Bench towards or away from wall?
I watched the remaining Roubo videos and realized that I'm getting towards the end. A lot of smaller things but nothing like the base and top slabs. Once I get everything put together on the floor I don't think I want move this beast. I'm wondering if there are any good reasons to have the vises on the wall side or open side? If I put them on the wall side I would have at 4 1/2' of space between the wall and the outlets right there. If I put them on the open side I would have more room and natural light from the window during the day. The downside is farther away from outlets and when heater runs the tail vise corner would get some warm air blown on it. I checked with laser thermometer and it was 87 degrees while running and since heater is vented don't think it adds moisture to the air. Heater runs about 10 minutes and hour on the cold days. What do you guys think or decision really doesn't matter.
3F1A0871-33E1-4E4F-9A1D-81E5C9CB3CF5_zps
DAE8A0B0-6D83-4F9D-91E7-FB9564688586_zps
I can always add an extra light directly over the bench if needed.
5210EE17-5955-4376-B198-1F207800C0FB_zps
I would want the vises toward all of my other tools. I assume in a mixed hand/power environment that you are using the back side of the bench primarily for stick storage and real estate for assembly. Using the vices to assist with joinery finesse etc would leave me not wanting to walk around the bench to return to the TS, BS, or MS for batch operations. My two...
Your back to the wall and a cabinet for your hand tools hanging from that wall. Easy access to hand tools while using the vise is what I'd privilege.
Pretty much the setup on your pics.
I'm with daniel on this one, you would have to put it to use to see if it works out but i've changed my shop about three times and i think i finally got it right (famous last words) i would angle the louvers on your heater to more straight out if you can, may take some heat off the bench and you when you're working
light from the window would be good bob but i often work at night/early morning when the light from a window is not available, i thing i would install some good lighting right above the bench IMO
I never sit in a restaurant with my back to the door nor do I work in my shop that way. I don't want any buggers surprising me!
  • 26,009 Total Members
  • Joseph b Newest Member ·
