Tony Wilkins Posted October 26, 2013 Report Posted October 26, 2013 Working on my Moxon vise using Bench Crafted hardware and I ran into a problem when using my Brace and bit to do the holes: Here's the particulars:Wood: 8/4 walnutBit: vintage Irwin 3/4 (the spur and the ramp seem sharp)Brace #1: Bell System 8" sweep (used on the first hole)*Brace #2: Fray Spofford 12" sweep (used on second hole)The Problem: the bit goes about 1/2 way in and basically stops cutting. I've backed them out and cleaned out the hole but no joy.The question (at long last): How do I get all the way through? Did I do something wrong?The one idea I have is to get my hand drill out and go the rest of the way through with a bit smaller than the lead screw as to line up the holes and start in from the other side.TIA,Tony*if anyone wants to trade my 8" bell system for an 8" or 10" Spofford I'm open to doing so. Quote
Tpt life Posted October 26, 2013 Report Posted October 26, 2013 There are a couple videos around on sharpening bits. It was also pointed out to me recently that there are coarse and fine lead screws on these bits. I am not certain what tpi counts to look for in fine. Quote
Tony Wilkins Posted October 26, 2013 Author Report Posted October 26, 2013 Schwarz talks about that in the Anarchist Tool Chest. I'll have to look it up. Quote
baok Posted October 27, 2013 Report Posted October 27, 2013 I've had tag same problems before. In my case it was cherry. I tried two different auger bits each with different lead screw types and the lead screws would load up with crud and not pull any more. I had to pick the threads out with an awl. Both bits worked great on a piece of pine as well as oak. I still don't k ow what the issue was. I had to use a modern drill bit to get the holes done. Quote
G S Haydon Posted October 27, 2013 Report Posted October 27, 2013 I'm no expect on the brace a bit but it sounds like the lead screw thread is shearing in the wood, similar feeling to when the thread passes through the other side and stops pulling. I would just put my gut behind it a little harder to start it cutting again and use a bit more pressure in general. Quote
Tony Wilkins Posted October 28, 2013 Author Report Posted October 28, 2013 Figured out that the lead screws are the coarse ones for soft wood and not the hardwood variety. Thought they were supposed to work but guess not. Found a bit of a solution. Put it down on my workmate where I could push down and finally bullied my way though one hole. 1 Quote
Ozwald Posted October 28, 2013 Report Posted October 28, 2013 When at first you don't succeed, get a bigger hammer. Quote
RenaissanceWW Posted October 30, 2013 Report Posted October 30, 2013 Basically you have stripped the threads in the hole. As mentioned above push harder and it will re-engage. Alternatively, rock the brace from side to side a bit while turning and you and usually get the threads to grab again. Usually this happens by trying to go too fast with a coarser thread or by wobbling from side to side too much while you are boring. Try placing your forehead on the pad to keep it square but also as a way to control the side to side wobble that comes when you rotate the brace. This is common when using the larger sweeps. Quote
jhl.verona Posted October 30, 2013 Report Posted October 30, 2013 ... Try placing your forehead on the pad to keep it square but also as a way to control the side to side wobble that comes when you rotate the brace... I was looking for a photograph showing this, and came across this interesting tutorial. In this position you can add pressure with your arm and hand, if necessary. I don't know what it is, but whenever I see a photo of this stance, I always imagine a little thought bubble and the mantra 'I will drill this one square to the face...'. John 2 Quote
G S Haydon Posted October 30, 2013 Report Posted October 30, 2013 Tony, I was boring some holes whist making my face vice tonight and even by pushing harder I could not get it going again (into a bit of rough euro oak). I took out the auger and noticed the lead screw was packed tight with swarf. I had to clear it with a bradl and go again, and it jammed again, same issue. I think this is the first time I can recall it happening (my holes in the softwood bench apron where like a hot knife through butter). Did it in the end but I decided the rest of the holes would be drilled with a spade bit and drill driver, never blocked once Quote
G S Haydon Posted October 30, 2013 Report Posted October 30, 2013 I've had tag same problems before. In my case it was cherry. I tried two different auger bits each with different lead screw types and the lead screws would load up with crud and not pull any more. I had to pick the threads out with an awl. Both bits worked great on a piece of pine as well as oak. I still don't k ow what the issue was. I had to use a modern drill bit to get the holes done. Just noticed this Greg , great minds..................... Quote
Nick2cd Posted October 31, 2013 Report Posted October 31, 2013 You ran in to an age old problem when boring into hardwood. All you need is a bit of cutting lube. Can't think of the name of the stuff but its green and kinda pricey, but man does it ever work well for this type of stuff. It just came to me...festool! 2 Quote
