Russell Beeman Posted January 12, 2015 Report Posted January 12, 2015 Okay guys, this may be asking a lot and I may be asking in the wrong spot, but I have decided that I need a router and a table saw to kick-start my woodworking. I am on a super budget so I have been scouring craigslist in the SF Bay area looking for deals I can't turn down. So far I have found http://sfbay.craigslist.org/nby/tls/4841755397.html this porter cable router for $100 that seems like a really good deal so I have arranged to make the two hour drive next weekend to pick it up. Here's where I really need help, I would really like to make this trip a little bit more fruitful but (this is actually a pretty big but) I can only spend another $100 right now. What should I be looking for, should I even buy this router, can I trust a $100 table saw from a few craigslist pictures? Thanks for the warm welcome so far and I hope to make sawdust soon! Quote
wtnhighlander Posted January 12, 2015 Report Posted January 12, 2015 Unless you find a really good deal on a used saw, $100 isn't going to get anything I consider safe to use. You'd be better off to buy a good circular saw, in my opinion. That being said, look for saws that have a cast iron table, and cast iron extensions, if possible. Your budget dictates an older saw, so you may not get a riving knife, but look for blade guard and splitter to be intact. Be sure the fence works smoothly, and that the table insert isn't missing. Don't bother going to look if the seller doesn't agree to a working demonstration. Take something to check that miter slots, blade, and fence are all parallel, but expect to need adjustments. Make sure the blade doesn't wobble. Don't be discouraged by the budget. You may have to wait a while, but good deals can be found. My saw came from CL, and I am quite happy with it. Quote
knotscott Posted January 12, 2015 Report Posted January 12, 2015 Make sure the router works, the variable speed works, and that it has a collet. This older Ryobi BT3000 could be worth $100 if it runs and works well....otherwise, not much in your area. Keep in mind the cost of a two hour trip, and consider the actual total before you go.... Quote
weithman5 Posted January 12, 2015 Report Posted January 12, 2015 I bought a skil 1830 combination router for 87 bucks off amazon delivered to my house. is it the best router in the world. no, but will it work reasonably well for a hobbyist starting out. absolutely. Quote
Russell Beeman Posted January 12, 2015 Author Report Posted January 12, 2015 Thanks for the tips guys, I am going to contact the guy with that ryobi, I figure a $100 table saw that I replace in a year is better than a year without a table saw. Quote
..Kev Posted January 12, 2015 Report Posted January 12, 2015 Thanks for the tips guys, I am going to contact the guy with that ryobi, I figure a $100 table saw that I replace in a year is better than a year without a table saw. I tend to agree with Wtn about the table saw. If the saw won't cut straight and true, it's of no use. Quote
Eric. Posted January 12, 2015 Report Posted January 12, 2015 Thanks for the tips guys, I am going to contact the guy with that ryobi, I figure a $100 table saw that I replace in a year is better than a year without a table saw. A year of frustration for a hundred bucks doesn't sound like a great deal to me. Keep saving. 1 Quote
wouldwurker Posted January 12, 2015 Report Posted January 12, 2015 +1 TS is not the tool to skimp on. Especially if dangerous, shaky, and not much help if it's not true and flat, unless you're just looking to rip two-by's into one-bys for garden beds or something. That said, I got by with a Delta contractor used $75 TS for a few years....but only used it for the aforementioned rough work. EDIT: Also, the router appears to be missing the plastic subbase - they're about $12. Rockler carries them. I have the 7529 version of that PC - not sure the difference in model, but it's a workhorse. Quote
Russell Beeman Posted January 12, 2015 Author Report Posted January 12, 2015 I see, I was about to ask about https://sfbay.craigslist.org/nby/tls/4843910503.htmlthis saw, but I suppose I should be looking for something else Quote
Raefco Posted January 12, 2015 Report Posted January 12, 2015 I see, I was about to ask about https://sfbay.craigslist.org/nby/tls/4843910503.htmlthis saw, but I suppose I should be looking for something else That could make an ok first saw, if it checks out. There are also several portable table saws at the big box stores in the 200 range, if you are going to be doing small stuff they would get you used using a table saw, are they good for ripping 2" stock, No but if you are looking at small home improvement projects or hobby stuff, yes. Im not so sure I wouldn't buy a GOOD circular saw. a straight edge and some clamps, if I didn't already have them, before I bought a table saw. Quote
Russell Beeman Posted January 12, 2015 Author Report Posted January 12, 2015 Ya, I have a circular saw that I am not completely happy with, I bought it a few years ago when I was re-tiling my shower and I bought it because I already had a drill that used the same type of battery (the craftsman c3) and the more I read and watch the more I realize how much I underestimated clamps, both in importance and price. Quote
dwacker Posted January 12, 2015 Report Posted January 12, 2015 I would take the Ryobi over that Delta. Folks don't give those old Ryobi's the credit they deserve. There was a pro woodworker Dave Shaw, most of the old timers have seen his work. He used the Ryobi saw and produce work that I don't think Ive ever seen matched. He did the Tsunami hope chest years ago and then just disappeared from the wood working scene. 1 Quote
mikem Posted January 12, 2015 Report Posted January 12, 2015 Just a note, that Delta is a direct drive instead of a belt drive motor. For that reason, I would pay about $75-$100 for that saw. If it was belt driven, I could consider going $150 if the seller won't talk down the price. Quote
Russell Beeman Posted January 12, 2015 Author Report Posted January 12, 2015 I'm so confused! I want to take everyone's advice, but I can't, but I may not have to worry about it as no one with a table saw has responded yet, so maybe I'll save for a table saw and just upgrade my circular saw or buy a jigsaw Quote
