The 240V model would be advantageous if it was a long run to the panel. I have a 120V, 1.5HP DP and it has never lacked for power and has never tripped the breaker.
  • Thanks 1
It's been a long time since my college electrical engineering power distribution class, but my recollection is basically high voltage means lower amps, which is advantageous as that means less load on the wiring, mainly in large-scale power distribution, and also, as drzaius points out, even over a long run in the shop.
Since higher voltage tends to mean commercial, I suspect they will often build in more power but that's not a direct result of the higher voltage.  (Perhaps easier to achieve with higher voltage?)
Three-phase has a similar benefit, if you get things tuned right (capacitance vs inductance), you can really cut the amps flowing over the transition line. You will find cases where capacitance or inductance has been added outside a building to help balance the load.
  • Thanks 1
Is the motor the same size, or is the 220v larger?
The only reason I can think of in WW is if you're running massive bits and like boring out logs or something.
For furniture and the vast majority of what we do, 120v is plenty enough.
  • Thanks 1
@pkinneb, are you looking at a traditional drill press, or are you considering Laguna's new digital/electronic DP?  I have the Nova Voyager and I really like the electronic features, particularly the depth control.  I'm not sure how the two compare.
Digital version.
  • Who's Online   1 Member, 0 Anonymous, 57 Guests (See full list)
    32k
    437.5k
    26,007
    FurniCore
    FurniCore
