Repairing Carbon Fiber with West System Epoxy
You guys know a lot of things, particularly about making and reparing things :-).  So I was hoping you might be able to provide me some guidance on this repair project, since it is a difficult thing to find on google: Filling carbon fiber damage with Epoxy on a bicycle frame.
I took my bike in last week for some tune up work and the mechanic identified some damage to the frame cause by "chain suck" (when you drop your chain while you are riding and it gets jammed into the frame by the torque fromt he spinning crank shaft - cycling's version of kick back).  The mechanic said he "cannot recommend" that I ride the bike in this condition, but after some additional questioning he admitted that is Legal CYA, and I should be fine if I fill the damage with epoxy.  Since a replacement frame would be around $1500, I am pretty motivated to get it fixed.
I have some West System epoxy for woodworking, and based upon what I've read about it online, it should be tough enough to work great in this application.  Really, the intent is to provide a new surface so if the chain drops again, it grinds epoxy rather than more carbon fiber (which can then lead to an actual safety issue).
My initial thoughts were to pool the epoxy in the damaged area, then sand smooth when it dries.  However looking at the damage (see picture) this might be difficult given the convex shape.
Do you have any ideas for building a resevior (maybe out of masking tape) to hold the epoxy in place but won't end up permenantly glued to the bike?
Should I let the epoxy sit around a while before applying so it's consistancy is a little more viscous?
Any other ideas about how to make this repair?
Thanks!  I've included a photo of the bike so you know what you are looking at.  The damage is behind the chain rings/crank on the tube that leads to the seat post.
post-14334-0-21319600-1384184311_thumb.j
post-14334-0-61564500-1384184423_thumb.j
Call Gougeon Brothers directly (the makers of West Systems).  They have excellent tech support... They also have several epoxy product lines beyond the 105/205-6-7-9 resins that woodworkers use...
Technical Services: Toll free 866-937-8797 / 989-684-7286 / Fax 989-684-1287
It looks like the cords of the layup have been severed. Dependant upon how deep it goes it may or may not affect the structural integrity of the frame. If it has only scratched the surface you may be ok. Boatworks may be able to advise.
Being the guy that I am (faithful follower of Red Green) my guess is that a bubble gum dam around the affected area would be sufficient. Obviously you shouldn't chew the gum after being used as a dam. I would check with West Systems about the correct epoxy to be used in this application.
I've never worked with CF :(, so afraid I can't offer much advice other than what's been mentioned (contacting west system).  I will say that I see a clean break in the laminate which means that you'll ultimately need to sand the surface back and lay up new material.  From what I'm able to see, it looks like the inner laminates are fiberglass (probably just 1 or 2 thin layers) with the top / exterior finished in CF (this is typical construction for a lot of parts that use carbon fiber).
Also I would contact the manufacturer to see if they'll share any specifics on the materials used in the construction.  This will be helpful info if you end up trying to repair it.
IMO simply filling the damage with epoxy and not doing a "proper" repair will be somewhat of a waste of time.  Thick(er) layers of epoxy without any reinforcement (whether it be filler, or laminate material) will be brittle and not provide the necessary strength..  Not saying for sure that it wont work, but I wouldn't place a lot of confidence in it's longevity..
Good luck!  I'll be interested to hear what you're able to find out...
==> I've never worked with CF  :(
Yea, that's why I suggested it... :)
Their Aerospace product line gets used for CF laminates and figure they would be able to provide much better info...  Who knows, they may supply the resin for the bike mfg in question...
The frame is toast. Argh.
When I stopped by the bike shop to pick up the bike to repair at home, I learned the gouge was actually on the chain stay (tube between crank and rear wheel) and the picture didn't do the damage justice. The location of the damage definitely changed my mind. I don't know why the mechanic I was speaking to originally thought I might be able to get away with a repair, at any rate by the time I got there the entire shop was a united front that the bike shouldn't see the road again.
Shop is going to see if Cervelo can make me a deal on a new frame... If not, eBay. :-(
Thanks for the help. I actually did call west system and they were really helpful. They suggested the 105 resin and add some fiberglass tape. He said while fiberglass is not as structurally strong as cf, it resists abrasion better (which is how I described the problem). So I learned something at least!
I also liked the idea about the bubble gum and the warning that I shouldn't chew it again after it was used as a dam for epoxy. That is good to know cause now that I have to buy a new bike frame I will have to conserve my resources, including chewing my bubble gum a little longer.
I have no idea what "red green" is, but I am intrigued.
Tough break!  Good luck with the replacement!
WHO Red Green is. What's this world coming to?
I find myself deeply saddened by this as well.  Although I found the bubble gum dam highly appropriate, I would've suggested duct tape & some reenforcing bars found at the heart of fudgecicles.
You can also use plumbers putty or glazing putty as a dam. The phrase " worth a tinkers Dam" referred to a process to fix a hole in a kitchen pot. A putty dam kept molten tin restrained to fill the hole, let it cool, file it flat and pot is back in service.
...just more evidence that I am not as cool as you hipsters. :-)
After watching my first episode of Red Green, I now realize that my hipster joke was funnier than I had thought when I typed it.
This might be a good time to suggest that when you get your new frame you might want to put a protective sleeve of some kind around it in the spot where the chain caused this wound.
