Jay91 Posted November 3, 2014 Report Posted November 3, 2014 I have searched the Web a bit but can't seem to find my answers. My questions are does anybody know what the horse power is on the ridgid table saw from home depot? And can it take a dado blade? Then the other question is "can the contractor style table saw from grizzly accept a dado blade?" And I'm sorry ahead of time if these questions sound stupid, I'm brand new to woodworking and I'm probably just not looking in the right spots. Thank you. Quote
..Kev Posted November 3, 2014 Report Posted November 3, 2014 Which model Grizzly saw are you looking at? If you look at the saw on the Grizzly site, you'll see a button for the pdf manual. You can download the manual which should answer those questions.. I think this is the one you're looking at.. http://cdn0.grizzly.com/manuals/g0732_m.pdf Not sure about the rigid but, there are several people here who use rigid saws. Quote
chefmagnus@grics.net Posted November 3, 2014 Report Posted November 3, 2014 I found part of your answer here http://www.woodworkweb.com/woodwork-topics/woodworking-tools/300-using-a-stacked-dado-set.html You will also find that most stacked dado sets come in 8 inch, or 6 inch. If you have a smaller table saw such as one with 1-1/2 hp motor or less, pick the 6 inch dado set. That is because there is less steel to spin which will help preserver your motor. If you have 1-3/4 hp motor and more you are probably safe with the larger 8" stacked dado sets, of which there are a number to choose from. If you are only cutting dados once in a while and don't need to have super clean cut dados you will be very happy with a more budget minded dado set such as the Freud 8" Dado Set. Another Part Here http://www.homedepot.com/p/RIDGID-13-Amp-10-in-Professional-Table-Saw-R4512/202500206#specifications Home Depot says that the 13-Amp 10 in. Professional Table Saw http://www.onlineconversion.com/motor_horsepower.htm Online Converstion Calculator Says that 13 amps can produce 1.359 HP or about 1-1/3 HP, So you will be able to use the 6" Dado set. Here is a link to 6" dado sets available at Amazon http://www.amazon.com/s/?ie=UTF8&keywords=dado+6&tag=googhydr-20&index=tools&hvadid=32826133709&hvpos=1t1&hvexid=&hvnetw=g&hvrand=551868792559207999&hvpone=&hvptwo=&hvqmt=b&hvdev=c&ref=pd_sl_40cc4zsu97_b Quote
Tom Cancelleri Posted November 3, 2014 Report Posted November 3, 2014 At 13 amps though is it developed horsepower or true horsepower? General rule of thumb, saws that are rated in amps instead of horsepower are generally weaker saws. They rate the saw in amps to give you bigger numbers and make you think the saw is more powerful than it is. Developed horsepower is virtually useless, as it is when there is zero load on the blade. Quote
chefmagnus@grics.net Posted November 3, 2014 Report Posted November 3, 2014 So that is why they have gone to amps instead of horse power.... 1 Quote
rodger. Posted November 3, 2014 Report Posted November 3, 2014 I have the ts3650 1.5 hp Ridgid saw, and I use an 8" dado stack all the time. No issues. Quote
JohnDi Posted November 4, 2014 Report Posted November 4, 2014 I've got the 3650 also and have no problems with an 8" dado. Quote
wtnhighlander Posted November 4, 2014 Report Posted November 4, 2014 I'm feeling some dado envy. Mine's only 6". Quote
knotscott Posted November 8, 2014 Report Posted November 8, 2014 Home Depot sells two Ridgid table saws....R4512 stationary and R4510 portable Grizzly also has more than one model. It'd be best to ask about specific models, so we can be accurate. Quote
