I want to start buying handsaws and I've been learning a bit about the subject but I feel like I need a little more help. Since I want to work purely by hand, I feel the need to cut rough planks by hand, so I need a couple of big handsaws (rip and crosscut) and a couple of panelsaws. The thickness of the planks I'll be working with can vary widely, between 25-60mm, but normally around 40-50mm. How does the tooth count of the saw affect cutting different thicknesses? Looking at old saws, I've found a large rip handsaw W.Tyzack & Sons that's 77cm long with 3 1/2 tpi and another similar Disston Canada with 6 tpi. Would that be a good choice to cover my rough rip cutting range? What tpi should I look for in a rough crosscut saw?
As for panel saws, I understand that the tooth count should be higher to make clean cuts cutting near the waste line. The thickness of the boards I'll be working with like that will probably be between 10-30mm frequently. I think here cutting clean is more important than fast.
I'd like to have a small chart of what I should look for in each saw so I can buy as I find good opportunities.
I use Sandvik (sp?) Fully pleased with saws that are at least as old as I am.
Tooth size that makes for “gullet” depth help clear in thick cuts. Rake and and tooth set matter a little more for different purposes, and tooth count is more about aggression or speed of cut in my experience.
So first, a slight correction on your terminology. These are panel saws:
Smaller saws like this below (tenon, carcase, dovetail, etc.) are typically called back saws, because they have a stiff back.
Usually, for panel saws, you'll see a much smaller toothcount for rip saws and a higher tooth count for cross cut. The teeth will also be profiled, set and sharpened differently for rip v. Crosscut.
As a rule of thumb, i was taught that you want a minimum of 4 teeth across the thickness of your workpiece.
I don't personally find that i need a huge number of saws. I do most of what i do with 2 panel saws, a carcase saw (which is my bellcow) and a dovetail saw. I do have a few larger tenon saws, but i don't use them nearly as much. So i guess that's where I'd start off if i were in your shoes,
2 panel saws, a small backsaw (dovetail) for small work and a medium carcase or tenon saw for most of everything else. From that base you can let your work tell you if you need anything more.
Hope this helps.
Lower TPI cuts faster for thick stock, higher TPI gives you more control and a cleaner cut on thinner stuff. For your 40–50mm boards, 3.5–6 TPI rip saws are a solid combo, around 7–9 TPI works well for rough crosscuts, and for panel work (10–30mm) look more in the 10–14 TPI range so you can stay close to your line without tearing things up.
