My jointer craps out on me when it's under load.  Sometime it also will crap out after running for a few minutes when not under load.  I posted about this a while ago and someone mentioned it might need a new heater element.  Before I ordered any new parts, I figured I should open up the switch and see if there was an issue with the wiring, but then I got busy with life for a while. I finally got around to thinking about it recently and it occurred to me  that even though the guy who sold it to me said it was wired for 110v (at the time I didn't have a 220v outlet), maybe it was wired for 220v and that was the problem.  When I bought it, I did put a new plug on it, because the plug it had did not fit my outlets.  The guy assured me it was 110v and all I needed to do was change the plug, so I took him at his word.  Since I now have a 220v outlet, if it is wired for 220v, hopefully I can just put a 220v plug on it and it will work again.  So, I opened up the switch to compare to the wiring diagram on the motor and all of the wires are different shades of black , except for one red wire, which was not attached to anything, and a vaguely yellow-ish wire that was connected to a terminal labeled "heater."  Not really sure what to make of it.  Can anyone who is electrically-inclined figure out if this is wired for 110v or 220v?  Here's the wiring diagram on the motor:
Here's the switch:
Hard to be certain from the photo, but I see only one wire on each terminal, so it appears to be wired for 220. In that configuration, there should be 4 wires from the motor, two of them on the switch terminals, the other two tied together.
Since the red wire is hanging free, it looks like the motor is running on just one winding. The "yellow" wire is probably grounded somewhere to complete the circuit. What I see it the picture is a recipe for electrocution. Don't plug that back in until all the wiring is properly terminated!
It's hard to tell with any certainty from your photo, but the label pretty clearly shows how it should be connected. Just connect it as per the label & you'll be fine.
Like highlander says, 1 of the windings is not connected. Each winding is rated 115V. When connected in parallel, the motor's wired for 115V, in series, 230V. With only 1 winding connected, it's 115V, but won't make rated power & might not start.
Thanks, guys.  That explains what's happening when I turn it on.  The only problem is I'm not sure how to connect it per the label, when the wires aren't color coded properly.  Take the cover off the motor and trace the wires back?
That's what i was thinking but you'd have to be very careful with that. I believe that induction motors use capacitors. Not sure if your motor has one but I'd just be careful.
Sorry, I missed the part about the wires colors being not there. You can easily determine which wires are paired with a winding with an ohmeter. Getting the polarity is a lot more complicated.
One method uses a battery & a galvanometer, another uses AC voltage applied the winding & can be very dangerous. Google will show you how if you would like to proceed on your own. Otherwise, take it to a motor shop & they could quickly do it for you & it shouldn't cost much.
You could also use the trial & error method, but that might let the smoke out.
3 minutes ago, Brendon_t said:
Why do you think the wires arent coded properly.
There are three black wires, no green wires, and the yellow-ish wire is connected to a terminal labeled heater, so I don't think that's even the right yellow wire shown in the diagram.
I think you'll need a new switch as well. That's a manual motor starter & is supposed to have a heater that, when the motor draws too much current, opens the switch. It looks like that OL heater is missing & the switch is old enough that I doubt you'd find a replacement.
If the motor has built in OL protection, then you don't need it in the switch.
1 hour ago, Tom King said:
The wires were maybe replaced at some point in it's life.
I'm not surprised, the jointer is at least 60 years old.  I left a message with a local guy who does motor repair work, just waiting for him to call me back.
If you can expose the wiring between the switch and motor, you may find the colors still there. The switch being mis-wired has undoubtely resulted in excess heat, which may have discolored the wire insulation near the switch. Farther back, it might be OK.
Good idea.  I'll check that.
Update:  Had a guy come and look at it this morning.  Turns out it was wired for 220v (which explains why it was stalling when plugged into a 110v outlet).  He traced the wires back and, surprise, it was actually wired (mostly) correctly.  The red wire wasn't hot, it was just a ground, although it wasn't properly grounded.  The rest of the wires were properly configured, even if they weren't color coded correctly.  So basically, he just put a new plug on it and grounded the red wire properly.  Feel kind of stupid paying someone to do that, but I'm glad he was able to figure it out.  Back in business!
Yeah.  I put the plug on because the guy I bought it from said it was wired for 110v.  Hopefully nothing is fried in the motor from using it at 110v, but I ran a test board and it seems to be working great.
That's what I thought. Glad you got it worked out.
On 2/9/2016 at 7:41 AM, davewyo said:
Maybe your heater element is bad. Or possibly your heater element is for 220v and you are running it on 110v.
  • Who's Online   0 Members, 0 Anonymous, 47 Guests (See full list)
    26,008
    Bob44
    Bob44
