Here is something I would appreciate, please check in after a year with the increase to your electric bill. Like you, I don't trust the estimates but am always looking for real world data.
Too late but, the worst time to buy a house or a car is when you "need to" or are in "a hurry". ;-)
At least if the electric bill takes a jump, you can blame the car . . . but she gets to blame the shop :D
Yup.
OK, but it will be hard to know what electricity goes to what as the garage is on the same meter as he house and I've added electric heat to the shop.
When I put the electric heater in the shop I calculated the draw and looking at the electric rates I figured it was about a dollar an hour.  I can tell you this electric car draws 26 amps at 240 volts when charging and that typically you are not charging the battery from a flat condition, but rather topping up.
Also I can tell you that the last 10% of battery charge takes longer than the first 10%.  I can't explain the physics/chemistry, but that's a consistent observation.  So let's say you drive 10 or 20 miles on atypical day you probably charge 2 or 3 hours.
So one can do the math and make some estimates.
By the way we have not gone to any special electric rate arrangement with the power company at this point in time, just so much per KWH regardless of when.  It is possible to program the charging to take place at off hours, but we just aren't ready to tackle any more of the learning curve right now.
20 minutes ago, mat60 said:
Are you ok with the car now and will you go electric again?
I would have no problem with an electric car as a second car for around town.  You have to get your head into a different mind set.  For example you have 300 miles of capacity with a full gas tank as opposed to say 65 with a full battery, but you don't top up your gas tank every time you drive the car.  You do top up your battery when ever you park at home or find a charging station at your destination.  Might as well.
We've gone from panic struck about the range to being able to take it in stride the two times she forgot to recharge overnight. "Oh well, there's enough charge for where you are going and you have the range extender".  By the way we've tapped the range extender twice in two months.  Though not for the two above occasions.  I really like the idea of the range extender.
So different mind set, and you have to have 240 V (30 to 50 amp) charging capability.  So it would be difficult to own a car like this while living in an apartment.  Also I don't use this car for my long work commute.  This is the errand machine, though we do tend to use it whenever we "go out" for the evening.
By the way, I'm wondering if folks are missing the link at the end of the OP?  I know it was a long post, sort of the nature of a saga, though.
It's broken. Did you click on it and see it got broken?
How long for battery swap?
According to the very truthful internet, the Netherlands will be gas, diesel and internal combustion engine free by 2020. All the major cities already have plug in stations at parking meters. I like that
You said the Beemer was previously owned? Do you know how old the battery pack is? I like the idea of a near silent vehicle, with lots of low-end torque, but the limited range and cost of replacing batteries keeps pure electric out of consideration.
It is a 2014 with about 19,000 miles at time of purchase.
I don't expect to replace the battery, although the Fates may have a different plan.
By the way my other car is a 2006 Highlander Hybrid.  10+ years old and 160,000 miles.  So far no problem.  Unless it suddenly craps out I have no plans to part with it for the time being.
Anecdotal, but I asked my father the same thing recently. He bought a used Leaf two years ago, and it's currently his only car (other vehicle is an F350 w/ dump bed that gets about 5mpg). He said he hadn't noticed a real change to his electric bill, if there was an increase, it was offset by the Mini-Split Heat Pump he switched to the same year.
  • Who's Online   1 Member, 0 Anonymous, 30 Guests (See full list)
    32k
    437.5k
    26,007
    FurniCore
    FurniCore
