Nick2cd Posted May 24, 2013 Report Posted May 24, 2013 I know this is a rookie question, but I am a hand tool greenhorn. I just got a Stanley block plane to play with and I'm wondering if I'm supposed to loosen the lever cap (?) before I advance or laterally adjust the blade. Quote
wilburpan Posted May 24, 2013 Report Posted May 24, 2013 You should be able to adjust the screw that holds the lever cap to a point where the blade won't move as you use the plane, but will still move as you adjust the position of the blade.If you can't find that spot, err on the side of being tight (i.e., needing to loosen the cap to adjust blade position). Quote
Nick2cd Posted May 24, 2013 Author Report Posted May 24, 2013 Graham, this is the plane i bought. i tried to find a classic on ebay but could never seem to pull the trigger. i figured this would be a good plane on which to get started. i won't be fearful of lapping the sole or de-burring other parts like i would be on a plane that cost 3x the price (of course these operations probably wouldn't be necessary on a higher end plane). regardless, i just wanted something to get my feet wet. i know it's not a LN or Veritas. just something to get my foot in the door. honestly, im impressed with it so far. adjustments seem to be easy and solid. Quote
Nick2cd Posted May 24, 2013 Author Report Posted May 24, 2013 Thanks Wilbur! i can get it to that point where it's adjustable, yet tight enough to use.....i just wanted to make sure it's ok to do this. something inside me keeps telling me not to adjust it against tension, but it seems like it's the best way to make precise adjustments. just don't want to develop bad habits that will hurt better planes in the future. Quote
Nick2cd Posted May 24, 2013 Author Report Posted May 24, 2013 Hi Nick, couldn't see the linK sorry Graham. this should fix it http://www.leevalley.com/US/wood/page.aspx?p=41227&cat=1,230,41182,41188 Quote
G S Haydon Posted May 25, 2013 Report Posted May 25, 2013 Thanks Nick, To echo what wilbur says this type of block plane is very similar to a bailey plane in how you can adjust the with the lever cap under tension. FWIW that's a decent block plane which should be adequate for nearly all tasks. I have just finished refurbishing one of these which is a very basic type. Time will tell if it's adequate for what I want but it only cost about £7.00 Quote
Stephen Prunier Posted May 25, 2013 Report Posted May 25, 2013 I know this is a rookie question, but I am a hand tool greenhorn. I just got a Stanley block plane to play with and I'm wondering if I'm supposed to loosen the lever cap (?) before I advance or laterally adjust the blade. Nick, I own and use that plane almost every day. You don't have to loosen the cap before adjusting the blade. However, finding the sweet spot can be frustrating. I find that I keep the blade pretty much in the same spot, and just tweak it a hair as needed. Remember that, after backing off the blade to snug it up again. Otherwise the blade will continue to back off. That plane is a real work horse. Just take a little time and take it apart. Check for any rough spots and file them. The sole and sides should already be pretty flat and square. I've had mine for over 10 years and I've dropped it off of roofs from 30 feet and it looks almost as good as the day I bought it! I do plan to install a new blade soon from L.N. or Hock soon. Enjoy it ! Quote
Nick2cd Posted May 25, 2013 Author Report Posted May 25, 2013 thanks guys! this is exactly what i was hoping to hear. i can see this plane being a spring board into more planes. bench planes are next on my list. Stephen, how well does the stock blade hold an edge? Quote
Stephen Prunier Posted May 25, 2013 Report Posted May 25, 2013 The stock blade on mine has served me very well. I make sure the back is flat when I sharpen it. It can make shavings that you can see through Quote
nateswoodworks Posted May 26, 2013 Report Posted May 26, 2013 When I was just starting to play around with hand tools I had that plane, granted that was over ten years ago but I doubt much has changed. I have never had to loosen the lever cap on any plane I have had with the exception of Sargent with a knuckle cap. It is a nice plane to get you started and if I hadn't been given an old 60 1/2 that was my wifes Grandfathers I would still probably have mine but instead I gave it to a to a friend who still uses it today. Enjoy! Quote
Tpt life Posted May 26, 2013 Report Posted May 26, 2013 Check your setup. My plane of this style is a Stanley. The iron has slots milled into the bottom across 1/2 inch of the center. These slots line up with the adjustment mechanism. The lever cap only needs to be tight enough to keep the adjustment faces engaged and at that point the blade will not move during use. Quote
