Gary Posted April 28, 2015 Report Posted April 28, 2015 This looks awesome Josh. This build is definitely on my short list. Question for those of you who use a power planer for flattening. Are you using a large stationary planer? I can't imagine a lunchbox has enough balls to push that heavy slab through - am I wrong? I've seen these large slabs go through a lunchbox planer. I think proper support on both sides would be the key. I also know that a lot of people just go straight at it with hand planes. Yeah, even though you can run both of these slabs through a planer (which is one of the features of this design), the entire top still needs to be flattened across both slabs once they are mounted to the frame. I also flattened mine by hand, but you can make up a router sled to accomplish this task. Either method can be a lot of work, but as Josh has discovered, it's really satisfying to get it finished! Quote
FtrPilot Posted April 28, 2015 Report Posted April 28, 2015 Josh...I had to go to the dictionary to get the right words...Here's a list of synonyms for Awesome! Awesome - Causing wonder or astonishment <the awesome beauty of Josh's Roubo> Synonyms amazing, astonishing, astounding, eye-opening, fabulous, miraculous, portentous, prodigious, staggering, stunning, stupendous, sublime, surprising, wonderful, wondrous. Awesome. Quote
Dnorris1369 Posted May 12, 2015 Report Posted May 12, 2015 Beautiful job man Sent from my iPhone using Tapatalk Quote
