more tung oil questions
I am still wanting to try this finish on a walnut top. I am unsure about a few things still:
1 Should I use polymerized tung oil?
2 Should I use 100% pure tung oil?
3 Should I use 100% pure tung oil blended 1:1 with citrus solvent?
I am not really in a rush, and if it takes overnight for a single coat of undiluted tung oil to dry, so be it. It is important that the finish be food safe.
Citrus solvent is almost as expensive as the tung oil. If it is only a drier, and makes the process only marginally easier, then I may skip it. If the solvent makes a difference in application (better performance means better results) then I am all for it!
Anyone care to share?
where do you find the citrus solvent i havent been able to find it?
Pug,
I love the polymerized tung oil. When I talked to Sutherland Welles about using the standard PTO on the Gretchin's Cradle, I was advised that after it's cured, it is safe. You probably wouldn't want to eat it, but... They also have the low VOC Citrus formula that I have not tried, but I do really love the ease of application, the close to wood finish and durability of the product I used. It still looks great.
http://www.sutherlandwelles.com/
I urge you to fully explore the site. It does a very good job of addressing many misconceptions.
  • 1 month later...
If time is not an issue but food safe is, I would use pure tung oil. Citrus oils in my opinion are primarily intended to have a temporary olfactory effect. Pure tung oil is intended for food contact products as they contain no chemical dryers or solvents. Relative to polymerized tung oil, you can however save a bit of money by using the pure tung oil and adding sovents and dryers yourself as polymerized tung oil is much pricier. Linseed oil is much cheaper and just as food safe if the "raw" variety is chosen. If you are concerned about the hardwarestore variety, you can get flaxseed oil from a hippy store. Same animal. Or you can get organicaly produced and highly fined linseed from Allback paints. http://www.solventfreepaint.ca/cleaned_linseed_oil.htm
Of course, using any oil lacking chemical dryers can be dodgy. One foodsafe option is to use a paste wax. I use Claphams " salad bowl finish" on anything that is food related or "hot cup of tea weilded by wife oblivious to water stain suseptable surfaces" which in my house is anything horizontal. Not much for a high gloss but it has never cause any waterstains to date. Also, Roger Clapham is a friend of mine. James Krenov and the Smithsonian helped him develop his furniture polishes so the guy has got his ducks in a row.
I assume you were looking at the offerings from Lee Valley Tools.
I have used the stuff from real milk paints company (no citrus solvent) and love the product. I did a walnut kitchen table with it and couldent be happier. It's been a year now and I cant say anything bad. Just my 2 cents.
I have also used the 100% pure Tung oil from Milk paint dot com. From what I understand it is food-safe, (from a nut) which is why I chose it.
I used it to finish an antique butcher block and several cutting boards. They have held up really well even with lots of use. The cutting boards need to be recoated from time to time. The butcher block took several weeks to do, but I haven't had to re-coat it since, (it is used as a counter not for cutting). I did several thin layers, wipe-on thick & wipe-off excess after several hours. I found that a hair dryer sped up the absorbtion process by making the oil thinner.
If time is not an issue but food safe is, I would use pure tung oil. Citrus oils in my opinion are primarily intended to have a temporary olfactory effect. Pure tung oil is intended for food contact products as they contain no chemical dryers or solvents. Relative to polymerized tung oil, you can however save a bit of money by using the pure tung oil and adding sovents and dryers yourself as polymerized tung oil is much pricier. Linseed oil is much cheaper and just as food safe if the "raw" variety is chosen. If you are concerned about the hardwarestore variety, you can get flaxseed oil from a hippy store. Same animal. Or you can get organicaly produced and highly fined linseed from Allback paints. http://www.solventfr...linseed_oil.htm
I was considering using the Clapham product - thanks for the endorsement.
For what it's worth, I second Clapham. I've used it on almost all of the stuff I make for home and really like it (specifically darker woods or anything that comes in direct contact with food or my little girl..) A little bit goes a long way :-)
My other 'go to' is Crystalac (water based stuff that is certified safe for toys, etc) but it lacks the ability to bring out the richness in darker woods. The finish is tough as nails and works great for light colored woods (maple, white birch, pine, etc) as it doesn't yellow; but not my choice for dark stuff...
I think the wax blend would make the walnut look awesome.. Speaking of this, I just remembered that I'm out :angry: Need to order more...
  • 26,009 Total Members
  • Joseph b Newest Member ·
