lighthearted Posted December 28, 2014 Report Posted December 28, 2014 I recently bought a LN Tenon Rip saw. I've had the LN Tenon Crosscut saw. I am building a roubo bench by hand and figured the Rip saw would be a nice addition to my tool set. I am no master sawyer, but I am able to manage the crosscut saw fine (follow my lines) but the rip saw I keep having drift issues. I am right handed and the drift is always to the right. I am cutting the end cut of 5" x 4" hard maple beams. thought? besides practice? thanks Quote
Llama Posted December 28, 2014 Report Posted December 28, 2014 How are your boards setup when cutting? Quote
lighthearted Posted December 28, 2014 Author Report Posted December 28, 2014 On end--cutting the joinery for the legs. Quote
wdwerker Posted December 28, 2014 Report Posted December 28, 2014 Try it left Handed ? I am left handed and have learned some stuff has to be cut right handed, welcome to my world ! Or practice! I will cut something too long and check the quality of my cut, then cut to the line. Quote
Llama Posted December 28, 2014 Report Posted December 28, 2014 How do you hold your stock for the crosscuts? Quote
lighthearted Posted December 28, 2014 Author Report Posted December 28, 2014 How do you hold your stock for the crosscuts? It's in a vice Quote
wtnhighlander Posted December 28, 2014 Report Posted December 28, 2014 Shannon usually recommends ripping from alternate sides of the board, switching every dozen or so strokes. Seems to help cancel drift. Also, I find that putting no more pressure onto the teeth than the weight of the saw itself really helps keep the kerf straight. 2 Quote
rasher Posted December 28, 2014 Report Posted December 28, 2014 I can attest to flipping the board often. Also a chiseled knife line helps to start the cut, then a steep angle to get a kerf going. One side then the other... Then you can go to town following your kerf on both sides. Repeat that sequence. I do prefer a Japanese pull-stroke for making long rips however. Probably just a personal preference. 1 Quote
Popular Post RenaissanceWW Posted December 29, 2014 Popular Post Report Posted December 29, 2014 The BEST thing you can do to assess a sawing problem is to film yourself making a cut. Take 30 seconds or so of footage from profile and from straight on. You will quickly see any body mechanic issues that would throw a saw off its line. Correct me if I'm wrong but you are talking about making the tenon cuts here right? The flipping the board techniques is something I do for actual rip cuts to dimension a board so that advice is not applicable here. I do cut tenons from both sides of the board just because it is the only way to see your lines but I'm not flipping until I hit the far corner on the end grain and the shoulder on the near side. Then I repeat on the other side. A cross cut down on a bench hook or in a vise is a different body position than cutting a tenon and you may well have some issues with alignment. Start with a wide stance with your sawing side leg back. This positions your torso out of the way of your sawing arm. Now place the saw on the corner of the board like you were to begin the saw cut and trace a line down the plate to your wrist, back to your elbow, then up to your shoulder. All of that should be in the same plane. If your body is in the way at all, your arm will deviate from this piston like path and can cause saw deviation. Look for your elbow to kick out to the side during a stroke. I would also spend 5 or 10 minutes doing some practice cuts in something softer (not Maple in other words) to see how the saw performs. Hard Maple is a beast with hand tools and it will exacerbate any body mechanic issues you might have going into it. The size of the cuts you are making can be tough too so you have a lot of things stacked against you right now on an initial outing with this saw. I'm not suggesting you are using it incorrectly, just that you are making it harder on yourself to diagnose a potential technique issue. Finally, new saws do have a break in period where they can be a bit grabby and possibly cause a bit of drift. Saw for 5 minutes with it continuously and you will get past that point and the saw should be running true. If you are still having tracking issues and the mechanics appear right you could have a set issue that Lie Nielsen can address or I can walk you though that if you like. Honestly it is doubtful since LN's QC dept is top notch, but not impossible. 4 Quote
lighthearted Posted January 1, 2015 Author Report Posted January 1, 2015 Thanks for the great advise Shannon. Quote
Trip Posted January 1, 2015 Report Posted January 1, 2015 You can thank GH --- http://www.sustainlife.org/store/online-courses/using-hand-saw/ http://www.sustainlife.org/store/online-courses/dovetail-demonstration/ Quote
cellardoor Posted January 2, 2015 Report Posted January 2, 2015 I've followed similar advice to Shannon's and it was definately body mechanics for me. I could tell that no matter how much I wanted to trust the saw to track that I was shying away from my line and drifting further away as I got down. After identifying it I still have to take some warm-up cuts before taking on a tenon. Quote
