Are you saying that the rollers stop turning when they engage the wood? Are they not driven by the same motor that drives the blades? If so, there has to be a gear jumping teeth, a chain jumping its cog, or some sort of clutch mechanism that is slipping. Look closely for a gear that is missing its key or set screws, or perhaps a broken roll pin, if that is how they are attached to the shafts. Simple friction can make the rollers turn with no load, but when they work against the wood, friction will be overcome, and an un-pinned shaft will spin in the gear hub.
In the first picture it looks like the shaft may be missing a key.  I'd look at the one first.
Turned it on this morning and looked at the other side while I fed wood in. You'll see two gears in the picture - the small one is driven by the motor, and the large one runs the drive chain to the rollers. The large gear skips/stops under load (actually, I can make the gears skip by turning both rollers with hand pressure). I would assume that the fix for this problem is a replacement gear.
Also, I tried searching the model number on Sears Direct and Google, and I get zero hits - absolutely nothing. So it's either really old, they made a separate model number to sell this in Canada, or it is unicorn & is the only one of its' kind in the wild. Yayyy.....
Craftsman 351.275210 is anyone thinks they can one-up me.
Looks stripped.
You can always pull them off (both gears) and just take them to a local machine/hardware place.....see if they can look up equivalents.  Exact replacements might not be necessary - slightly larger/smaller gears would just change the speed of the rollers.  I would think the sum of the radius of each gear would have to be the same though - so the center-to-center distance is the same....
I'm thinking I might relist it on Kijiji for parts/as a project for someone (with a full disclaimer).
Tonight I'll see if I can pull the gears off and have a look. What I'd really like to be able to do is pull the whole top cover off, but it's on pretty solid - there's probably a nut I missed somewhere, but I don't see how or where.
@C Shaffer and @drzaius seem to be onto something - I pulled the gears off, and the shaft that the large one is on has a LOT of play in it (it's the bottom of the two de-geared shafts in the one pic).
I cannot see anyway to actually remove the shaft, or for that matter, take off the cover of the unit. I've removed every screw and Allan key* I could see that might possibly be holding it on, but it ain't moving. The only thing I can think of is maybe I need to take the rollers out to take the top off?
Thoughts?
*while cursing the engineer who decided to put Imperial AND metric on the same unit.
I hope you get this sorted. There are so many variables at play here. Thin sheet metal, keys, bearings, bushings... Just take lots of pics as you get deeper. It never goes well if you cannot put it back together.
  • 3 months later...
  • Who's Online   3 Members, 0 Anonymous, 68 Guests (See full list)
    26,008
    Bob44
    Bob44
