don't know that I've ever seen anything dumb come out of your camp. This is an interesting technique and not something i would not have stumbled onto any time soon. So no. Definitely NOT dumb!!! 2 Quote
Coop Posted November 28, 2024 Report Posted November 28, 2024 Great Tip! Only thing simpler would be for us to send our blades to you for sharpening! 2 Quote
derekcohen Posted December 14, 2024 Report Posted December 14, 2024 Let's assume that the bed angle is 45 degrees. If you sharpen like this, you achieve a blade with a 45 degree bevel. Not good. Further, sharpening the angle flush with the surface leaves a zero relief angle. The plane will either not cut at all, or stop cutting after a few shavings. Regards from Perth Derek Quote
gee-dub Posted December 14, 2024 Author Report Posted December 14, 2024 I hear what you are saying Derek. Yet that is how they were produced from 1929 through 1964. Completely non-adjustable other than blade protrusion. One catalog reproduction I have seen states a bedding angle of 20 degrees but it is more like 45 and stated as such in other document reproductions . Obviously not a plane for any serious stock removal. I believe the target was pattern and model makers. Pretty light use. The bevel down iron is sharpened at ~30 degrees for my use. Quote
Tom King Posted December 14, 2024 Report Posted December 14, 2024 The tape is just for setting iron protrusion, not sharpening. I've never owned a plane without some sort of iron adjustment for that, whether with a hammer like for molding planes, or adjusters, so can offer no better advice. 1 Quote
