TRBaker Posted September 3, 2012 Report Posted September 3, 2012 I'm kind of proud of this one. I had to make a set of bannisters for thes brick steps and the boss said, "Here" and handed me a hand-drawn sketch of what he wanted. I scratched my head for a while and then went to work. The newel posts are tapered, with square bases so that when the caps were added they would look like lighthouses. Each run had five 1-1/2" square tubes epoxied into the brick steps for anchor posts and I had to lay out the spindles so they all lined up. Tell me what you think of the finished product. 1 Quote
Pbmaster11 Posted September 3, 2012 Report Posted September 3, 2012 How does one construct these? always interested! finished product looks great! Quote
TRBaker Posted September 3, 2012 Author Report Posted September 3, 2012 First you have to buy every clamp in the world and then start gluing up strips, in place. I then disassembled the parts for machining. There might be a better way of doing it, but it was my first time and it seemed the way to go for me. I sent the top rail back to the shop for machining because we didn't have a shaper on the job site. I tapered the posts on the jointer, they were hollow, and then split them to put them around the steel anchor posts at each end. Quote
Beechwood Chip Posted September 3, 2012 Report Posted September 3, 2012 Did you steam the strips on site before bending, gluing, and clamping? Quote
duckkisser Posted September 3, 2012 Report Posted September 3, 2012 i'm guessing you did a dry bend rather then steaming a larger piece of wood and manually bending it. but this is impressive for a first try. Quote
TRBaker Posted September 3, 2012 Author Report Posted September 3, 2012 I didn't use any steam on this project. All the pieces were glued up in 1/4" to 3/8" strips, glued and clamped, one layer at a time. I used Titebond III as the glue of choice. Once the outside portion was completed, I installed the spindles, and then constructed the inside radiuses. Quote
lawrence Posted September 4, 2012 Report Posted September 4, 2012 wow, that is beautiful and exacting work- Great job! Lawrence Quote
Indy Cindy Posted September 4, 2012 Report Posted September 4, 2012 Gorgeous! I'll bet you will be getting requests for more of those. Quote
fransikaner Posted September 4, 2012 Report Posted September 4, 2012 Well done. Thanks for sharing and inspiring! Quote
JerrySats Posted September 4, 2012 Report Posted September 4, 2012 Nice job it came out great , looks very classy . Quote
chicks82 Posted September 9, 2012 Report Posted September 9, 2012 TRBaker, Great job. I would have done it the same way you did. I would have build forms and then bent the strips to the forms. The only way you get around using a million clamps is by building a set of forms an inside and outside form and use good high quality ratchet straps. Still end up using other clamps just cuts down the amount Again amazing job looks awesome would have loved to worked on that with ya. Quote
Ironman50 Posted November 1, 2012 Report Posted November 1, 2012 Oh, that must be the stairways to heaven ... Beautiful! Quote
TRBaker Posted November 2, 2012 Author Report Posted November 2, 2012 Thanks for the kudos, y'all. Quote
