I've never used or in my opinion needed them. I've been using my 16-32 for years without it and have never had an issue; even when running longer stock for tall face frames etc. The 22-44 that I worked with back in the cabinet shop days didn't have them either and we never had a problem. I think it all comes down to how you use the machine. If you pay attention to your loading and unloading of the stock off the feed belt you'll be fine.
For me the extra bit of attention needed to keep pieces flat as they enter and exit the drum is not worth the extra costs of the tables...let alone the hassle of having to make sure they're always coplaner with the feed belt.
I don't have them on my Delta but I do use indeed/out feed rollers. If I have a single long board, I will just use the out feed roller stand. If I have several long boards, I use both indeed and out feed roller stands. That just makes it easier for me to cycle the stock for the next pass.
BRuce
I have the 16-32, not for much time, but never saw the need for the in/out tables.  Longest board i put thru was 6 feet, and just put a roller on the outfeed side like Bruce said.
Also, I've never gotten even the smallest amount of snipe.  i wonder if that is normal?  Definitely so much better than a planer.  Always wondered why..
I run some pretty long stock from time to time . I have the Peformax 16/32 and the infeed/ out feed tables. For really fine sanding run short boards one right after the other to prevent any snipe. The infeed table lets you stage the next board behind the one being sanded. The outfeed table supports the piece untill you can grab it.
I like the in/outfeed tables for my Delta. I picked them up off a forum from a guy selling. Yep I'm with Steve, when your running lots of smaller stuff in rapid fire, like re-sawn drawer parts. Its nice having those come off the back to the outfeed and not onto the floor. They are nice. Otherwise, you have to baby sit one board at a time. Thats just me :)
I don't use my drum-sander for long boards, so cant speak to that.
-Ace-
I have the Performax 22/44 with the tables.  Like Steve said they are great for running lots of material one after another, which I do a lot of.  They do provide good support, but nothing you couldn't do with some roller stands.  The tables are nice to have.
They have gotten quite expensive.  I don't remember them being that expensive, but I bought mine at the same time as the sander which I think was a package.  I've had mine since around '05, so I'm sure they charge a lot more now.  It's now a Jet model.
I have a wide-belt, not a drum sander, but the principal is the same...  I use the extension tables when working with strips of veneer, inlay, etc -- i.e., stock that will bend sharply under it's own weight...  Doors, face frames, 4/4 stock, etc don't need the extensions -- assuming the stock is already planed and will move through the sander easily...
  • Who's Online   1 Member, 0 Anonymous, 43 Guests (See full list)
