Maloof rocker questions
Today I got some spare time to drill and attached the legs with screws. This will now enable me to cut the arm blanks and start fitting it to the rear legs. I'm pretty excited about this next phase!
I also got some epoxy for when it comes time to glue up. I opted for the slow set so I got more open time to get everything right.
  • Replies 131
  • Views 30.2k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • I've finished the leg joinery now. I just got to shim the rear left leg. My course Holey Galahad wheel arrived today so I'll start working on the seat over the next week.
  • I got the legs turned and dowel holes drilled yesterday. Today I continued grinding the seat and worked on the front of the seat. I didn't use the front template supplied but rather freehanded a
  • Still plenty of work to do on the arms but they're getting there. Next up will be refining the front and underside area. But I'm happy where things are at now. Thanks!
Posted Images
Looks great Andy that seat is really going to pop with finish! I also like the way you sculpted the seat front.
Thank you.
I still got work to do on the seat but I'm happy where it's at now. I will transition the pommel into the seat but I'm still working out how I'd like it. The front will also be sculpted a bit more and I'll create a more dramatic perimeter around the seat with my grinding wheel. But that can wait.....
Question: My leg joints with clamps are pretty tight. I have noticed that the screws don't seat the joint fully. The front legs have a very small gap (a clamp closes it) but the rear legs are a little worse. Do you think this will effect the fit of my arms and headrest when it comes time to glue up and the joint is closed up that little bit more? Should I fit the joint with a clamp on or should it just be fine?
Thanks!.
You should fit the arms with it fully clamped as you will when you glue it up.
Yes, clamp it up where it's going to be for the fitting.
It turned out that I just needed a clamp running front to back and the joint closed up perfectly. I think this is how I'll glue it up also with the screws.
I started work on the arms today and I'm pretty happy how everything has turned out so far. I just need an 1/2" dowel point centre to mark for the dowel. I went to my local big box store and thought they'd have them on hand. It turns out not only they don't stock them, but they're very hard to find here in Australia. I can find them in metric only. Luckily a friend of mine came to the rescue and had a set do I'll pick them up during the week.
You'll need them again when you attach the rocker..  Looking great!
Thanks!
I've completed most of the sculpting on the arms now. I just need to refine the hard lines and of course blend in with the leg when it comes time to glue up.
IMG_3528.thumb.JPG.8dba3139022cae3c596b7
I also worked on the seat yesterday. I refined the inner perimeter and the pommel. I ordered a rotex sander today which will help me sand the seat and other parts of the chair.
IMG_3507.thumb.JPG.d23c3530d16f32c2a2575
I cut the 9 degree angle at the back and front of the rear legs today also. This curve matches the headrest and the rear of the seat.
IMG_3535.thumb.JPG.714a1e5de710a080111bd
Coming along nicely Andy!! the chair is really coming together. Which sander did you get?
I got the RO150. After speaking to a couple of guys who make rockers full time they all swear by it.
I fitted the headrest the other day and I'm quite happy with the fit and the grain. Next up will be cutting the curves out on the bandsaw and drilling the spindle holes.
I'm hoping to have the legs glued up in the next week so I can start sculpting the leg to seat transitions.
I've started sanding the seat in preparation for gluing up the legs. I've got it sanded to 60 so far but will go up to around 500.
First up was refining the shape. I wanted the front to appear thinner than it was so I removed material from the front and underside.
The tools used to refine the seat..... The rotex is so good! I used 36 grit paper and used skimmed over the surface and it did an amazing job- very happy.
After attaching the headrest to the arms with screws I started working on the horns.
Thanks !
Looks awesome Andy!  I don't see a need to go to 500 grit but, it's your chair..  I took mine to 220 and was perfectly happy.
Keep the pics coming, I'm enjoying them!
Andy, first of all, I would never attempt this build so I applaud you for doing so and it looks fantastic so far, except... The front edge of the seat seems awfully thin, and I'm use to seeing the convential rockers, ie, Cracker Barrel's. Is it thicker than it appears?
Thanks for the comments.
That's what I wanted to achieve- making the front look thinner than it is.
Here is a pic of before I sanded and scraped the underside. You may be able to see that there is still plenty of material there.
Thanks! I have a habit of over doing things.... I'll see how I go.
Did you use west system epoxy for your legs joints! I have the 105 and 206 epoxy and was wondering if it's worth getting the 404 high density filler? I'll have to get it from overseas as it's hard to find here in Australia.
That's what I used.  I did use the filler but, could have gotten away without it.  As long as your joints are tight, you can get away with it no problem.
Andy, the build is really looking great! I just spent a bit of time reading it through from the start. Really impressive work so far! Inspiring me to move my build higher up on the priority list! Looking forward to seeing it all come together.
Thanks for all the comments. I've really enjoyed the build so far and plan to build more in the future.
The chair is dry assembled now. Next step will be gluing up the legs to the seat.
I've only sanded the seat to 60 grit. I'm thinking I may leave it as is as I'll be sculpting the leg to seat transition and will likely need to sand around the seat again to blend in. I'll the sand the whole seat to a much higher grit.
  • 26,012 Total Members
  • JAR Newest Member ·
