Flooring/Finishing help
I have a piece of white oak I'm using on a landing that goes from a hallway to my living room.  It's going to have a lot of traffic.  Kids, dogs, rain, dirt, etc.  So my question is what should I use to finish it.  It has to be stained to match the hardwood that's in the hall and living room.
Hey Big. Welcome to the forum. I think you'll find that the finish of choice, for most flooring guys, is polyurethane. They use stuff that is designed for floors, not furniture or trim.
I made a few transition strips for my home, and finished them with tremclad clear from an aerosol can. Works great! Very durable and nice satin finish.
I've used aerosol finishes for small items, but they don't have the solids content needed for something like a stair landing.
Hi,
Can you clarify what sort of "piece" of white oak you're referring to? I doesn't sound as though you're referring to an entire landing; do you mean some sort of trim piece or transition strip?
In general, TrBaker is correct, the vast majority of hardwood floor finishes are poly-based. But there are significant differences between water-borne and oil-based finishes. Most oil-based (sometimes called "Swedish") finishes are two-part and highly toxic; you shouldn't mess with these without some experience. Waterborne finishes are less harsh, generally one-part (sometimes with a separate sealer), and can be a bit unforgiving. In any case, professional finishes are pretty much only available to contractors.
I don't know of any aerosol products that would hold up to foot traffic.
More details about your project would certainly help us to give you more specific advice.
Ryan
True, I did not use it for a high traffic area. Not too many people walk on the transition strips.
Moisture Cure Urethane.  I'm not sure it's available in small quantities though, and has no shelf life once opened.  Floors I finished in the '80s with it still look good.
Synteko Swedish finish. Simply put its a conversion varnish for floors, I did my stairs with it years ago. Around here its very popular but might be tough to find in areas where VOC compliance is an issue.
I had my oak floors resanded and I went with a product called Bona traffic. 2 part water based stuff that so far has held up really well considering we have a dog. Dries to the touch in 30 min but full cure 3 days.
Thanks guys for the information.  Sorry for the sketchy info Atritinus.  This is a 4" wide strip 17' long(actually two pieces) and 7/8" thick.
I use last n last 1500 or bona traffic. Both water borne finishes. Lnl has a 15 yr warranty.i start with a ambering sealer.
Hi,
Judging by the info in this thread and your other thread in General forum, it sounds as though you're installing a nosing; is this correct? If so, I can offer more detailed advice.
Ryan
Atratinus, didn't know it was called a nosing but that's exactly what it is.  Any more info would be awesome.
Ok, that makes things clearer. If the nosing adjoins other hardwood flooring, you'll want to try to match the existing finish. Most flooring finishes are only available to pros; you may just have to match the carrier--oil-based poly or waterborne.
As for the installation, you don't need any special hardware or joinery for end-to-end joints; it's up to the subfloor to keep the individual pieces level (shimming may be necessary). If you need to join two pieces for a long run, use a scarph joint. Use construction adhesive and top nail the pieces to the subfloor. If you can use the tongue and groove with adjoining flooring, do so. Fill the nail holes and finish.
Hope this helps,
Ryan
For some applications of a high traffic nosing, i screw into the subfloor and plug with 3/8" plugs. You can buy or make your own. Be sure to orient ur plug grain to look as unnoticable as possible. This will be the strongest by far.
For smaller oak replacement parts, I'm a huge fan of Waterlox.   It was originally designed as a floor finish.   My entire home, except for one oak staircase, is finished with Gymseal, a no longer available tung-based Waterlox competitor designed as a professional gym floor finish.  The remaining staircase is Waterlox.   15 years of no special treatment, both products still look fantastic.  McCloskey's discontinued Gymseal, long before VOC laws took off, because the ingredients became too expensive.  It sold for $85-90/gal. in the late 90's.
The main advantage to newer commercial floor finishes is not higher durability than old pro finishes, but a durable finish that dries quickly and meets VOC rules.   The main disadvantage of the old school varnishes is far longer dry time and low VOC's, and a far higher cost than polyurethane, but in small scale applications, none of those has to be a problem.
As previously mentioned, the biggie is matching the existing finish, which Waterlox may not...    If it does, you can buy a quart and get a far superior floor finish than home center polyurethanes.
  • 26,009 Total Members
  • Joseph b Newest Member ·
