chrisphr Posted November 9, 2013 Report Posted November 9, 2013 I was all set to buy a low angle block plane when Marc released his top four recommended planes for hybrid woodworker and it didn't make the list. Instead, it was the rabbiting block plane that made the cut for its ability to trim tennons. Only difference I can see that might be a negative of the rabbiting block vs the low angle block is that it doesn't have an adjustable mouth. Only a few bucks difference in the price, which one is the better, more useful buy? Quote
wdwerker Posted November 9, 2013 Report Posted November 9, 2013 I have both and the block plane gets more use, but I do loose tenons not the traditional ones. Quote
mikem Posted November 9, 2013 Report Posted November 9, 2013 I have the rabbeting block plane, and love it. Quote
Llama Posted November 9, 2013 Report Posted November 9, 2013 It depends on what you need it for...I'd buy the low angle block plane first. Second, I'd buy a good shoulder plane, then perhaps the rabbet block if you need wide rabbets. Quote
CessnaPilotBarry Posted November 9, 2013 Report Posted November 9, 2013 I use my rabbet block more than the regular block, but I use a low angle smoother and a #3 or #4 bench plane where lots of people use block planes. For example, I just got finished flushing dovetails on a box I'm making today. Lots of folks might use a block plane for this, but I find a low angle smooth plane to be faster, because it's wider, and easier to use, because it's got a lot more mass. My favorite tool to trim tenons is a router plane, because it automatically leaves a tenon face that is still coplanar with the face of the board, and easily gets right up to the shoulder. No tapered tenon faces... On longer tenons, just add an offcut from the same stock as the part with the tenon, or a second copy of the same part, to keep the router from tipping. Scroll down THIS PAGE to see how to do tenon faces this way... Derek Cohen appears to be a hand tool only person, but I usually do the initial cuts on the table saw. Quote
Trip Posted November 9, 2013 Report Posted November 9, 2013 ==> but I do loose tenons not the traditional ones. That's probably the key consideration... I've got every one of LN's block planes... The rabbiting plane got the most use until I got a Domino... Now the block plane that gets the most use is the one that I know is sharp..... Quote
mikem Posted November 9, 2013 Report Posted November 9, 2013 The really nice thing about the rabbet block plane is if you are just getting started with your hand tool collection, it serves the purpose of both a block plane and a shoulder plane very well. in fact, I haven't bought a shoulder plane yet, which has allowed me to build up my hand tool collection in other areas. Quote
chrisphr Posted November 10, 2013 Author Report Posted November 10, 2013 Thanks for all the good suggestions and different perspectives! It sounds like both are great tools so I can't get it too wrong. I think I am now leaning towards the rabbiting block plane. As far as I know, LN is the only company that makes them, correct? I couldn't find a competing version on the LV website... Quote
PaulMarcel Posted November 10, 2013 Report Posted November 10, 2013 The skew block plane is hidden away in the Rabbeting Plane section: http://www.leevalley.com/US/Wood/page.aspx?p=65373&cat=1,41182,41192&ap=1 The blade itself being skewed means you'll likely have to hone it by hand unless you find some jig that holds it (dunno, maybe the MK-II does... probably, but would look funny). The skew is nice for rabbetting as well as normal block plane operations since you get whole sole on the stock with skew instead of having to skew it yourself. Free shipping right now, too. Quote
