Hanging System
In my shop, I am in the basement. The walls are made of cinder blocks, and the 2x12 floor joists are exposed. I want to have a method of hanging stuff on the walls, but I do not want to continuously drill holes in the cinderblock foundation. It is covered in the "moisture resistant" paint product, and I would really like to keep that intact because the room have no leaking issues.
My thought is to take some 1x2 strapping and hang it from the joists so the boards are laying the "flat" way against the wall. Then, I would take some hardboard or 1/4" plywood and attach it to those.
I don't plan to cover the entire basement walls with this, just in a few spots where I would like to have some storage.
Any thoughts or suggestions on this?
I would frame up the wall with 2x4s. Glue the bottom plate to the floor and nail/ screw the top plate to the rafters. This will also give you a place to put more outlets :)
To be honest, that was something I was looking to in the future. But for now, I wanted something more intermediate.
The room isn't completely mine, yet. There is still a lot of clutter in one portion of it, and that is the portion I would most like to have some wall storage. Also, as the budget remains ultra tight, I would rather stay a little cheaper on the storage part and use the money to spend on some tools. I still need to purchase my CT MIDI, a router, the bits to accompany it, kreg jig, assortments of screws, abrasives for my ETS 150/5, and the list goes on. When this semester of school is over, I am going to work as many overtime opportunities as possible to put some money aside.
The only thing I would add to Mr T comment is to use treated 2x4's for the bottom of the frame up.
2x4's are will probably be the cheapest way to go. for an 8ft section of wall all you would need is 8- 2x4x8 at about $4-5 a board your only looking at around $40 plus some nails. you can always cover it and or wire it later, but at least you will have some studs to hang things from.
Frame ups can happen one stick at a time. A treated 2x4 sill on the floor, even just a four foot length, and a top plate with a stud or two can easily be added to in the future. Especially since this is your long range goal I would consider an option like this. If you screw things together you can pull it apart and glue the bottom later if you are nervous about getting too far ahead of things.
I never thought of it that way. Looks like I have something to strive for.
For the wall material, what would you recommend? I'm not looking for sound barrier or insulation, just something to hold stuff up.
If you hung a strip from the joists that was ripped to a 45 degree angle on top you could hang pegboard panels, wall cabinets or whatever with French cleats.
Another good idea.
I'm in the exact same boat you are. I can't afford to do everything, but I need to accomplish a certain amount of furring out some walls so I can run more power and a 220 line.
There are about 10 thousand reasons why framing up a wall is the best way to go. I recommend that. As pointed out, the benefit for your situation is that you only have to build as much as you can afford. I'm actually doing just that.
Be sure to take some time to think about the big picture, and then just build out in small chunks.
Now, I say that, but I let myself get caught up in it a bit. I started with a short run on one wall and now I'm up to 4 walls. However, the small extra cost actually gained me a ton of solutions. Hopefully, in a few months, I can move on to some doors and maybe even sheetrock. But for now, in  few weekends of work, I'll have massive upgrades to my shop for fairly little cost and effort.
Just to add to some of the recommendations   See your local building code.  You will likely need all treated lumber or a vapor barrier.
Treated lumber is typically needed for any wood that touches concrete.  This includes the studs that will touch the block wall.  Unless you are putting up a vapor barrier, be sure all lumber is treated.  Also, treated for basement use is different than treated for outside use.  (You want the blue ones)
I agree with the others though, Studs are the best solution, and in most cases the most economic too.  If  you are just getting started, consider hanging a sheet of peg board somewhere.  It's very flexible, and relatively inexpensive.
I framed some of the walls in my basement shop. I used a PT lumber sil plate on the concrete floor as well as a foam sil gasket. If you keep the studs away from the wall (around 1/2" works well to account for wall unevenness), then you won't have to use PT studs. All nails and hardware touching PT lumber should be galvanized or otherwise coated for corrosion resistance, as the chemicals in PT lumber will help corrode uncoated metal quickly.
If you have room and a fairly level floor, build the walls on the floor and raise them up. I built my walls 1/4" short, and then shimmed the top plate where it was attached to the joists above. I did this with just a framing hammer. For stick building one stud at a time, use a framing nailer unless you really want to delve into the art of toenailing manually. I tried that, but it's really not very fun. :)
If you use concrete screws they're easy to pull out later as opposed to a .22 actuated nailer or other similar, more permanent method.
Tapcons are blue screws and sometimes come with the correctly sized drill bit.
A rotary hammer is not essential, I'd use a corded drill at a minimum.
It's usually recommended to secure a bottom plate every 2 ft., so you'd only have to drill two holes.
I have an unfinished shop basement and couldnt frame it in as id lose to much space and its a rental, mostly cause its a rental cause theres tricks you can do to help with the framing, but i digress.  What i did do is two things.  i made a  frame from 1x2 and and covered it with tempered pegboard.  leaned that up against the wall at an angle and cut 2 wedged blocks with a small groove across them and slid those in underneath the bottom 1x2 so that gave me a sturdy more even surface on my unlevel basement floot and it kept it from getting wet since my basment leaks.  i built another one and put the frame up flush against one exterior wall and used some beefy screws with a very large fender washer to go through the top rail of the frame and into each floorjoist that it touched i then put the pre-cut to sized pegboard on it securing it to the 1x2 frame.  both turned out very well the stand up one is easily movable and definately nothing permanet but works fine, i have all my clamps on it.  the other ones while more permanant isnt that permanant since youd only have to remove the tools and the pegboard to undo the screws with the washers.  i was really suprised at how sturdy they both turned out.   i managed to have almost everything i need to hang on those two surfaces. good luck.
Nyles