..Kev Posted January 12, 2015 Report Posted January 12, 2015 Getting away from a battery circ saw will be a major step in the right direction. You can make your own straight edges with the circ saw and get by for a while. You'll be better served in the long run saving for a decent saw. Quote
knotscott Posted January 12, 2015 Report Posted January 12, 2015 Think of our "advice" as "opinions", and go from there! The Ryobi BT had a huge following (BT3Central.com....everything you could ever want to know about it lives here)....if it's in good working order, the parts are worth more than the asking price. The Delta 36-600 was my first saw...I paid close to $300 for it new. It weighs more than the BT, but doesn't offer a riving knife....it is belt drive, sort of....it's got one of those cog belts like on a vacuum cleaner, but is largely considered a direct drive saw. It actually did a decent job for me, but it's loud, small, and the motors are prone to burning out, and aren't cost effective to repair. Both the saws mentioned have universal motors. I'd consider both of these saws a couple of steps up from the plastic benchtop models at the homecenters. These old Emerson made Sears contractor saws are workhorses....full size, cast iron, belt drive induction motors. These were the basis to all the former Ridgid contractor saws too. Check to see if the fence comes with this, The stock fence on these wasn't great, but they work and can be upgraded later on if you want. Feasible and easy to fix should the need arise too. He appears open to offers. Quote
Russell Beeman Posted January 12, 2015 Author Report Posted January 12, 2015 Okay, so, I know it's not a tablesaw but I'm surfing the craigslist and found this: https://sfbay.craigslist.org/eby/tls/4834288081.html. Worth it? You guys are all great, i couldn't ask for a better response! Quote
Eric. Posted January 12, 2015 Report Posted January 12, 2015 I hate to be the guy who always has to say it...but you're wasting your time with these little tiny old tools. You'll spend more time working on them than you will with them. If you're on a really tight budget, I'd suggest looking into playing with hand tools for a while until you can afford some decent machines. Just trying to save you from throwing your money down the toilet. 1 Quote
weithman5 Posted January 12, 2015 Report Posted January 12, 2015 Also check with Home Depot. I bought a 1 year old rigid table saw from their rental. Reasonably good saw Quote
Russell Beeman Posted January 13, 2015 Author Report Posted January 13, 2015 Eric, we all need guys to say stuff like that, and I appreciate it, it made me concentrate my searches more, saves me a bunch of time . They way it looks now is that I am going to get the router because it really seems like a solid machine and a good investment and then I will try to get a "good" circular saw and save up for a proper table saw to pick up in the next year or so. So my next question, is https://sfbay.craigslist.org/eby/tls/4835791173.html this a good circular saw? Again, this is the best forum I have ever been a part of and its only been a few days! Quote
..Kev Posted January 13, 2015 Report Posted January 13, 2015 I've got one of those and love it! With that said, I don't use it for fine wood working but, I would take it over the table saw you were looking at. Quote
Janello Posted January 13, 2015 Report Posted January 13, 2015 Yes, that saw is a good deal if it's truly new condition. Any worm drive such as that, be it Makita, Skill, porter cable would be worth that price. They start at around $300. new With your budget and what you are after, you should hit yard sales come spring. Sometimes you find a diamond in the rough hitting those things. Quote
Russell Beeman Posted January 13, 2015 Author Report Posted January 13, 2015 Thanks TIODS, that's great to hear! Janello, I am probably relying too much on diamonds in the rough, but, I'm still young, I've got time to search through people's leftovers! Quote
tim0625 Posted January 13, 2015 Report Posted January 13, 2015 Nothing wrong with that Russell....there's a huge market out there of used woodworking tools and someone is always looking to change - upgrade, getting out, or they've died and the widow is selling. Many (most?) tools are in decent to good shape. I personally stay away from tools that have been in a production shop because of the high usage. I don't drive long distances - i.e. for a router that the guy could put in a box and UPS to me. I stay away from tools that won't run. "It just needs to be put back together...." yeah right....I have a Jet 18" band saw. I looked at band saws and scoured CL for 2 years until I found a guy going to the mission field and only wanted $800 for the 1 year old, $1800 saw. I've just bought (3 weeks ago) a Powermatic 701 Mortising machine and it was new. The guy had an idea to make furniture and as soon as he bought it, his job transferred him. It's seen about 10 minutes use, It and the bits new, sell for around $630 and I got it all for $270. If you want a Table Saw, they're out there on craig's list but you'll have to be patient but the deals will pop up. If you need a table saw now, look at Home Depot, Lowes, or Amazon and the Ryobi or Skil are good starter saws and have a warranty. I have a nicer table saw now but still have my little Skil and it still works fine. The deals are out there....save your money, be patient, and keep searching. Gotta go to work...hold my sippy cup....I'm going in. Quote
Jeff Ellis Posted January 13, 2015 Report Posted January 13, 2015 I have one of those old Delta Table saws and LOVE it. It is, however, a belt-drive motor and I cannot speak to the direct drives. I also spent over $250 on upgrades and spent a lot of time to make it into a station in lieu of a contractor saw. As far as that jointer is concerned, save up for a decent floor standing model. I bought a benchtop model when I first started and got rid of it in less than a month, it was a hunk of junk. Finally, I read in your intro post that you are moving for CA to GA soon. Are you sure you want to haul a large machine across the country? Also, you might be able to find better deals in GA. Quote
